-June 2024 Special Lease Deals-
Chevy Silverado/GMC Sierra's w 8100/Allison
The paint strainers will catch all the little chunks that are left in the oil....and if left in....can break it down kinda and give it a terrible taste as time goes on..
Peanut oil gets the hottest....transfers less tatse and is supposed to be the best for ya?
Good Luck
- Tim
2700 mile round trip over Thanksgiving from central IA to VT via Port Huron, Toronto, Cornwall to Burlington w/8100/Ali/3.73 LT excab 4x4 average 12.09 - 70 to 75 for most of the time.
Best leg 13.5 -
Longest leg from Port Huron to Cornwall between fuel stops 493.4 mi mpg 12.18
Love that 38gal Aux. Tank. You DON'T buy gas in Canada!!!
75v
Kyle
-Eric
It's true that as altitude is gained, increasingly smaller gulps of air are in taken which requires ever less amounts of fuel to maintain proper mixture ratio - less fuel consumed. But for any given RPM, because the volume of air/fuel mixture decreases, so does power. And to maintain a constant speed as altitude increases, say 65 MPH, only one thing can result with a normally aspirated engine: opening the throttle, resulting in increased fuel consumption. So, all this seems a practical wash, no loss, no gain. What provided an unwitting hint was 75v's mention of "flight levels". It's well known that most aircraft perform better at higher altitudes, not because of better engine as much as less parasitic drag. In looking into this I found that air is approx. 1/3 less dense at 10,000' than at sea level. 33%!! Although the truck only reached that altitude twice, briefly, most of that leg was from 5 to 8 thousand. It's also significant to note that on the previous leg at lower altitudes the average was 13.2 MPG. So initially, on the Kingman-Durango leg, MPG was probably in the 13's, maybe more, which means to get a 16.1 average it got well beyond that at altitude.
So, it wasn't engine performance that improved, but vehicle performance due to less drag. I can think of no other answer than that except for previous speculation about faulty inputs. Probably wrong.
Ahh, I feel better now. Thanks.
-David
Still looking for that oil filter with an anti-drain back valve. Any help much appreciated.
Comparing a truck to an airplane,what a stretch.LOL
-David
The other thing is that you probably don't travel as fast, and that can have a bigger effect on those drag numbers than the air density. Form drag (the part that comes from pushing the shape through the air, as opposed to induced drag, which comes from making lift, and isn't of much concern to truck drivers) increases as the square of airspeed, at least at the relatively small Mach numbers that we experience in trucks, but it is lineally related to air density. (At the same speed, 1/3 less air drag at 10,000 feet than at sea level. At 57 mph only 1/2 the drag of 80 mph (both speeds at same elevation). Combine the two effects and you can find yourself overcoming only 1/3 of the wind resistance at 10,000 feet and 57 mph that you had at sea level and 80 mph. The only down side is that, unless you have a turbo, you only have 2/3 the horsepower to do it with, and the rolling resistance and mass of the vehicle haven't improved at all, so hill climbing and acceleration are not like at sea level.
-David
I plan to drive it to work 16 miles one way 5 days per week. I will be pulling a two horse trailer (approx 3,700 lbs loaded) and a slide in camper (Low profile, light weight crank up style -1500 - 1700 lbs there). I will only be towing about 15 - 20 times per year during the summer months (May through October), distances of 22 to 80 miles depending on destination. I know this is alot of truck for these requirements, but I plan to keep it for awhile - at least until it's paid for :>)...and my longterm goal is to go with a gooseneck trailer in about 3-4 years.
I see alot of stuff out there on this truck, but short of sifting through thousands of posts I would like to ask the readers about a couple of things.
What's the weird metal thing that sticks out from between the seat bottom and back of the captains chair that looks like it poked out of the material by mistake? Is it normal?
Other than the cold knock and the oil consumption are there any other things I should be on the lookout for based on my driving habits?
I'd like to replace the tires, any recommendations?
This will be the first vehicle I've owned which is older than a 1992. I've had an 83 Suburban and 88 Suburban and a little car-1992 Eagle Summit. I'm a bit confused about the synthetic oils / rear axle lubricants and pink antifreeze. I know I can read about these things in the owners manual, however the one in the truck is written in French (truck was built in Canada). The dealer said he would get me an english owners manual, but I don't know how quickly that will arrive - I've heard it takes about 3 months to get one. Can anyone provide basic information on maintainence of the lubricants?
Any information you provide will be greatly appreciated. Thanks for taking the time to read this over. Looking forward to your responses!
255/85/16's look good on these trucks..
Good luck
- Tim
What have you guys that have the allison been doing? any comments and suggestions would be appreciated, thanks
kyle
-Eric
Bob
To kg11 - This truck has a maple leaf sticker on the door panel - 1st registration issue with 0 miles was at Quebec Motor Vehicle Department dated 3/2/2001. Sure looks to me like it was built in Canada, especially with all them funny french words in the owner's manual (Smile) I've heard that they do some initial frame assembly in Canada and then final drive train assembly in Michigan but I can't attest to that as fact. Thanks for the tip on the tranny. Two test drives in the mountains didn't show any sign of problem there. I was quite impressed with the transmission actually.
