Chrysler Sebring Ignition Problem
My Sebring has about 75,000 miles on it and for some reason, it has a hard time going into park so that I can remove the key from the ignition...When I shift it into park it feels like it locks in but I can not turn the key off fully..Therefore, the oil light stays on and if left like that it drains the battery.....Can someone please shed some light on the problem??? Thanks!!!!
However, you indicated that you already tried that.
our model of cars have a hard time with the ignition keys, somtimes they just stop recognizing the key so just have a new one programed to it, also ask a mechanic about recall id# 28912.
also check your pump selenoid and your high and low air pressure.
goodluck, and let me know how it goes thedgenerate@hotmail.com my name is dan
Thank you for your suggestion. I am not sure if we have the same problem. I can insert my key and turn it to the start position and have the engine cranking over, but it won't start because of no gas or spark at the plugs. I did try hitting the key when it was in the ignition fairly hard with the palm of my hand and kept inward force on the key when trying to start the car, but still no success with the car actually starting. Please let me know if you were able to turn your key to the start position without hitting it or if you had to hit your key to drop the tumblers (I think that is what they are called) into place on your key so that you could then turn your key in the ignition to start your van.
I did have to hit my key in order to turn it. Thanks for the name of those things!!
http://answers.edmunds.com
After you post your question, you can check for responses by clicking the "my answers profile" link near the top of the page.
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
Just FYI I lost all dash lights and the mileage counter didnt come up.
Can someone help, I am new to a forum... Chrysler Sebring Convertible 2010 - Melb, Aust. I am using the remote key to open vehicle, I can hear the doors unlocking, but the driver side door isn't budging. I can open passenger side door, use everything in vehicle. drive vehicle (haven't driven out of street). but cannot open door. Any hints, clues as it is 1 month out of warranty!!
