Electrical issues
JustCory88
Member Posts: 5
So i think ive solved a alot of issues in one swipe here. I may be mistaking but go to your control modules and pull out the plugs and check your crimped connections. I think thats probably the culprit with most of the issues here. I just found the supply line to a preciously untouched rim modile to be loose enough where you could roll it back and forth in the crimp itself and that will cause so many issues.
Poorly crimped connections can lead to a variety of issues, such as an electrical short, an open circuit, or a weak connection. Poor quality crimps can cause corrosion, intermittent or poor performance of the connection, and even complete failure of the connection.
