You shoujd see the external shots of his car. He has really done a great job in adding a distinctive look to his LS. Can you add some of those for the folks here?
Your LS really looks good. I really like that grille, who sells them? I'd love to have one for my LS I just bought. Maybe you can help me with this, my 2002 which I just picked up a few days ago has the body kit,the fin on the deck lid and a phone as well as some other different options that where much different than the other 2002 LS'S I was looking at. I'm thinking maybe it's a regular LS with LSE options on it. Though on thing that puzzles me is that it says LS-C in the inside compartment. One thing I don't have are the round fog lights, I have the sqaure ones, I guess the rounds fog lights weren't available till 2003 maybe ? Could you let me know how the LS-C varies from the LSE. Any info you can pass on would be highly appreciated. Thank you, LS4RON
Hello I own a 2001 Lincoln Ls V8 and the pillar post and rocker panel have started to become dull in color and I would like to replace them. The only replacements I can find include the use of 3m adhesive tape and I dont really wanna use tape. If any knows of any other parts without the use of adhesive tape please RESPOND to my post any help would be greatly appreciated and I am sure everyone else will benefit from your in put
Have you tried cleaning the posts and restoring the finish?
I've had mine dull a little and have had pretty good luck shining them up. Perhaps a product like 3M finish restorer or something like that would work for you and be much, much cheaper. If you are willing to swap them out for new ones - why not try to restore them and if you ruin them along the way - then you'll have to replace them.
Sorry, I don't have any suggestions with the actual replacementparts.
What's up guys & gals? I'm looking to see what all I can do to my LS (2002) v6 This is my want/wish list that I need info on. Air intake Speed chip/super chip Mesh Grill for the lower front. Maybe a black metal grill for the upper front. Eng. Dress-up kit. Clear side markers,headlight, & taillight. Ground effects/Body Kit Underbody light kit 20" Dub spinners/floaters.
I have used the stainless pillar post covers with 3M tape on my '99 Town Car. Looks good on the Town Car but would look overdone on an LS. I have used all sorts of polishes on the stock posts but they did not come back to the factory look. The tape is very thin and is applied to the new post covers, you would need to follow the instructions very carefully as I did not and had to buy 1 extra post.
I am about to replace my speakers in my 2000 Ls. I read that I must remove the entire door panel. Is this true. I have a blow by blow on the door removal, but wanted to ask if were true. How hard is it to remove the rear speaker cover in the trunk, it takes up so much room.
I install the speakers. It was very easy. You can pop the speaker covers off, but you can't get to the screws holding the speakers. Perfect 5x7 fit. Oh yea, door panels did come off. I used SDAT's
I just purchased my a 2000 Lincoln LS - I am looking at any mod's that will boost performance. I have read alot about Intake mod's - have you done this yet? If you can throw me a few ideas i would be grateful. BTW, I haven't read alot on problems replacements with the car - my car has just under 70k miles on it and I was just kind of wondering what to expect in the future, as far as problems are concerned.
I recently installed the KKM V8 intake and have been experiencing problems.
The "Check Transmission" error keeps displaying. I took my car to a transmission specialist and he said to there were numerous errors codes returned by the diagnostic computer. There was nothing mechanically wrong with the transmission. He recommended I remove both Positive and Negative battery cables and touch them together to fully discharge the system and purge all error codes from the system.
This worked for a couple of days and the error returned.
Has anyone experienced this problem when installing the Kurtz Kustomz Motorsport V8 intake?
I am looking for ways to modify my car. I want to add power. I plan to add a new exhaust system but wasn't sure what kinds to look at. I also plan to add a new audio system and 20'' Asanti's wheels. Please reply w/ any suggestions. Thanks!
Hi did you ever find out what that drone noise was, I have heard it on my ls. I thought it might be a rear bearing, so I called a dealer and they said that you have to buy the hub with the bearing $400. Anyone have any suggestions.
Hey Man, I love what you did to the front end! I have an 00 LS and looking to add a new look. Would you mind telling me where you got the black honey comb bits and cost?
I have a 2002 Lincoln LS that had been serviced by Desert Lincoln-Mercury in Las Vegas for 40,000 miles which was provided by Lincoln. After the included servicing had expired I decided to service the LS myself, because I wasn't that pleased with Desert Lincoln-Mercury service. The first service I performed I found numerous things broken and also noticed the oil level wasn't to the full mark on the dipstick. I didn't think much of it and serviced the LS, and did so again 4,000 miles later. My wife smelled oil and we made an appointment with Desert Lincoln-Mercury, since it was still under warranty until 75,000 miles. Long story short, I get a phone call from the service department telling me the valve cover had a hole in it? I asked how something like that would happen. Desert Lincoln-Mercury tells me someone?? stuck something down the oil filler and started the engine causing the valve to strike it and crack the valve cover, but it didn't happen there???? I asked where it happened since they where the only ones who touched the car, and me performing two oil changes. Desert Lincoln-Mercury tells me there was no way they did it and therefore they were not going to cover the valve cover?? Has anyone else experienced anything like this and what action should one take. I have no confidence that anything/previous services had been conducted correctly on the LS and unfortunately think I should get rid of it. I like the LS but have a very bad taste with Lincoln/Ford and probably with get a Cadillac next. All input would be appreciated.
(that looks long.. it is just the problems and solutions forum on this website. It could be the halfshafts, apprarently that is a common problem... I have a similiar problem, but haven't solved it just yet...
Hi guys, My car was vandelized tonight and I need a new driver door mirror. I was wondering if anyone knew where I can get one inexpensively. Sorry if this is in the wrong section. I did not see a parts section. Thanks
I have owned an LSV8 2002 for 15 months and thought it was an awesome auto until today. The vehicle will be four-years-old on 11/16/2006 and only has 58,000 miles on it.
