Ford F-Series Engine Swap
I am swapping engines on my 84 F-250 from a 6.9 to a 7.3. The year difference is from 84 to 89. I am having a lot of problems with the engine wiring. Can anyone get me a basic wiring diagram that will help me wire it correctly?
So far all I have done is made a little smoke.
Thanks in advance for your help.
what motors can i swap into this shell?
sometimes it won't crank at all, no dash lights on nor headlights. is this the starter solenoid?
also, it runs well but occasionally its like the tranny gets too hot and won't shift into 1st gear (manual tranny).
After it sits for a few hours (cools off) it runs fine if it starts. Is this a clutch problem or is it related to starting issues?
Scott
I just swapped out dist cap, rotor, and plug wires-could I have damaged a circuit?
Thanks for any information.
Jim
kcram - Pickups/Wagons Host
