Chevy Blazer Oil Pressure problem
Ok I had to change the oil filter on my 02 Chevy Extreme Blazer 4.3L V6, because It was shooting out oil around the seal which had broken in 2. I replaced it with an AC Delco filter and tightned it to Spec, Filled it back up with oil, and then statred it. The oil pressure went immediatly all the way up to spike the gauge in the dash and then blew the O ring right out of the side of the filter and shot another 2 quarts of oil on the floor. We already checked the radiator and the lines going to and from it. Any ideas are welcome please help
Thank you in advance
Familysize75
Familysize75
Oil pressure indication recently became erratic. Up, down not related to RPM. This was the replacement of the original sensor, which failed last April. Changed sensor again. Pressure stable at 40 lbs. for about 5 days [approx. 150 miles ]
Last night engine started normally and drove about one mile. Suddenly pressure went to 0, digital warning flashed, check engine light came on and engine died. Sensor has a fuel pump cut out switch. Today I, found the oil level full. [ about 600 miles since change & new FRAM filter ] I removed sensor, checked with air pressure and found it to be OK both pressure and cut out. Observed there was very little if any oil on sensor and was not to the top of the open port. With the sensor removed, turned engine with starter. No oil came out of open port.[ may not have turned it long enough. was sitting over night ] I then added a small amount of oil into tho sensor port. It took very little to over flow. Again turned the engine. Bad idea. Blew oil all over the engine which ,by the way, I had just cleaned. Re installed the sensor and started the engine. Started instantly with 40 lbs. oil pressure
My questions are; Since this is the second sensor change this year, am I buying defective sensors? [Auto Zone Duralast PS168 ]
Could I have temporarily cleared the problem by putting air into the sensor or oil in the port?
Do I have an oil pump about to die? Now at 176,000+ miles but running great until now.
What else can I check to determine the cause? It seems totally unreliable as is.
There is an unused port above the oil filter. If I install a mechanical gauge at this point in the loop, will it read correctly?
Thanks for any suggestions
GM Part# 15547452 @ $154.00. Hope I could help I own a 2DR 92 4x4 s-blazer & 4DR 94 4x4 s-blazer.
Was the old o-ring from prev. filter still on engine when new filter was replaced?
The oil pressure guage only spiked do to oil filter blowing off.
Try pulling coil wire when you change oil filter on start up to build pressure up in the lines. check for leaks before it actually starts.
Are you adding oil to the filter before screwing it onto engine?
Sometimes you can overfill. Try this and see if this helps.
Good luck,
Jim
Can any one be a little more specific as to where I might find the ECU?
Can any one explain why the AC control even goes through the ECU?
I prefer to replace the ECU, if necessary, but what would happen if I bypassed it and went directly to the clutch?
Thanks :sick:
Never mind, I found the ECU /ECM. It was not the problem but by tracing the grounded wire back, found the problem in a connector that does not show in the manual. All systems are now GO.
For any one interested, the ECU / ECM is installed [ hidden ] behind the glove box. In this model the box appears to be a rigid part of the entire dash. Below the dash there is a shelf that runs from the passenger side kick panel just beyond the 4X4 shift lever. Even with all the screws out, it is difficult to remove. The kick panel comes out easily. A single screw, now visible, secures the mounting bracket. With that screw out, the entire unit slides down from it's hiding place. The cable harness is rather short and tangled so a little care should be taken. I had to remove the two small plugs on the inboard side before it was free.
What did you find that was blowing the fuse?
This sort of issue came up in a general discussion page elsewhere on this site. The question was, why are there never problems, in this forum, with the ECM. As I remember, the opinion was that the trouble is almost always in the peripheral circuit and the ECM is so well hidden that a stupid mechanic, such as myself, can't damage it. Well, I tried really hard.
Regarding ECM failure, they are very rare. As any failure can cripple the car, a lot of attention is paid to these, and typically they are built using MIL-SPEC parts. Higher temp ratings, greater voltage tolerance, etc. The second generation S series ECM has a heat sink mounted to it. I have been told that many of the ECM that are replaced will test good. Either a harness problem, or bad contact in the mating connector. In a manufacturing environment, these are very easy to test and confirm good before installation.
I need to correct myself on accessing the ECM. It was not the shelf under the dash but the kick panel below that was removed. Still a miserable job, out and back in. Also, the other wire in the connector was not circuit ground. Still more reason to look further down the line. Intermittent problems can make you crazy.
How many miles on the engine?
Did you find out what your problem was?
Her also seem to just stop for no reason. It will stumble and die. A day later it's fine again like nothing has happened.
It seam to come and go. Sometimes she can only drive for like 5min before it start to stumble and want to die. Others it will be fine for a week.
