brake system flush
For a camry v6le, typically when is this needed?
when did you folks do it?
Dealer informed me that my car needed this.
i have about 62k miles, 1995 camryv6le.
I dont get any sounds or any other indications.
I guess there is no way for me to verify
if the brake system needs a flush, or is there?
thank you
Steve
thank you
Steve
Couple of questions -- I've done it before on my old Volvo without ABS; it was easy, but is it more complicated with antilock brakes?
And when bleeding the system on the Camry, should I proceed as follows: left rear, right front, right rear, then left front (it has a split diagonal system)?
I have more experience on domestic ABS systems, and on a few of them a scan tool is required during bleeding to cycle the ABS solenoids. You might want to check with a Toyota dealer about that. If not, it's the same as bleeding any system. Use the same sequence as the Volvo for flushing your diagonal split system. I'd recommend using a turkey baster or big syringe to remove as much of the old fluid from the reservoir as possible before adding new, then bleed each corner until clean fluid comes out. Did my neighbor's '97 Caravan yesterday. It was like pumping black coffee out.
BTW, we'd better take this to the other "Brake Fluid Flushing" topic area before our host Pat comes and shoos us out. :-)
bnormann
Maintenance & Repair Message Board
