Audi A4 Audio Questions
yifeiyifei Member Posts: 12
Hi guys,
I just bought an A4 2.0T. But it seems like I can't use ipod with direclty even via the cassette hookup. So anyone has some idea about how to use ipod with the car, or probably I can only burn mp3 cd by myself?
Thank you for any input!
  • yifeiyifei Member Posts: 12
    Hi guys,
    Anyone uses Itune to burn CD and play it in Audi's CD player? Does it work well?
  • a4quattroa4quattro Member Posts: 3
    I do. I have the Bose Symphony system in my A4. CDs play and sound great! I get all my music, or most of it anyway, from itunes.
    I don't have the Bose but I think the standard audio is ok. So you think I don't need to have the ipod interface installed, right?
    Thankyou
  • shaner747shaner747 Member Posts: 1
    I am trying to buy a module to hook up Sirius, does anyone know if it is ok to installthe module P/N 8E0 035 593 D, the dealer gives the part number 8E0 035 593 F and wants over $500 for it.
  • jlkiljlkil Member Posts: 18
    did you get an answer on this? After signing the papers on my new audi, I learned it was "wired" for Sirius. Is there an aftermarket model that will connect up to the Audi Symphony radio?
  • lucya4lucya4 Member Posts: 2
    I just picked up my car and am having trouble with the built in iPod recognizing my playlists. It appears that CD 7-11 pick up the first 5 playlists, but does not show the playlist name? Is there a fix to this? I knew the songs wouldn't show, but the playlist?
    Also, how do I have the mix function stay permanently on? It seems I have to reselect this every time I turn on the car.
    Thx
    No - I've not received any responses, but reading more on the web, this appears to be a "quirck" of the car - sucks, but only thing thus far I do not like. Mine came with the satellite radio already wired - part of the Special Edition package. I had ordered the car in January without it, but it appears they did some switching on packages (it was ok).
    Here is the link explaining the radio:
    http://review.zdnet.com/sedan/2008-audi-a4-2/4505-10865_16-32577807.html
  • rookiea6rookiea6 Member Posts: 1
    I have a 200 A6 4.2 and have very poor am radio reception. I am wondering if there has been something disconnected or if there is a booster of some sort?
  • max4funmax4fun Member Posts: 1
    I have a 2007 A4. Bought it used. Signed up for Sirius Satellite Radio, but it didn't work. The Audi dealer is telling me that since I have the IPOD hook up, you can't have both. Is that a glitch? It doesn't make sense that you can't use your IPOD and use Sirius as well. Any thoughts?
  • dcaudidcaudi Member Posts: 1
    Hello everyone,
    i have a 2003 A4 3.0L, and the stereo died on me about a year ago. Audi says its the amplifier and they want to charge me ~$900 to change it. It's the Bose upgrade. Anyone know how I could find the exact amplifier and have a stereo place change it? Or can I just change the amplifier to any brand?
  • ilovemyaudiilovemyaudi Member Posts: 2
    Is anyone else having issues with their factor installed iPod players? Issues are as follows:
    - skips songs
    - repeats songs over and over on various tracks
    - does not read various songs
    I have now made 8 trips into my Dealer :lemon: and they can't figure this out. They have even gone as far as to say that there is no issue. WHAT?!!!
    I was told that my iPod was out of date and not supported with the Audi A4. So, I purchased a new iPod and I am having the same problems. Not only does these problems happen with my iPod (3 different iPods) but my frinnds iPods as well.
    Has anyone else run into this same problem? Any solutions that you can think of?
    - skips songs
  • wmendietawmendieta Member Posts: 1
    I was wondering if you can connect an ipod through the audio USB port using a USB cable? If it works can you control the ipod from the audio system? thank you. My A4 only has a usb port it does not have an aux port.
    Thank You
  • nebatuganebatuga Member Posts: 9
    I've owned 05 and 07 A4s-- both with the Bose stereo upgrade. Looking at the 09, I see the premium audio is a Bang and Olufsen system, but only available on the "prestige" package at a cost better than $40K. That sounds like too much for an A4.
