subaru forester-air bags don't work
while driving on slush covered road, brake lightly applied to avoid obstacle, brakes did not respond, had to move more to right side of road, front wheel caught in slush causing car to pull severely to right, over corrected and went off road, not really good thing for the forester, hitting culvert at more that30 mph. Air bags did not deploy, seat belt did not hold firmly. Driver hit head on windshield, resulting in confusion.
UniBODY bent (Ins co allows 6 hrs for this) plus substantial damage to front. I report my concerns to Subaru of America, spoke with Chris in customer care, who is basically not concerned nor sympathetic nor understanding. Subaru's position as indicated by Chris, customer care-Subaru, is he these things happen and Subaru is not interested till the Ins CO notifies them of their investigation. My Ins co has elected to further investigate. SUBARU SAFETY??????? NOT AS SAFE AS SUBARU ADVERTISEMENTS WOULD MAKE YOU THINK..
BUYER BEWARE
BUYER BEWARE
Seems like airbags should have deployed, but I have read that airbag deployment requires a very substantial impact. Your impact may have been just under the threshold. Investigation should prove this out. If the seat was very far forward and the seatbelt height adjustments were improperly set, there may be insufficient distance for the belts to bring you to a safe stop, but again, investigation should prove this. Please post results.
I hope that everyone in the vehicle will make a full recovery and I can understand your frustration. You want justice and if the investigation results indicate safety problems you should have (and pursue!) a valid case against Subaru. Unfortunately, it is crashes such as yours that makes vehicles safer for everyone.
I own the same car and believe that the GOOD ratings that the 2001 Forester received in both the Gov't Crash Tests and Highway Institute's independant tests back up Subaru's safety claims, barring any system failures.
Please keep in touch as there are many sensible and knowlegeable Subaru owners here that will appreciate your comments and experiences.
-Tony
Marc
Without knowing the exact distances and speeds and the fact that you have given an estimate of your speed on impact and the fact that the culvert would absorb some of the impact,then I would have to say that it sounds like it didn't fail.
I don't have the owners manual for your vehicle on hand. If you look in the manual you will probably find information on the speeds at which the air bag system is designed to activate. The manual should also warn you about the types of accidents that the air bag will not deploy under.
Anyone have the Subaru Forester owners manual? (I'd look in mine but my vehicle is on order - had not arrived yet)
It might say something about it in the specifications section or in the air bag section. It should give you a range of crash speeds where the system is designed to trip. Let us know!
subaru forester 2001-air bags did not deploy,questionable brake failure
At this time, the insurance co. has contacted NETS, a technical consulting firm in MA. They have contacted Subaru and invited them to have an engineer present to inspect our vehicle. Subaru is now requesting more information for my insurance No prior to sending an engineer out. Their response is that they do not have the resources to responding to all situations. I have asked Chris, SuBARU CUSTOMER SERVICE, if they have had many such request re: air bags, of course no answer.
In earlier conversations with Chris, Subaru Cust. Care he stated that the air bags are designed to deploy as impact speeds greater than 14 mph.
In addition my ins. o. has elected to purchase our vehicle as they may need it as this investigation continues.
Re: the brakes, Subaru has had a recall for faulty master cylinders in 99 Foresters, this problem was noted to occur in cold weather..
We will post updates as this saga moves forward.
Towed the car to dealer who tells me they can't find anything wrong with the car. Unfortunately, my insurance company doesn't want to take it any further at this point.
Coincidentally, I'm also dealing with a "Chris" at Subaru of America. He told me that I can submit all my records to him for review. But yesterday, he advised that if the dealer couldn't find a defect, there was really nothing they could do. Car is now at the body shop.
Thought these events sounded similar to your own. Any suggestions on how to deal with this now? Unfortunately, the car is a lease and I only had it the three weeks before this happened.
