How do I replace the bracket that holds the rack and pinion on my Olds ?
AleroKat62AleroKat62 Member Posts: 1
edited July 2024 in Oldsmobile
I have a 2000 Olds Alero. On my way to work I suddenly felt like I had no steering control. I pulled over, got myself together and carefully made it back home. From what we've seen the rack and pinion seems to lift up off its bracket when I steer to the right. The bolt is gone and I believe one side of the bracket broke off. It's so hard to see it all using just Jack's. We don't own a lift. Does someone have a diagram or a website I can go to to see the set up clearly please ? I can't find anything useful at all. Thank you
Answers
  • thecardoc3thecardoc3 Member Posts: 5,858
    The "brackets" that hold the steering rack are part of the cradle assembly. If they have rusted off you need to replace the cradle.
