Visitor Agreement.
Best Regards,
Shipo
Best Regards,
Shipo
It seems that the 3-speed 4 cylinder configuration may have less transmission reliability problems and wonder if anyone has inputs on that.
Older four cylinder versions came with a hydraulic 3-speed automatic that was of the same family as the A413. These were exceptionally reliable transmissions. In fact any problems at all were almost always associated with the differential, most notably the output bearings and/or seals on the drive shafts.
The bad years for Chrysler mini-van transmissions have past. The newer versions of the electronic 4-speed fully adaptive transmissions are far more reliable than the original A604 Ultradrive. The biggest area of trouble, the solenoid shift packs and associated electrical wiring, has long since been resolved. Another problem often not mentioned is the fact that a lot of routine maintenance has been done on these transmissions using the incorrect transmission fluid. In my area, there are several oil lube places being sued for using Dexron-Mercon in full flush scenarios, then the transmission "fails" within 5-8 thousand miles.
Our national fleet has contained Chrysler mini-vans and other makes for years. Prior to '96 the Chrysler did have more trouble, but in recent years our Ford Windstars have been far worse.
There's something else to consider. Mini-vans as a class are far more likely to be under maintenanced and overloaded by their users. The fact that Chrysler has had a volumous model and enjoys a majority of the market has helped in part to this problem.
I wouldn't have a problem purchasing a '01 and up Chrysler mini-van.
Dusty
More reliable than the Windstar seems like faint praise. Roy
I've always wondered why Chrysler's trannies need all these fussy maintenance above and beyond what is prescribed in the owner's manual (like why do I need to put in a aux cooler for normal use, fluid change every year etc.). With all the rebates etc. though, Chrysler is a good value and if one can get loaner coverages with extended warranty etc., I would hope one can get 7 years/ 100K miles of useful life from Chrysler and Dodge minivans in the -:worst case:-scenario.
A few times since then, when we start the van, all of the gear shift indicators light up. The van went in for a leak in the power steering lines in February and I asked them to check this too. They said there were no codes.
Yesterday I was driving and the road was blocked so I had to back up. Well the thing would not go into reverse. I am wondering if there was damage caused by low fluid. Any info would be greatly appreciated. There are less than 4000 km on the van and we are ready to park it and refuse to make payments. Thanks
We thought we would be safe buying a brand new van.
Roy, according to the Consumer Reports 2004 Buying Guide, Caravan is rated "worse than average" '00, "better than average" '01, "much better than average '02." Keep in mind that these ratings are based on owners reports of their subjective opinion of what a "serious" problem is. The fact is that there have been no significant changes in the Chrysler FWD mini-van transmissions since 2000, yet the results vary. There is obviously a statistical dynamic present unrelated to design. Let me also suggest that because of "popular opinion," on Chrysler transmissions, non-fleet owners are more likely to view any problem related to the transmission as "serious" or worth reporting.
>>>dustyk's company I think uses only Chryslers and Fords for whatever reason. But, Chrysler will have a hard time convincing anyone that they've fixed their trannies (May be a lifetime warranty would help?).<<<
We currently are running Chryslers, Fords, and GMs. Fleet buyers are usually good test beds for vehicle designs since accumulated mileage is above average and drivers are not stake-holders in the vehicle's ownership. Thus, maintenance neglect or abuse is far more prevalent. Chrysler minivans for us have given us no more transmission problems than GM versions, and much better than Windstar.
>>>I've always wondered why Chrysler's trannies need all these fussy maintenance above and beyond what is prescribed in the owner's manual (like why do I need to put in a aux cooler for normal use, fluid change every year etc.).<<<
I wouldn't consider an aux. cooler as part of maintenance and none of our minivans from either Chrysler, Ford or GM have them. As far as maintenance goes, Chrysler versions are no different than Ford or GM. In fact, our fleet contract calls for the same level of automatic transmission service for all three (30,000 miles).
Dusty
The best preventative medicine is scheduled service using recommended materials.
I think your dealer was trying to be kind to you. The price they gave you sounds more like ATF+4 which is more expensive. As long as the ATF+3 is equivalent and certified there should be nothing wrong with it and fully compatible in your transmission.
