Can I put slightly larger diameter tire?
My car originally needs 225/70R16. A friend could give me a set of alloy rims with 225/75R16. This is 3.12% diameter increase. I read 'stay within 3%'. Can I take these 225/75R16 or should I avoid them? Main concern - can this much of an increase do any harm to transmission?? I know about the speed / odometer reading, that's not an issue really. The real issue is transmission. Maybe there are other serious concerns in this given case? Please suggest if you are knowledgeable. Thank you.
What you do need to be sure of, however, is that the new wheels are the proper bolt pattern, offset, and center bore. The wrong bolt pattern would prevent you from mounting them at all. The wrong offset could cause rubbing, either on suspension or fenders. The center bore, if too large, can prove to be dangerous. Almost all of these issues are possibly solved with adapters, depending on the specs.
Tires of the same 'size' may be physically different in size, so there may or may not be a 3% difference in circumference.
While you’re on Tire Rack you
can see if that size tire is compatible with you vehicle.
