2000 Yukon Oscillation
My 2000 Yukon is totally stock. At 1500 rpm, any gear, there is an oscillation that sounds like sheet metal vibrating. The sound emanates from the front half of the vehicle. I call it an oscillation because there is only the sound, not the feel of something moving.
Any ideas?
Pete O'Neill
Any ideas?
Pete O'Neill
I am guessing that it is sheet metal problem and that the metal is under stress from air pressure when the vehicle is moving at highway speeds and therefore not resonant.
Problem 1 - The breaks squeak. The first time I took it to the dealer (where I bought it). The said it was metal content in pads. Second time a different mechanic said it was glazing. They said they fixed it but I still have the problem.
Problem 2 - There is a noise (squeaking noise) that comes from the front of the truck when I hit the gas. When I release the gas the noise stops. The noise comes and goes.
Two noises never happen at the same time. For a $43,000 vehicle I am going crazy. If anyone has any advice or similar problems please let me know.
Pat/Roving Host