    It looks as if the stock Audi Symphony stereo is the best I can afford on the newly redesigned models. Anyone have any opinions on how the stock stereo sounds compared to the old Bose and new B&O system?
  • aussiem8aussiem8 Member Posts: 27
    I can tell you that the Audi Symphony is better than the Bose system. When I got my 06 A4 3.2, I specifically did NOT want Bose. I tested both systems in the 06 A4 with my own CDs and it was night and day. The Bose sounded awful. It was so bad I was convinced there was a fault in their programming. I added my own aftermarket subwoofer to the Symphony and it sounds great. The sub that comes from the factory is so weak you can't tell it's even there.
    The B&O system is the best of the lot. Very clean and natural sound, close to an audiophile quality. There is nothing wrong with the base stereo . . . just a little underpowered and needs an aftermarket sub.
    Thanks, aussiem8. Your response is really helpful. I realized after my original post that the Symphony seems to be the intermediate step between the base model and the B&O system. I've been very pleased with the Bose system on my 07 a4. I definitely need to get to a dealer's lot and listen to the Symphony unit. Adding an aftermarket sub sounds like a great solution, since I really don't want to pay 40K plus for a prestige packaged 09. However, I'm reluctant to do aftermarket work, since I lease. Do you know if Audi will add a subwoofer to the Symphony system on the premium package for delivery? Again, I appreciate your help!
    I lease as well, but adding an aftermarket sub is a great solution for leased cars. They connect right in with the factory set up and disconnect very easily. I had a local professional install mine. They just uninstalled it last week when I returned my 06 A4 at lease end. You DO NOT want your Audi dealer to do any of this for you. Firstly, on the 09, all you can get is the factory set up, which will have poor bass once you turn the volume up to any decent listening level. But then I really want tight, deep bass with my music to provide a full bodied sound (not the head banging, hear you from 1/2 a mile away rumbling bass that the young kids of today call bass), so you might find the factory set up to meet your sound needs. Best way to decide is bring a selection of your own music (important to try different genres) and play it on the car system. Let your ears tell you what works for you. If you decide on an aftermarket sub to add on, you should expect to fork out as much as $500 for the sub, amp and installation. Although I usually get high end equipment, I went the budget route on my A4 and got an Infinti Kappa 10" sub with a Profile amp -- both purchased from Crutchfield.com, based on their customers' online reviews. Had the installer build the subwoofer sealed box. All in < $500. And the sound was amazing, and worth every penny. At lease end you still have the equipment to put in your next car. If you decide on adding a sub, I'd be happy to give more details via email. Have fun experimenting.
  • nuc318inuc318i Member Posts: 3
    they are right u cannot have both at the same time because and ipod are use connector so they have to eliminate one to get the other one,sorry.
  • jimlindseyjimlindsey Member Posts: 2
    I recently bought a used 2008 TT Coupe which was originally sold new in 2007. It has the Audi Symphony stereo sound system which has a plug for an iPod in the glove box. I have an older iPod with a hard drive and a newer iPod third generation nano -- whenever I plug in either of the iPods, the stereo recognizes the iPod and shows an additional six CDs (CD seven through 12) which is supposed to represent six playlists on the iPod. (What a lame system this is for playing an iPod) However when I choose to play one of these CDs, there is no sound. The track appears to be playing but there is no sound. I took this in to the technician at the small Audi dealership where I bought the car, and he was clueless. Does the stereo system need a software update? Anybody have any helpful ideas?
    Thanks in advance
  • jimbodtxjimbodtx Member Posts: 4
    I just bought a 2005 A4 2.0T, (not quattro). I have a white circle light with a red ring around it and it says MPH in the middle of it.... blinking every once in a while. What is this?
    How do I set my maintenance reminders?
    Does anyone own one of these cars that does not have Quattro and if so, have you had any problems with it. Mine has 43,000 miles on it.
    that feature using to set mph u re driving so u re not speeding u can set it and cancel.
    Does anyone own a 2005 A4 T 2.0 that does not have Quattro and if so, have you had any problems with it. Mine has 43,000 miles on it.
