Taurus overheats, what's wrong?
My son-in-law has a 1995 Taurus that overheats.
While driving (with coolant) the car is fine. When
he comes to a stop the radiator boils over. When
this happens, we notice that the radiator cap is
loose. We have tightened it up, but it seems to
loosen on its own (it has a screw on type, not the
old fashioned type). The car will continue to boil
over until it is out of coolant (not all at the
same time). What am I missing? Any and all help
will be appreciated.
Oh yeah, he has brought it into the dealer and
they can't find anything wrong (surprised?)...
Bad thermostat or radiator cap?
Does it have a temp gauge or indicator light coming on? Is this happening after a hard freeway run? Check your oil. Is there anti-freeze mixed in giving it a white/milky texture? Need more info.
In general, a pressure test, and test of the thermostat and radiator cap are called for. Does the heater work properly? Where are you adding the coolant, the overflow tank or the radiator? Cannot rule out water pump at this time.
My car is old, so I replace the fan clutch(belt driven, not electric) and replaced a new radiator, NO MORE overheating problem in traffic.
http://www.alldata.com/consumer/TSB/9319_mo.html
Interesting to here your problem. I did not mention the gurgling, but it is there. Right in front of the firewall. Very noticeable during cold weather when first driving. Did not notice during warmer months.
If your dealer is correct on radiator hole then it must not be very big as I am not losing alot of coolant from the radiator just the recovery tank.
Is your dealer cutting you a break on replacement as this is covered under a TSB. Question I have is why did the gurgling go away upon replacement of the hoses and then return two months later if the radiator was the real issue?
Thanks for your help.
I also believe there is a TSB on the hose that connects the recovery tank to the radiator.
alumiu
http://cartalk.cars.com/Columns/CC/CC7516TXT.html
An aluminum cylinder head which is 17" long will lengthen by 0.045" as its temperature is increased by 200*F. The corresponding 17" iron block will expand by only 0.022" with this change in temperature. The 0.023" difference, generally realized as 0.011+" at each end, must be provided by movement within the head gasket.
I believe this helps explain why the successful gasket makers were touting their achievements a few years ago.
The AXOD (and successor) transmission is major trouble.
Hopefully the littigation will move forward and Ford will pay everyone back (all years of these ) for all of the trouble they've had and quit making such crappy vehicles.
BTW - I had a Sable AXOD which went out at 25,000 miles and headgaskets were starting to leak. No warranty help from Ford - I sold car as "junk" at big loss.
WARNING - DO NOT BUY A SABLE / TAURUS / WINDSTAR UNLESS YOU YOU LIKE TO BE HUMILIATED BY COSTLY MECHANICAL FAILURES !!!
I've found the posts about Taurus/Sable interesting. I've had most of the problems other people have, but I usually found it was caused by poor workmanship or quality control. When I replaced the head gaskets, I found the failure was caused by improper installation of the heads when the engine was new. It was apparent by looking at the gasket imprint on the underside of the head.
After talking to trans specialists I found that performance shops recommend valve body work to make AXOD transmissions shift quicker, reducing wear and extending life. Still, I think 125,000 is the most you can expect from a transaxle. By the way, it's easier to buy an aftermarket shift kit for an AXOD than it is the make the Ford valve body mods.
Many of the noises/knocks/rattles have been caused by parts just coming loose. A lot of plastic fasteners are used nowadays, and they just don't last. Also, sheet metal screws are used in abundance, which work loose in time.
I have 150K on my 88LX. I was a mechanic for many years and do most repairs and maintenance myself.
Even though I wouldn't call a Taurus or Sable a very reliable car, I've had worse. Also, the interior and body of these cars (paint excluded!) is very durable if taken care of normally.
Figure On Repairs Daily
Found On Road Dead
For Only Retarded Drivers
etc......
My problems include:
1. a totally shot electrical system which means that the automatic climate control is perpetually blasting either hot or cold air in my face. I can't turn it off.
2. a blown AC compressor which shoots freon out from under the hood when on. Given problem 1 above, I have to drive with the vent or heat on at all times.
3. chronic overheating when standing in traffic. Coolant shot out of my radiator overflow like a geyser about 2 weeks ago. The coolant level in the overflow has remained constant - after I replaced the coolant that shot out. Of course, the engine runs on the cold side when I am on the highway, but heats up as soon as I stop at a stoplight. I am not mechanically inclined enough to tell if the engine fan is out, or if it is rather a problem with the radiator or radiator hoses / cap.
I've decided to stop being a chump, stop going to the dealer who is getting pretty happy to see me walk in the door, and to get a new car.
We are looking at Corollas, Civics and VW Jettas. Any advice?
The VW Jetta performs very well in safety crashes and in performance. Besides its German engineering and one should expect many years of trouble free performance
Your Ford has 100K on it and depdning on your driving mix of city/highway and your record of maintenance maybe some of the problems are expected. I doubt that is the case however.
A few years ago I traded in Saturn SL2 on a Volvo for my wife and found that the Saturn which had 128K (all our miles it was bought new) began having minor troubles with the a/c and the temperature control. Volvo tells me to expect 300K from the vehicle without a problem. We shall see. I doubt it will see over 100K while I still own it.
Personally I am a pickup driver and have a 99 Dodge 4x4 with absolutely no problems whatsoever.
You may want to look at the Chevrolet Lumina if you are thinking domestic. I also recommend the Dodge Intrepid.
See you there!
carlady/roving host
