Air in tires worn out?
After 4 years of happy driving, I noticed recently
that the ride in my car just wasn't what it used
to be. Realizing that I'd never changed the air in
my tires, I drove to a service station and put in
a completely fresh charge. It has really seemed to
help, but in checking my owner's manual, there is
no recommended interval for this service. Does
anybody know how often this should be done? It
sure is an easy and inexpensive way to keep that
"new car" feel.
"new car" feel.
A stylish decal is placed in you rear window so all your friends will know that you are as trendy as they are. For a slight extra charge they will also install a designer set of gold valve caps. What a deal.
Floridian
I still don't know how often to have this service done, but with pure nitrogen, I imagine that it lasts practically forever. The Starbucks people will probably know. Hopefully they will have one of those helpful decals for my windshield like the one I need to change my oil.
Sorry, couldn't resist
Is there a prize for the oddest thread? ;-)
Don't believe everything you read.
ESPECIALLY here, in this topic ;-)
Make sure to run it for awhile afterwards to to clear out the water from the system, make sure the tailpipe doesn't rust!
A modification is to add some soap to the water to do an extra good cleaning job. A high-quality expensive herbal soap will let your engine know that you really care.
This will help your engine's mileage tremendously--in fact, you will swear afterwards that it uses no gas at all!
dave
As far as the tires go, I received an even better tip for improving performance. My mentor was explaining how both air and pure nitrogen are too compressible to be an ideal filling material for auto tires. Air works well on lighter applications like bicycles, which is how it originally came to be used on cars, but the greater weight of modern cars requires something stronger than these relatively weak gasses to hold up the weight (especially under hard cornering, etc.). He explained how all the NASCAR and Formula 1 teams are filling their tires with water because it is less compressible than air so the tire holds it's shape under hard use. The added weight also really holds the tire down on the pavement so the traction is unbelievable. In the winter the benefits are even greater because the water freezes, so it's ability to hold it's shape is just that much better. (side-note to "Floridian:" sorry, but your tires may not freeze in Florida- you may want to experiment by adding firming compounds like jello or concrete) If you want your car to perform like it's on NASCAR, this is definitely the way to go!
Thank Goodness I have so many friends who are so smart about cars. Keep all these great tips coming! We finally have a topic that is really useful to the average gear-head.
Floridian
I DEFINATELY NOTICED THE DIFFERENCE IN MY CARS PERFORMANCE!!!!!
kes special equipment)This is not a practical soluton for the mass mototring public. The remedy is to keep the water in a liquid state.
F.L.O.P. has found the answer! By filling the "tyres" (British) or "Tars" ( American, Southern)with unpasteurized orange juice. The O. J. soon ferments,turns to alcohol and thus will not freeze. As a secondary benefit it was found that the organic components (seeds and pulp)of the juice act as a self-sealent material and will seal punctures up to .062" in diameter.
As son as F.L.O.P. gets permission from the Feds (A.T.F. guys)about the production of alcohol on such a massive scale they will be able to proceed. They are working on a suitable design "tax stamp" that will have to be affixed to all tires using this technology. We should be able to get "tanked-up" by this time next year. just goes to show that good old American know-how can solve ANY problem. Eat your hearts out japan & Korea the "good ole boyz" from the South have once again shown the world the way to go.
Floridian
For those of you who prefer the old fashioned style of driving, here's a tip to better lubricate your engine. Replace your motor oil with gasoline. Gas has a lower viscosity, and will workitself into all the tiny spaces in our engine, better lubricating it. So much better, in fact, I swear it will be the last oil change your car will ever need!
In cold weather, special care must be taken in defrosting the front and rear windshield and heating the interior of the car. This puts a great strain on the electrical system of your car. The blower and the rear defroster use a lot of power!!!
This cost effective solution will solve the problem: all you need is a garden hose, duct tape, a few T connectors, a utility knife and a drill.
The idea is to recuperate the heat from the vehicle's exhaust and use it to warm the car's interior. Cut a 10 foot section from the garden hose and duct-tape one end to the exhaust, making sure you have a good seal. Drill a hole in the floor pan of the vehicle and snake the other end of the garden hose into the passenger compartment. Using a T connector, it is now possible to split the hose into two feeds; one for the front windshield and one for the rear. Proper care must be taken: make sure all connections are seal properly with the duct tape! It is possible to run the hoses under the carpet to keep the OEM look of the vehicle. Additional hot feeds can be added to the basic system to deliver heat anywhere in the vehicle; use your imagination. For maximum efficiency, all windows must be rolled up.
He vacumed his datsun's 210 tires with a lab vacumn pump and filled them with Helium.
He claimed that one of the test results was that he got 10% gas mileage increase and it slowly decreased over a month period until it disappeared. He said that it took about $30.00 worth of helium to do this!.
But don't just use any water. It should be New York City tap water. Best in the country. And for you performance hounds, you can add my special Jello shock resistant tire-water adative. The extra slow bounce gives the tires better protection against pot holes.
And for real speed freaks, our racing water should be used. Consisting of NYC tap water plus Dawn dish washing liquid, this stuff really gives you the slip. And the bubbles, ahh!
So remember: Pot for every chicken and the gas for free!
Try it, it's fun!
A customer came in for an oil change with a old full size rwd car (can't remember for sure). While working on his car, the customer handed me a banana and requested that I stuff the banana in the car's differential!!! He told me it helped keep the differential from whining. I did my best to stuff the banana in through the diff's check plug opening. As a precaution, I wrote on the work order what he requested, in case something blew up on his car.
And to say that, as a lube tech, I only made minimum wage. With all the crap lube techs have to put up with, they should be making double!!!
Next time you go to a fast lube, pat84, make sure to give the lube tech a dollar tip. That'll just about double his hourly wage and ensure your car's safety.
PS Sorry about that last paragraph. I just get a little nostalgic sometimes.
It seems like pepper is all it's cracked up to be.
Us chefs want to know.
BTW, at least I got a nice tip for this.
Did he have any tye-dye curtains in the Bus? Dreadlocks? Smell of Pachouli oil? Wear sandals?
Or was he the bearded, pipe-smoking, tweed-jacket-with-elbow-patches professorial type?
I've gotta know....
