Cleaning your wheels.
in General
Hello all,
I saw a post in one of the Mazda conferences about
a guy who stumbled on Windex as a wheel cleaner.
He swore up and down that it made his wheels look
new.
I tried it out and he's right? Brake dust comes
right off with a little squirt and a paper towel.
Does anyone out there use Windex on wheels
regularly? Can it possibly damage wheels?
new.
The wheel cleaner I've used for the 22 years I've owned cars: none. If you start with clean wheels (i.e. a new car), I wash them thoroughly with the same sponge and car wash mixture I'm using on the car. Dry them completely, and put two good coats of wax on them. I do this every month. When I wash the car, brake dust comes off of the wheels with a simple rinse of the hose. A quick wipe with a sudsy sponge and they're new again.
Wax will protect the wheels, and if you put nothing else on them then you have no concerns.
Any suggestions for a product that will remove this baked on dust?
My '93 Saturn's wheels clearcoat is starting to show damaged areas. Could the drive-through car wash detergents be the cause of this?
There are many culprits to oxidization of alloy wheels. First and foremost, the primary cause is a chip in your clear. As soon as this happens, you expose your alloy to the air, water and salt or other contaminants. Salt is the worst enemy, especially if you live near the ocean or in areas where salt is used to de-ice roads. Salt and water gets in, begins the oxidation process which spreads eventually causing the existing clear to lift and eventually flake off.
Solution:
1. If you live in areas where salt is used on the roads in winter, buy and 2nd set of steel wheels and winter tires for the winter months. Steel wheels can be purchased relatively cheap for most vehicles...check local autowreckers that guarantee their wheels free from cracks or bends. Winter tires will maximize your traction.
2. If a 2nd set is not possible, frequently apply a thin coat of vaseline or similar product to your alloys in the winter. Its messy and your wheels get dirty quicker, but they will slow penetration of salt and water.
3. Irregardless of your choice to use a 2nd set of wheels in winter, clean and wax your alloys frequently. I wash my alloys every time I wash my car and wax them regularly. Use a clear touch up for any chips.
Let me say this: I found a wheel restoration place that will take and re-finish and true any aluminum wheel for $150 or less. One of my rims got bent (hit a rock) and they did it, made it look and ride like new.
-Chris
Some posts I've read have strongly cautioned to be certain you get the NON abrasive type for car cleaning stuff.
Anyone know more or remember this better than I?
Pat
that being said, i'm not sure i'd use it on my alloy wheels...
-Chris
Ode to the days when things were much simpler
Harleybill
Just spray it on before starting to wash the car. As you rinse the sides, wash off the simple green too.
Then go over the tire and wheel using the remaining carwash solution in your bucket with a tire/wheel brush.
Works well for removing bugs on the front too, but can take the wax off. Since anytime you've had a close encounter with a bug you should rewax, it is no biggie.
best of luck
Castrol Super Clean, Eagle One Wheel Cleaner, PS21 Wheel Cleaner
The excellent ones are:
Meguiar's Hi-Tech wheel cleaner (not the Gold Class version), Mothers wheel cleaner
Someone suggested to use glass cleaner before hosing off the brake dust. I tried it, it did not work!!
My daughter leases a 1998 Saab 900 which she is due to return to the lessor later this month. Over the weekend, she ran over a pot hole and one of the wheels got bent so much so that it has affected the driving performance.
The car has the standard wheels that came with the car and she is looking to replace the damaged wheel. She has been quoted a price of $240 by the dealership just for the wheel.
Can anyone suggest a way to acquire the wheel at a lower price? Thanks.
If so, email karen@edmunds.com and ask her to ask Well Engaged to fix it for you. You will lose your "last post read" marks and placemarks, but the problem WILL be fixed.
See the discussion in Talk to the Hosts Part Three in News and Views for more details, or feel free to email me.
Pat
Unfortunately, the problem is with individual users "participation data" which means there is no "site" fix, it must be done on an individual basis.
You can email me if you have any questions at all.
Pat
Pat