Best regards,
Dusty
By the way, the manufacturers get around this by saying that other types of fluids can be used to top up etc, and then put in a caveat that it may cause rough shifting etc.
Any advise on towing with this thing? One issue I have is with the rear suspension. It seems so soft anyway - I'm not sure loading it up with a couple hundred pounds of tounge weight will be a good thing! Also, there is no tow package on this one - so I assume I have no cooler. Can one be installed? Are they expensive?
I would appreciate any feedback.
There may be a lawsuit, but if so it is a civil matter and not a suit brought by the Federal Trade Commission. A search of FTC records indicates that the last legal action taken against Chrysler was in January of 1999. The FTC website lists no current litigation proceedings against Daimler-Chrysler. Neither are there any Daimler-Chrysler hits in Adjudicative Proceedings, Applications & Petitions, FTC Orders, or Advocacy Filings.
( http://www.ftc.gov/ftc/formal.htm )
According to my company's legal counsel, this more than likely means that the Independent Lubricant Manufacturers Association (ILMA) letter of complaint dated 11 November 2003 was not considered actionable by the FTC.
The ILMA's opinion of ATF+4 as a violation of the Magnuson-Moss Act is self motivated and represents an extremely narrow interpretation of the law. If a compound, fluid, or other substance is an integral part of a design, then the required use of that material to maintain design performance or warranty is not a violation of the Act. (If the Act was construed that narrowly, my company would be out of business from the impact of litigation alone.)
Since Chrysler still specifies ATF+3 for older transmissions built when that ATF was current, and Chrysler recommends ATF+4 for those, but does not stipulate its use, consumers may still continue to use ATF+3 in those versions without any threat to warranty coverage. In addition, ATF+3 is currently manufacturered by several independent lubricant manufacturers with license from Daimler-Chrysler.
Keep in mind that lubricant manufacturer's formulations themselves are protected by US patent laws. In this case the ILMA might be shooting their members in the foot!
Dusty
While Chrysler may not have been the first to bring electronic technologies to automatic transmissions, they most certainly have been the most aggressive. In the mid-'80s they introduced the first fully electronic and adaptive automatic transmission, the A604. While some view the A604 has a disaster because of several problem areas, in truth the design itself is solid. In fact, almost all of Chrysler's automatic designs today use the same basic power delivery architechure as the lengendary A727, one of the best transmissions ever built.
When Chrysler began building part and full electronic transmissions, many in the independent transmission repair business saw this as an attack against them, since specialized diagnostic tools were required that weren't available to their industry at the time. Conventional hydraulic designs were easier to work on and troubleshoot and most independent shops were already set-up to do this type of work.
Many in the independent transmission repair industry railed against Chrysler products and capitalized on earlier problems to take advantage of customer ignorance. It was fairly easy to instill fear through myth-building by the constant repeating of stories of Chrysler automatic problems. Since independents knew they had the advantage of belief that dealer service was always more costly and less reliable, it was easy for a customer with a Chrysler electronic automatic believing that it was going to cost $3-5K to fix. And many did.
Without knowing how your independent shop determined a seal problem with your '99, I think it is worthy of suspicion that they may see a way to make an easy $1500. For the moment without knowing anything else, I would trust the Chrysler dealer. I will tell you that in my opinion with a Chrysler mini-van you are much more likely to have a problem with the AWD than you will with the "T" series automatic.
Regarding the Dexron-Mercon that was put in, get it out ASAP. I would recommend a filter change and complete flush using ATF+3 at minimum, ATF+4 if you want to flip for the extra dollars.
The $150 is not a bad price if it's a complete flush. It will be inconvenient if not difficult to do a complete flush by yourself without the correct equipment. You will have to open the line from the transmission cooler to allow the old fluid to pump itself out and will need something to capture 18-22 quarts while the engine is running. The bigger problem is controlling the input flow of fresh new fluid. You can't simply hang a +20 quart container of ATF above the level of the transmission. Gravity will overfill the transmission and cause aeration, a particularly serious condition for automatic transmissions.
I've seen this attempted by folks without the type of equipment used by flush shops and its a messy and wastefull process. My advice is to pay the $150.
Sorry for the lengthly reply. I hope it helps.
Best of luck.