4X4man - Any recommendation on the mfr. of "good oil, good gas"? I've used Mobil Gas in all my vehicles, plan to continue. As far as oil goes, what do these trucks come off the line with? Is it possible to switch to syn oil if the truck hasn't had it before? (I can see everyone laughing at that question now - Come on guys, I'm just a lady trying to learn about her new truck). How'd you get rid of the engine knock? I listened for it on my 2nd test drive and didn't hear anything but the outside temp wasn't that cold at the time. On my first test drive I started it up a couple of times while it was warm and didn't notice anything unusal then either. I guess I'll just keep my fingers crossed and hope for the best.
Thanks for all your replies.
On the oil, I put synthetic in at 3,000 miles. That is good oil IMHO...I am using Mobil 1 5w-30 but there are a lot of other good synthetic oils on the market.
If/when you switch to synthetic there is no need to flush the engine as the dino and synthetic are compatible. I have heard that it isn't wise to switch back and forth between synthetic and dino oil. So if you are going to go synthetic, stay with it for the rest of your ownership.
Hope this helps!
Bob
All you people who have to cope with the white stuff, which type do you prefer ?
Just a 'flatlander' in SOCAL who needs to make a decision by 12/26/01.
Thanks in advance for your opinions.
omcniff@shinbiro.com
-- Don
Bob
Driving home from Crested Butte, up over Monarch Pass, US285, Kenosha Pass, Crow Hill above Fairplay, passed scores of 4x4's in the ditch, up the hill on C470 from Santa Fe to University, got it completely sideways, saved it...kept going all the way to my driveway. And THERE...THERE I could not get up it. Had to put chains on....Grrrr!!
Today, with mag chloride, A/T radials, I may never need 4wd. Still glad to have it though, if only to get up the driveway.
-- Don
BTW: I've had the pleasure(?) of driving Fox chassis Fords in snow/ice. Sincere congratulations on making it as far as your driveway! I stayed home that day.
Forgot about the May storm last year (thought it was earlier, but they all go so fast don't they??). Arapahoe road was full of 2wd trucks and vans stuck all over the place at 5:30am. They should've stayed home...come to think of it, I should've to. Luckily I had my 97 4x4 half ton at the time and made it in to work ok.
Bob
Drove a 2wd 97 sonoma at the time too. Got it stuck plenty of times
8.1l, allison, 4.10/locker rear, all in town driving. I also don't know if the tank was absolutely full from the dealer.
I'm not sweatin' it. I know it will get better when the truck breaks in more. also, i did not buy the truck for gas mileage.
kyle
kip
-- Don
Anyway back to trucks...noticed this morning that for the first couple of minutes if the temp is 32 or below my mirror blinks the temp then blinks ICE and then goes back to the temp. First time I ever paid attention to that. I could've just opened my eyes to the snow that was still left on the ground, but luckily those trusty GM engineers already thought of that so I didn't have to....
Bob
I don't like vehicles that assume you are an idiot, and have to tell you things you should already know, like your fuel is low, or door ajar. Who's drivin' the damn thing anyway?
Interesting note, I called the GM dealer and asked for a price on the filter. Was told it was $26. I asked for a part number and the dealer refused to give it to me. He must have sensed that I was going to shop around and offered me the filter "at cost" - $18 without being prompted. I hung up and called a local diesel shop that is an authorized Allison service center. "Allison" brand filter = $11.
Also purchased a 454 oil filter from a local Delco dealer for $4. GM dealer wanted $12.
Pays to shop around? Can't afford to let GM rip me off on parts aft spending $30K on the truck.
Jim
Bob
Oh well, just like any other place that charges too much for a product, I go to another store and give my business there!
Bob
Boneheads!!!
Jeff
P.S. I live in Gardnerville.
See you a Sharkey's!
Jeff
Bob
P.S. Ah, Jeff is that place you mentioned on the corner (LOL).
Steve
Go for the longbed and the 8.1
You will kick yourself later if you try to slim down. You get the 34 gallon tank with the long bed. Get the 4:10 gears as well. I've had mine 6 months now, very happy overall!
kip
LAURIE 1:My gas guage works fine.
I switched from a ext'd cab LB to a Crew Cab SB with my 2500HD. I do miss the foot and a half out of the bed, but the functionality of the crew cab more than makes up for the bed space. My new truck is 4" shorter than the old one, but parking and garaging are vastly improved. Make your decision on how you will use the truck, not what a dealer says.
Regarding the 8.1 Vs the 6.0, the 6.0 will tow your trailer no problem. I would recommend getting a brochure on whatever truck you are interested in to be sure the tow ratings of engine & axle ratio match the load you plan on towing. I went away from the 6.0 engine because you cannot get a 3.73 axle ratio, only 4.10's, which are way too low for me. If you tow a lot, get 4.10's, but if you only tow a couple times a month, go for the higher ratio. Your mileage will be very close between the 6.0 w/4.10's as compared with the 8.1 w/3.73. Lastly, if you decide to upgrade to the 8.1 Allison combo, you are looking at around a $3,000 price adder!
Good luck with your choices!
Jeff
