hvac / air Mode Door Actuator Advice
97 subaru legacy brighton
I am unable to switch between air modes ( defrost, feet, body) and from the research I have done it seems like the issue is my mode door actuator. So I finally found the part and installed it and it still does not switch between modes.
I was wondering if I had to have my dash and all other electronics plugged in (dash lights) in order for it to work?
Also is it more likely that my wiring harness has a short in it or that my vent dash control box ( not sure what to call that part (but the box that you can switch between hot and cold or between the different modes))could be faulty?
Thanks for and suggestions and help.
