Oil Change Negligence - Is my car ruined?
Took my wife's car to local repair shop on 1/2 and on 1/3 the filter fell off, oil came out of car, car started smoking and stopped running. Wife called tow truck and car was towed to original repair shop that incorrectly installed oil filter. With new filter and oil the car is running but I hear a tapping/knocking noise that was not there before. Repair shop says that car is fine but I am worried that engine has damage.
What is my recourse? What is the shops responsibility and how do I get them to take responsibility? Planned to keep the car for 3 to 6 more years and am worried about what running with low/no oil did to engine.
Does anyone know what to do?
FWIW, I did something that was very dumb once. When my car was having its oil changed at a quicky joint (I was sitting in it), I started the engine in a moment of extreme brain fade. I thought they had told me to start it. The engine was only running for a few seconds so no serious damage was done. But the shop did make me sign the receipt stating I was an idiot.
ed
was able to remove pan bolt, was ultra tight. Went to local Ford dealer and bought new bolt.
I agree that they owe you an engine.
If the oil filter came off, then the engine bearings became oil starved and it only takes a few minutes to peel the bearing material.You've gotten good advice from everyone except adc100.
adc100,
I suppose that you have never done something like that? Everyone starts learning at one point, no one starts life knowing everything. I regularly deal with truck drivers who on several occasions have had this happen and they have a big red light and a buzzer and neither one caught their attention and bearing failure always occurs, then the man with zero patience gets to tear down a big diesel.
NO - if the filter came off and the engine was run any length of time, it will not be allright.
Since it is making a knocking noise, then there are sever possibilities as to what has actually failed, but if one thing has failed (which it clearly has), then the rest is not far behind.
And just in case anyone was wondering, the car was driven for less than 1 1/2 miles and not over 35mph before the damage was done.
Unless they're going to send your engine out to an automotive machine shop for the rebuild, I'd lean toward the low mileage used one. A lot of components can be scuffed in 1 1/2 miles, despite what the snake oil infomercials would like you to believe.
Alcan, I've been overloaded. Too many things going at one time. You know how that goes.
LOL!
Later
Brad
Sometimes it worked, sometime it didn't.
Marvel Mystery Oil works best for that purpose, but you have to remember that sometimes the sludge is better left alone if it isn't causing a problem.
If you disturb it and flush it into the crankcase, it has a nasty habit of pluggin up the oil pump pickup tube, and that isn't a good thing.
I was in front of the car looking down, when I saw oil splash marks on the garage floor. (The car was just outside the garage.) When I looked under the hood, there was oil everywhere. I immediately shut off the engine, but since I had to add about 3 1/3 quarts (the oil capacity is only 3.6 quarts), I am wondering if any damage was done. Once I got the mess cleaned up and added more oil, the car seemed to run fine.
As far as using synthetic oil to flush, probably not a good idea especially if there is a lot of sludge. As the synthetic cleans (and it will, synthetics are great at keeping the crank case clean)the oil can become contaminated to the point that the exhaust may have a lot of smoke, not good for the engine.
I agree that if the engine has a lot of sludge just leave it. You'll probably just make matters worse.
The repair shop that did the oil change paid for all cost of replacing engine. They also put in new battery at no charge (i did not ask for the battery). The business said to bring the car back at 1000 miles for oil change and filter (no cost). Also will top off the AC when it gets warmer.
The car is running very well. I am very happy that the shop backed it's work and took care of it's mistake. There are some good people out there.
The cause of the loss of oil and filter that started it all, an incorrect filter was installed which fell off.
