Isuzu Off Roading/Trail Reports
-mike
Brian
I'm thinking of planning a Pine Barrens Run sometime in June or July, would you be up for it?
-mike
Yes, depending on the date, the summer gets very busy with trips and picnic's, etc. A friend of mine just upgraded from a Montero to a Trooper and he is interested in hitting the trail too. The pine barrens is kind of vanilla, and I am gun shy of the water.
I am "jones'in" for some offroading. What other options are there in the tri-state region? I like the idea of having a destination, not just cruising around trails.
It's a haul, but well worth it. It's an experience. Camping, and difficult yet easy on your truck trails.
Other than PB and Paragon not much else in the tristate I know of.
-mike
http://community.webshots.com/user/emiura
PB would be OK. I am going to look for some forest information to see if I can find anything else too.
I did some tire damage there too, I pulled back a flap of tread big enough to put my hand into, but it laid flat and I did not notice it till much later. The tire held air just fine, maybe because the original 1984 Trooper tires came with inner tubes.
