Home EV Charging 101
edited June 2021 in General
  • AlGrsnAlGrsn Member Posts: 1
    "These outlets aren't designed for that type of use and will wear out over time, potentially becoming a fire hazard." This is true as regards NEMA 14-50R outlets intended for electric kitchen ranges. They commonly are not unplugged and plugged for years. Heavy-duty commercial-industrial-rv park grade 14-50R outlets designed for frequent plugging-unplugging are much more expensive - like $17 instead of $8. RV park plug-ins should be expected to serve daily plug-in and unplugging. Just splurge an extra $8-9.
  • MHinNjMHinNj Member Posts: 1
    great article, but one point on the 11kw example. if the evse is a 48amp model, the circuit should be a 60amp circuit. the breaker and wiring has to be 25% greater than the charger. put in the way of the code, the circuit can have a continuous load of upto 80% of the breaker rating.
  • snapundersteersnapundersteer Member Posts: 2
    Appreciate the comments! -JE
