2000 Olds Alero under carriage wind deflector problems
The dealer advises me that this is a common problem with the Alero model. The plastic under carriage wind deflectors get damaged all the time when drivers pull up against a curb or a snow bank. Mine
became partially loose and broke away. I think this is a possible design flaw because it shouldn't happen under normal use!
I would like to know if other Alero owners have had similar experiences and if the problem was remedied by the Dealer or the Company?
I'm going to ask the service dept if it would have adverse effects on the car to remove that deflector.
Will keep you posted on the results.
and is on "national backorder"
You can get over it. Besides, it's just black plastic....the scrapes aren't noticeable, like on some other cars with painted pieces. The great news is, the interior water leaks, warping brake rotors, inept dealer service, and plunging resale value (not that it was ever good) will take your mind off that scraping noise. Cheer up!
since it is so short, and also straight vertical, and probably bends back a little as the car speeds up. The only thing I can think of is that it's purpose is to scrape and make noise to alert the driver to stop and back up, in order to prevent damage to the oil pan and suspension components.
