Hyundai Azera Starting/Stalling Issues
mac32mac32 Member Posts: 4
edited March 2014 in Hyundai
I have a 06 Azera I live NY since this cold spell has hit the car will not start with the remote in the AM after sitting over night. I have taken it back to the dealer three time and they have reset the system and replace a chip in the starter but it will only work for one day then it’s back to not starting anyone have clue to why this maybe happening
  • drdonrsdrdonrs Member Posts: 164
    mac,
    Is your remote starter an original equipment item? If so, which model do you have? I have an 06 Limited with Premium Pkg. and I don't remember that being an option. You are right that it has been cold here in the NY area. Wishing for a remote starter!
    Don
  • mac32mac32 Member Posts: 4
    I had it installed after market buy the dealer it is a nice option to have I have the same model you do
    What was the approximate cost and did it require the car to be at the dealer for any prolonged length of time? :confuse:
    The cost was about $500 and it done in a day
  • yorkiegirlyorkiegirl Member Posts: 1
    I also have an 06 Limited and it was not an option so I had mine installed after market as well- $265. I love it and have had no problems with it. We are in Ohio and also battling this gruesome weather, everything closed today including all govt offices.
  • killerztpkillerztp Member Posts: 4
    Hi mac32 I also live in NY and in fact I also had the remote starter installed by the dealer as well. At first I had the same problem you did, but after going back to the dealer twice or so the problem was solved. At first, I would remote start it then the car would power up and it cranks but won't start. Then they finally realized that the chip from the key was not placed in the close enough where the ring (around the key) can get the singals. After they placed the chip in a better spot my problem was solved and so far is been six months without any problems with the remote starters. Hope this helps. :)
  • samazerasamazera Member Posts: 6
    what brand remote starter do you have?
  • mjbekmjbek Member Posts: 3
    I have a 2007 Azena (7000km). When I start it the first time everyday, it shakes (the engin sound normal) for a few minutes until it idles normally. Hyundai mechanic said that this is a normally behavior for an azera.
    You input is appreciated.
  • gamlegedgamleged Member Posts: 442
    After disengaging the starter, I suspect I could set a full wine glass on any horizontal surface and not spill a drop as the engine runs...
  • jaymagicjaymagic Member Posts: 309
    Same here. Like a poster somewhere on this forum noted, if I didn't watch the tach I would not even know the engine started.
  • cobrazeracobrazera Member Posts: 352
    Note that there is a TSB concerning the cam chain tensioner on the Azera.
    The tensioner is hydraulically controlled and uses a ratchet mechanism to hold it in place when the engine is shut down ( it would otherwise retract due to loss of oil pressure ).
    The teeth on some of the ratchet mechanisms wear or shear and do not hold the tensioner in extended position. This causes a rattle of the cam chain on startup until oil pressure extends the tensioner. This would explain a slight rattle for a few seconds after startup.
    Thank you all for you responses.
    My Azera shakes for about four minutes only when it is cold, then it smoothes out when it warms up (or idles down). During the day, I hardly notice the engine started as some of you mentioned. I have heard of the problem with the oil reaching the mechanism which last a few second only.
    How can I access the TSB?
    Thank you again.
  • dborthdborth Member Posts: 474
    TSB # 06-20-002 Part Update, (Timing Chain Tensioner)
    Go to the link indicated below. You can print a copy for your dealer in PDF format.
    http://www.hmaservice.com/index.jsp?SSOSESSIONID=oa6tHjX4VkN3OMvBtW33DvF8
    Azera is 1 of 3 Hyundai models listed with same problem.
    Thank you very much.
  • dresdres Member Posts: 1
    When I brought home my new 2007 Azera I noticed that the engine was quite noisy. When it is started for first time in morning, it has a loud mettalic clang for 3-5 seconds (al;most like there is not enough lubrication?). Dealer tested oio pressure -said that this was "within spec" - that it could take up to 3 seconds to build up oil pressure. Any other such experience? What did dealer say or do?
  • grayfoxgrayfox Member Posts: 166
    You might have a faulty timing chain tensioner. There is a factory Service Bulletin 06-20-002 that addresses this problem. It is a warranty item. They replace the tensioner.
  • sardonesardone Member Posts: 5
    After 8,000 miles my Azera's engine began to make excessive noise. I took it into the dealer and I was informed that there were loose bearing on the main engine fly wheel. After two days in the shop and the lifting out of the engine the repair was completed and the engine is again as quiet as when it was new.
