Leak in power steering suction hose
ShaneTXShaneTX Member Posts: 4
edited October 2025 in Toyota
I have a 2002 Camry LE 2.4L 4-Cyl with about 116,500 miles. I hear a growling noise when I turn the steering wheel to the right or left at very low speed. When the steering is turned, I see some yellowish-green liquid oozing from the "suction hose" that connects the power steering fluid reservoir to the pump.
Is this a kind of leak that can be fixed using Bar's Leaks 1600 High Mileage Power Steering Fluid Repair https://www.walmart.com/ip/seort/16794875 or Rislone High Mileage Steering Stop Whine with Leak Repair 4604 Power Steering Fluid https://www.walmart.com/ip/seort/2426102232.
Are such sealants known to damage to the power steering pump or other parts?
  • thecardoc3thecardoc3 Member Posts: 5,869
    The hose must be replaced. Do not try to use a stop leak, that not only will not solve the problem with the hose it can cause other issues.
  • ShaneTXShaneTX Member Posts: 4
    Thank you for your suggestion. Actually, all three hoses--suction, return, and high pressure are original. They have taken a beating in the Texas heat, and are all candidates for replacement. I am just trying to make sure I am not ignoring cheaper alternatives.
    What are your thoughts on this hose set available at carparts.com: Power Steering Hose, Pressure Hose and Return Hose?
    Anything to be concerned about?
    Fix it right the first time and have no regrets. That link is to only part of the system but that's the right idea.
