Trans Filter Bolts for 10L80 10 speed - Disposable "Single Use" and/or Reusable?
MikeySBytheSeaMikeySBytheSea Member Posts: 1
edited May 2025 in GMC
In terms of the two trans filter bolts for this 10 speed Transmission, I'm hearing two different stories. Some techs say that it's ok to reuse these 2 bolts and others say definitely replace them. They are to be torqued at 44 ft/lbs. I'm wondering what the pros or techs are saying regarding these bolts. Toss and replace or is it ok to reuse? They are scarce as Hen's teeth and it seems that you have to order these from the Dealer. Anyone out there with on opinion on this? Thanks.
  • thecardoc3thecardoc3 Member Posts: 5,869
    Which bolts are you referring to. SI doesn't point out any bolts for the filter that have such a high torque specification.