Dusty
Greetings; Hope all well with you and yours. I don"t know what to say. No, I know, thank you, and I really thank you for the mention about knowing a bit of history. I WOULD SURE LIKE TO LEARN SOME MORE ABOUT THAT HISTORY. I was wondering though about the Amsoil Transmission Fluid. It is named 100% SYNTHETIC UNIVERSAL AUTOMATIC TRANSMISSION FLUID and sells for $8/QT. say can be used in apps. req. DEX II, III, MER., MER V, ATF+ THRU ATF+4, and a few more. thanks, TimC P.S. Am going to call Dealer Today or tomorrow will wait to see if you recommend the Amsoil,
Thanks again.
Doug
ATF+3 & 4 is slightly more viscous and contains stabilized friction modifiers. It also contains a considerable amount more antioxidants than Dexron, has a 22 F (ATF+3) and 33 F (ATF+4) lower pour-point. Both have a wider operating temperature range. ATF+4 is semi-synthetic. Neither the ATF+3 or 4 have a permanent dye, however. Color should not be used to judge the effects of dirt or oxidation.
By the way, one of our local transmission shops here use ATF+3 in Ford trucks to eliminate torque converter shudder.
Best regards,
Dusty
I am glad no one else on this board is having these problems. I am back to driving a 10 year old vehicle that I feel safer driving since I know it is not going to leave me stranded. I bought auto club membership and I have a cell phone.
Good luck to everyone with your Caravan.
I have the opportunity to buy a 1998 Dodge Grand Caravan with AWD and 36,000miles. The mileage is valid. According to the owner, he has never had any transmission problems. Price seems fair according to Kelly Blue book, but after reading all the messages, I am scared to buy it. What should I know before buying this van? Thank you.
www.allpar.com has some good tranny advice also.
Will be getting my new Caravan in two days!
Don't forget the Honda Odessey tranny problems and the Toyota sludge fiasco. They all have problems.
Running a Carfax may be worth it, but it sounds pretty cherry with those miles. And having a mechanic look it over should expose any obvious major problems.
I bought a '97 wagon last April with 34,000 miles on it. But I knew the seller very well.
They are out there, I'll bet especially in Florida.
With that in mind, and after a combined seven years and 100,000 miles on our two 3.8 vans (our 1998 has 82K and our 2003 has 20K), and having driven a number of rental DC vans with lesser motors, a couple of possible explanations have occurred to me.
1) Could it be that the transmission has a problem with frequent excursions into the higher RPM range? I ask this because whenever I drive/ride in a van with the 3.3 or the 3.0, I am always surprised at how hard the engines have to be pushed to achieve decent acceleration compared to the 3.8.
2) Could it be that the transmissions mated to the 3.8 mill are in some way beefier than those in the other vans?
3) Could it be a combination of the two?
Do any of you have any in site that might either validate or invalidate one or both of my suppositions?
An interesting side note; in our current neighborhood, there are three Odyssey vans and our two Grand Caravans. Within that population of five vans there have been two transmission failures, none of them ours. I guess any manufacturer can have a problem with their automatic gearboxes. Even still, it seem that the Oddy owners look sort of askance at our "unreliable" Dodges, even though the only unscheduled failure for said Dodges was a battery on our 1998 after 50K miles. Go figure.
Best Regards,
Shipo
When it comes to mini-vans my belief is that they are used by their owners closer to or beyond the designed service limits yet maintained like cars, which translates to not enough maintenance. Dexron in Chrysler mini-vans is a far more common than most people realize. I've seen many more Chrysler FWD automatics go to 150,000 miles and more without ANY problems or failures. But the large portion of them were maintained correctly.
Change the filter and AT fluid on a scheduled basis and I think you'll find that the failure rate (ie: rebuild rate) will be less that on a Toyota or Honda.
Best regards,
Dusty
I think your 2000 was designed around ATF+3, which is still available and about $1 cheaper a quart than ATF+4. I would use the ATF+4 if it were my car.
Best regards,
Dusty
"Change the filter and AT fluid on a scheduled basis and I think you'll find that the failure rate (ie: rebuild rate) will be less that on a Toyota or Honda."
You really believe this dustyk?. IMO, hell would freeze over if that's the case.
