Overheating
hywyhywy Member Posts: 4
Hi Folks Help Please have a 93 JCW, Country, 4wd,
auto, 97K and cannot seem to figure out the over
heating mystery - have replaced thermostat, hoses,
flushed radiator, new antifreeze, radiator cap,
tune up, oil change -All the basics and still
overheats when I drive either in-town or freeway,
with or with out air on - been to three different
mechanics and replaced two sensors -still
overheating - seems like somethings pulling on the
engine and I have made sure it is not 4Wdrive
engaged -Any one have any expertise on this?
  • oilcan2oilcan2 Member Posts: 120
    Make sure there is not some other reason for
    overheating,if engine actually is "pulling" it
    sounds like this is causing problem,if not try
    looking into radiator and seeing if orifices
    are blocked,I had same problem once and I did
    what you did but rad. was still plugged up,I had
    to have rodded,the flushes we get at walmart
    do not always work.