  • audifan9audifan9 Member Posts: 1
    I recently purchased a B7 A4 2.0T and planned on picking up the car this past weekend. The dealer called and said there was a problem. Apparently the radio that was in the car was not the factory correct radio and the mechanics realized it after failed attempts to try and get the installed radio to work. The previous owner attempted to install a factory Audi radio and removed the original. The car is being sent to Audi authorized dealer to have the correct radio installed which is also equipped with navigation system. I can not complain since the nav is an added bonus and I am not being charged. Has anybody heard of this before? At first I thought maybe the battery went dead and a code was needed to get the radio to work when I test drove the car. It sounds strange and I never heard of this before.
  • kmelbykmelby Member Posts: 3
    I have the same problem as the amp cuts in and out. Did you fix yours and what did you do?
  • dmz_nydmz_ny Member Posts: 2
    I just signed up for a new 2010 A4 lease and anticipate picking up the vehicle by Christmas...my understanding is that the car comes pre-wired with satellite radio -- a few questions:
    1. Does Audi provide a trial period for the satellite radio service (e.g. 3 months free)?
    2. If I already have satellite radio in another car (a Lexus), would I be able to provide XM with the radio ID for the Audi satellite radio and pay an incremental 2nd radio monthly fee as opposed to an entirely separate account?
    Thanks for your input.
  • eddie650eddie650 Member Posts: 26
    I lost radio reception (AM and FM) in my 2005+ A4 convertible this week for a few days; now it's back. Who knows what caused this - maybe a short in the antenna? I never lost my satellite radio reception during this time.
    I was planning to have the dealer check it out a day this week, but now that it's working again, guess I should wait for it to happen again. The dealer guy said that the antenna is not in the windshield, as I'd assumed, but within some trunk wiring.
  • llogiquellogique Member Posts: 1
    I am having the same problem with the radio of my 2003 A4 1.8T Audi Cabriolet. When I got in my car last Friday morning, I had no radio reception. After the tuner went around the dial 4 times, it finally found a single station. The dealer said it was a wiring problem (in the trunk) and would take some time to troubleshoot. Since they already had me for $1100 (purge valve and oil gasket (and they are replacing the ignition coils under recall), I told them not to proceed. Suppose this could be fixed by a stereo-install shop?
    you may have a bad antenna recevier is in truck of vehicle it is a flat black module control the stereo system.
  • robbieusarobbieusa Member Posts: 1
    I have the same problem, anyone have an answer?
    In my 2008 Audi TT, the ipod runs off the module for the satellite radio.This module was faulty.It was faulty.They popped in a new one and solved the problem. iReplacing the module is simple
  • blacklotusblacklotus Member Posts: 1
    I have had the car for about 8 months now (it has about 80000 miles on it now) and Ive had no problems with this car at all. But lately, the radio and speakers have been on the fritz. It always started by just displaying "Phone" on the radio's display and it wouldn't let me do anything else on it (pushing any of the buttons on the radio didn't do squat). Usually I was able to turn the vehicle off and the radio would work again and stop showing that Phone message. But as of the past 5 to 6 days or so, It won't work at all! I am able to push the Load button and put CD's in and stuff, but the minute I push CD or FM on the head unit it goes strait back to displaying PHONE and won't play music. I didn't even think this model has phone capabilities. Is there any type of reset button on the head unit Im missing? Has anyone else had this problem? Any input would be SOOO Appreciated!! Or do I just need to get a new radio (which I don't really want to spend the money to get one)? Thanks for all the help to who all responds!!
  • sueintexas2010sueintexas2010 Member Posts: 1
  • rabbitrockrabbitrock Member Posts: 8
    Did you get your radio out of Phone mode? Mine's doing that now thanks to the sugar-water industry.
  • squareonesquareone Member Posts: 1
    edited November 2012
    Mine one a 2002 A4, audio unit developed a fault which drain on battery. It needs to be replaced. The part is 8E0057195, do I have to use this part (costs a small fortune) supplied by dealer or any Audi audio head that 'can fit in the slot' will work? How about 3rd party generic parts? I read report said the on-board computer may complain (as in here: non original audio )
    Any advice appreciated. Thanks
