Engine Flush Systems
Today my wife took in her Civic for a regular oil
change and rotation. The service guy mentioned to
her that it would be in her best interest to have a
engine system flush ( $130.00) . With only 24,000
thousand miles on this car is it really needed or
he just blowing hot air. I heard in reality it ends
up hurting the engine is this true. I would
appreciate any input.
guitarzan
Community Leader/Vans Conference
I'd switch mechanics, too.
guitarzan
During startup is when engine lubrication is most critical. So, here's the rub- if you use a flush, then you're putting low viscosity, low lubricity solvents in your engine oil, albeit for a short period, starting the engine, and then draining same. During the critical startup, you've impaired the lubrication system.
The above assumes that deposits are not so great as to cause sludge to break free and be pumped into an oil passage, thereby blocking it like a thrown clot.
I wouldn't use the stuff. I agree that the best you can do for your engine is the maintenance specified by mfr, and change the filter w/ each oil change. High grade lubricants (virtually any major brand with the appropriate svc grade and viscosity) and a quality filter are the way to go.
My advice is to just keep changing the oil, and if you are going to flush it, then don't buy the cheap stuff.
I understand that the two-letter stuff sold at most high-dollar places is pretty good, though.
help keep my new car running well and
helping out the gas mileage. I think
she said its called GUMOUT and you
put it in your car (either into the
engine or gas) every 2 weeks and it
cleans out your system. Anyone know
about this product or have experience
with it?
Do these work at all?
Which one works best?
My 87 Accord carbed engine has some pinging(?) when I accelerate in too high of a gear.
I have 177k miles on it and I have always used the cheapest gas in it...do I just need a timing adjust or will a combustion chamber / fuel system cleaner do better?
Gumout makes carburator and fuel injector/system cleaners which go in your fuel NOT in your oil.
There are other good ones as well, but some we tested internally are little more than solvent in a bottle.
I hear BG44K is good too.
Click and Clack (PBS auto gurus) mention Techron and BG on their website.
FWIW, Chevron invented and patented the original "PEA" detergent fuel additives. The Oronite Chemical Folks sell PEA and cheaper PBA bulk fuel additives to the aftermarket, and gas retailers for use in pump gas. Some folks use better additives than others.
Generally, I personally believe, the major brands are more effectively additized to keep your engine cleaner. Disclosure: I am employed by Chevron...but Edmunds is personal gig.
BTW, Click and Clack have no clue. They have all these promoters telling them what to say and if they are mechanics, then either they haven't been very long or need to go back to some schooling for some of this stuff.(That is my personal opinion of them,like it or not)
It amazes me that they have the following they have and they give the most attrocious advice I have ever seen.
Alcan, I don't think Canadian radio would allow such trash on their stations.
wow, is this getting off the subject or what?LOL!!
