Jetta Interior Issues
i am on a lease of an 06 jetta. the surface of the buttons on the cd player has swollen-looks like burnt- and can be peeled off by the softest touch.
no liquid, cigarette or anything burning or any other deteriorating agent has come into contact.
i was hesitating to touch the damaged buttons but i did and it looks bad.
does anyone know how can i get it fixed, if vw will charge me for the whole stereo system and generally what costs should i expect?
thanks in advance
thanks in advance
So one day 8 months ago I'm driving on the freeway at 70mph. All of a sudden (with my foot on the gas pedal) the car starts revving instead of driving. I mean I'm coasting but the speed is going down. I take foot off gas, turn hazards on and move aside. Once pulled over, I turn engine off and on, and it's fine.
Since then, that same thing has happened about 30 times. The "connection" lasts at most 5 seconds". VW can't run codes because it needs to happen when they test it. Know about Murphy's Law?? Apllies here...
The other day though I was on cruise control at 70mph, and the same thing happened, and even in cruise control the speed went down (the engine stays on but it's like something cuts out) Since I was in right lane I left everything alone to see what would happen... The car got down to 60 almost and all of a sudden with a quick jerk whatever it was got connected again and the car sped up by itself to 70 wit...
Any ideas?
As a side note, the temperature gauge on my car goes to normal (in the middle) and by itself drops to the left (cold) back and forth several time in a day...
are these two related? How can I figure out what is wrong with car??? PLEASE HELP!
Why would you be charged? It is still under warranty, right?
thanks again
If this happened 30 times, it makes me think there might be some issue ... Coolant leak, perhaps? Some people use water instead of coolant... If you are doing this, try using regular coolant.
Not sure if that helps but I remember the same exact thing happening to me in another car....
I have no idea what the smell was, but at least we were able to get some usage out of it again. We think it had something to do with the leather/glue/foam... Not sure.
Good luck with yours- sorry I cannot help. I will NEVER NEVER NEVER buy another VW again. :P :mad:
