Sequential Shifting
How do you use this feature on the new 08 xB--I have never drove a stick or used a feature like this before and figured someone here may have a better explanation than the book. Also when do you think it is beneficial to use this feature?
If you did it when stopped, the car was in First gear when you took off, and it STAYED in first gear, unless you 'bumped' it gently 'upward'. Then it went into second, bump it up again, into third, etc.
I think if you pulled it to the left when going 40 mph, for example, it would stay in fourth, or maybe go into third. Either way, you bump it downward to go Down one gear, and Upward to go up one gear. If you were in fourth gear and came to a stop, I can't remember if it went to third, or maybe second, on it's own. But again, when you took off, it would stick in whatever gear it was in. You had to move it to the next higher gear.
One thing - it was the only car I've driven that had this feature, and I can't remember 100% if you moved the shift lever to the left or right to kick it into Seq shift. I know what it is for, but can't explain it without rambling. This was going to be a few sentences total.....I worked a 12 last night and should have been in bed hours ago... Seq Shift comes in handy, others will do a fine job with the details.
I am not trying to confuse you (or anyone), but with the car I rented, it was not needed!! I do remember reading, probably at Edmunds after I got home from the trip, that car had a great tranny. I'm not going out and buying a Kia, but the tranny in that car was outstanding. I paid close attention, and the thing shifted EXACTLY where I would have done it myself. And I mean like 99% of the Time. I swear I'm not making this up. In fact, it is the reason why I'm posting. Thanks for bringing it up. :surprise:
Plus sometimes you may just want to have the fun of controlling the engine and shifting when you want!
On a level road, try 1-10 2-25 3-35to 40, then into 4.
You may not need it much, and it does impact gas mileage. Also, if you're nit-picky like I sometimes am, it wears your car out quicker. Again, watch the board. Someone is probably on vacation that could describe this better. I saw an xB last Sunday at a lot. Teal with upgraded Wheels - the $750 wheel and tire package. Great looking car!
My Caliber actually has 6 gears when in Auto Stick. I typically shift pretty early, I don't "wind it out" too far. I'm in 4th gear at apx 45mp.
