Vibration on Front Drive Axel / Transmission
apersaud500apersaud500 Member Posts: 1
edited May 2023 in Toyota
Hi All,
I need some help I have 2014 Toyota Harrier - CVT Transmission.
Toyota Harrier :Model : DBA- ZSU60W-ANXGP Engine: 3ZR-FAE TRIM: FA43 Transmission: K114- 01A
https://youtube.com/shorts/dwFUOBKk290
https://youtu.be/mBIDwmFOHv4
Steps done so far: All mounts replaced.
Front CVT Differential inspected but seems stiff (mechanic not sure if it should be stiff)
Please help. Thanks.
  • thecardoc3thecardoc3 Member Posts: 5,858
    Watching the video, it appears as if the axle shaft bearing support is moving. I'm not sure if it is, or if it's just a camera angle trick. When trying to identify a noise the video and sound are enough to start testing, but really not sufficient to try and say what is wrong here. Is the noise described always present or does it disappear at a higher speed? If I was investigating this, I would be using a stethoscope or my chassis ears tool to try and prove the origin of the noise.
