radiator fan
alladin1alladin1 Member Posts: 1
edited November 2024 in Oldsmobile
I have a 1998 olds intrique gl. My high speed radiator fan setting does not come on. My low setting works fine. My A/C clutch went bad so I disconnected the electrical connection to it. My relays ,fuses,temp control sensor and fan motors all work fine. I can’t connect the electrical connection to the A/C clutch because it will most likely freeze up. When the temp sensor is disconnected my high speed fans turn on.
Why won't my high speed radiator fan work correctly?
Answers
  • thecardoc3thecardoc3 Member Posts: 5,877
    If it works under a default mode, such as disconnecting the coolant sensor, then it does work correctly. It only runs at high speed if there is a need for it to. If the low/medium speed is sufficient to cool the engine, then you won't see the high speed turn on.
