Ford Edge Accelerator Surge?
in Ford
I'd like to start off that I'm not setting off an alarm or anything, but since I do auto claims for a major insurance company in Texas, I'm sending out this post because of a traumatic experience by one of our insureds. On 3-10-08 one of my insured's pulled into a parking space and just as she was to come to a stop, she claims her 07 Edge took off out of control with her foot on the brakes. She ended up striking a light pole and stopped back on the street she just pulled off of. I promised her that as part of my investigation into her claim was to see if any other Edge owners are having or have had the same experience.
The Ford service tech scanned the computers right after the tow truck dropped off the car from the scene. And of course no error codes were detected. The car has driven fine every time it has been moved from spot to spot at the body shop and service center. So unless there is a rash of other Edge owners experiencing an accelerator surge, this is either a very isolated occurrence or driver error.
Please respond if you know of any other incidents similar to this one.
Dennis
Dennis
Accelerators can stick, but properly functioning brakes will ALWAYS stop the vehicle no matter how powerful the engine or how high it's revving. Brakes can also fail.
But whenever a person reports that the car accelerated on its own and could not be stopped by the brakes, and the brakes are inspected and found to be working fine after the accident - it's driver error.
This is most appreciated to see your post as the lady we insure is very credible and did crash as a result of her alleged accelerator surge :sick: . Unfortunately there will have to more incidents posted in the near future to back up these claims. As stated already, the car will have to tell us what happened and ours did not.
I too was accussed of "driver error." That was absolutely not the case. I was fortunate that my Ford dealership finally agreed to replace the entire brake system. Eventually I was contacted by the NHTSA requesting information as to whether my issue was resolved and if so how. I was told that seven other incidents had been reported.
Once you adjusted your foot to stomp on the brake then you also adjusted your foot over onto the brake peddle and off of the gas.
If you were wearing any kind of sandal or flip flop, I would bet money that this is what happened. People don't realize how wide sandals and flip flops are compared to regular shoes.
I called our garage and ask the manager if he knew of any recalls on Ford pick ups because of this problem. He said none that he was aware of but that I was the second person in the yard to have this complaint with Ford P/U's.
I believe what actually happened was that I was inadvertently pressing both pedals at the same time. My personal vehicle is a Chevy P/U, so I am use to the 'pedal spread' being much wider. I have never had this problem in my Chevy.
I searched on line and see a pattern since at least 2002 where Ford pedals have been placed too close together, even causing recalls in some models. I guess the designers can not learn from past mistakes.
There will be accidents because of this problem and there will be law suits.
hesitation abolition wwest -dfg
Try left-foot braking. It's not for everyone ... some lack the discipline & coordination to do it properly. If you master it, you'll be a safer, smoother driver.
Slow-speed maneuvering is more precise ... parking is smoother & less likely to collide with something.
When I read of an elderly (sometimes not elderly) driver mistaking the gas pedal for the brake, mowing down pedestrians, crashing into a building, speeding uncontrollably backward out of their driveway, I have to believe that in all but a few cases, they were right-foot brakers.
I accept any rational flak.
Judging by the number of people you see driving along (and speeding up), with their brake lights on the whole time, there may be more left foot brakers out there than you think. But if you are standing on the brakes, that'll override a foot on the gas.
Now, if the pedals are too close to each other, that does cause problems.
Only if it's a RWD, or with FWD you're already at a stop, or almost so.
That's true. You should have stayed on the road.
Mine are 10.5" D and I have the same problem even though I keep practicing placing my braking foot well to the left.
I consider "people you see driving along (and speeding up), with their brake lights on the whole time" a false argument against left-foot braking. The people doing this don't know how to left-foot brake, and shouldn't be doing it.
If citing an example of someone not knowing how to do something as an
argument for others not to do it, then none of us should be driving manual transmission cars ... because so many people don't know how to drive M-T cars.
Please take an objective look at the issue. Consider: A) Not everyone is capable of proper left-foot braking.
I'll bet a lot of money that none of the pedal-position "accidents" discussed here involved left-foot brakers. And that none of them would have occurred had they been skilled left-foot brakers.
For more than two decades I've owned two cars ... one with manual transmission, one with automatic. I now have a Mazda 3i manual & an Edge Limited. I can hop out of one & into the other with no problems. It just takes an open mind, commitment, and practice.
Pardon the pun, but my brain just automatically changes gear when I go from AT to MT to AT.
I do remember, just once, when driving MT car I wanted to slow & attempted to do it with the clutch. A bit of a thrill but no harm, no damage. That mistake is firmly embedded in my brain.
dealer) I now have a 2011 Escape with another trans. (but not as bad as the Fusion) that just does not shift properly(flares and revs. too much). The engine groans and does not seem to want to go (it's a 4 cyl. with 6 sp. auto). I only know one person with a new Edge but he would rather cut his arms off then say anything bad about a Ford so I need honest feed back. I believe that the Asian 6sp. transmissions are problematic but Ford will NEVER admit it and God knows they have had plenty of time to do it. Please be forthcoming with your reviews. Thanks
Only complaint is the My touch & Nav system. The stylists & interface designers must have locked engineers and drivers out of the room when they released the package. IMO Its AWFUL.
But, a totally new O/S is supposed to be on its way in a flash drive. From what I've read, they've done it right this time.
Allen: Is there a forum that has feedback from owners that have the upgrade?
Side story - my daughter totaled her 2012 Focus in November when she rear ended another car (her fault but everyone one is ok). We went looking for a new one and local dealer had one on the lot that was perfect. It was a SEL hatchback with only the MFT package. It only had 120 miles. Turns out an elderly couple bought it and traded it in one week later because they didn't like the MFT touchscreen. Of course they had never even opened the owners manual or tried to learn it. I guess we both won - we got a good deal on the Focus and they got a non-mft equipped vehicle.
I'll probably go with the download.
Not having the Nav. is no loss. My wife & I prefer my Garmin 1490.
P0720
Insufficient input from Output Shaft Speed sensor
Detailed Description
The output shaft speed sensor inputs a signal to the PCM, based on the speed of the output shaft of the transmission. The PCM compares this signal with the signal of the VSS or TCSS and determines correct tire size and axle gear ratio.
Possible causes :-
OSS sensor circuit short to GND.
OSS sensor circuit short to PWR.
OSS sensor circuit open.
Damaged OSS sensor.
Damaged PCM.
Diagnostic Aids
Verify sensor signal output varies with vehicle speed.
Output Shaft Speed (OSS) Sensor
The output shaft speed (OSS) sensor is a magnetic pickup that provides transmission output shaft rotation speed information to the powertrain control module.
The output shaft speed (OSS) sensor is mounted externally on the top of the transmission case. The PCM uses the output shaft speed (OSS) sensor signal to help determine electronic pressure control (EPC) pressure, shift scheduling and torque converter clutch (TCC) operation.