Apparently the front end has been going nuts on me since I changed rubber in October of 2005. (Same Michelin Pilot series that came with the car. I did not purchase the rubber at the dealership due to the fact that they did not and could not offer Road Side Assistance.)
After several attempts to figure out the problem with both tire shop and dealership, everyone is puzzled - that was until today.
The dealership hooked up a computer to the car and found out that the Variable Assist Actuator is defective as well as a module that controls this actuator may also be defective.
The end result - Me spending $886.24 + Tax to replace the defective item/s.
I told the dealership that I declined the repair work and it still costed me $140.66 for them to diagnose!
Personally, I do not feel that I should have to pay for an item that apparently was going bad when I changed the rubber and was still under the 50,000 mile mark.
No... I did not take an extended warranty and now I wish I did, but none the less, I feel that this is a manufacture defect, especially when the vehicle is not even four-years of age and is only 8,000 miles outside the 50,000 mile warranty.
Now, I could see if the vehicle was 5-years of age and had 70-80,000 miles and if the vehicle was owned by more than two people and was never serviced/maintained by a FORD/LM dealership, that I would have to pay for this.... but since I am only the second owner and the vehicle has always been serviced by a FORD/LM service centers, then I firmly believe that FORM should take care of this item for me.
I tell this story because I would like to know if anyone has expierenced anything like this - and what they have done about it, or what anyone may suggest for me to do, other than what I had already thought of... Find the car a home.
Ford has a comsumer affairs appeal process where you can go above the service managers head. You should also call your local district office. But since you didn't buy the car new, they will be less inclined to help.
I've looked everywhere for dark headlight & taillight covers for my 2002 Lincoln LS, V8,but absolutly no luck.I find it hard to believe they cant be purchased.Does anybody have any ideas?
Hi folks. I purchased a brand new rain sensor (part number XW4Z-17D547-AA) back in 2000. I had planned to use it in a project I was thinking about doing but never got around to it. The part is brand new and has never been used. It also has all the schematics surrounding the LS wiper system. If anyone wants this part they are welcome to it. The part is free...just cover shipping and it is yours. if you are interested, check my profile for an email address where you can contact me. I'll hang on to it for a few more days and then I'm throwing it away if there are no takers.
Hello folks, I am attempting to put LED stop/turn signal bulbs in my LS. I purchased some great LEDS from a company in AZ. They are as bright or brighter than the incandescent bulbs. My problem is this. My car is sending pulsed current to the LED's, which cause them to flicker rapidly (about 15-20 times per second). There is definitely a rapid increase /decrease in voltage. This happens when the motor is ON or OFF, so that rules out the alternator or charging system. The necessary resistors are in place however it happens with or without them. I have tested the bulbs in a 2002 Escape and they function flawlessly. I know there is a Lincoln Engineer that would laugh at this problem and tell me how (if possible) to fix. But I can't find that person. CAN ANYONE SHED SOME LIGHT (NO PUN INTENDED)ON MY PROBLEM? Thanks JRIEGER
If anyone talks to supervette79, please ask him to respond to post 89. (accessories and Mods. LS) I think he may be the person that I'm looking for.THANKS
Hey guys this is my first post I have just purchased a 2000 lincon ls has alot of miles on it (146,000) but anyways I was wondering if there are any websites that have lincon ls performance parts or atleast show setups I have looked everywere and have got nothing the only thing I have got was a website called www.lskoncepts.com and all they had was a couple of bodykits. what I was wanting to do is find a ls rolling chassis (no motor or trans or possibly blown motor or trans)and put a small block chevy in it or possibly even a small big block. Tell me how many of you have been at a stop light and had a lincon ls come up next you you with a carbed small block under the hood lol bring some old school to new school and mix a little class. well if anyone has any helpfull tips such as info about if the rear end will hold up or what kind of engine compartment tricks I will need to do just stuff like that. well thanks guys and hope to hear from some of ya soon.
lskconcepts is about it as far as specific LS stuff.
A ford 4.6L V8 will fit under the hood as will the 5.0 Cammer engine. The rear end is only good for 300 hp (factory V8 was 252 hp) so you'll need a whole new rear end (you might look at the Jag S-type R rear end - it was good for 400 hp) and should bolt right in (more or less).
The problem is that the PCM won't talk to the new engine or transmission and you can't run the car without the PCM. If you just want a track car then it's probably ok. If you want a daily driver it will be difficult.
i have a factory alarm but it hasnt been programed to the car yet so i cant open the car from the remote and putting the key in the door everytime is getting annoying. The dealer wants $90 to do it i dunt want to pay for something i can do myself does anyone know how to do it????
I watched my salesman add a 3rd keyfob to my car when I purchased it. He had to do a sequence of things, but it worked. I couldn't tell you what the sequence was. In addition, you may have to have 1 or 2 working keyfobs to add one, I am not sure.
I'm almost positive the dealer has to use the diagnostic tool to program the keyfobs. This is one of the few vehicles that don't allow you to do it yourself. You don't need any working ones - that's for programming the keys yourself. You need two working keys to program a third key without taking it to the dealer.
My car was vandelized too. But they could not get the left side mirrow off, so they broke it. It works but hangs down. It needs a screw in side to keep in place. Can anyone help???
Instead of telling me how many miles i have left on the message center of my car when it starts it just says check left brake lamp. Problem is my brake lamp is fine, works great and the only way i can shut it off is to hit the status and reset to shut it off for the one time im driving but then comes back on the next time i start it up. i was wondering if anybody could tell me a way of shutting off that message for good
I think you're on the wrong forum. The 3.9 V-8 engine in an LS puts 250 HP to the rear wheels and has an un-modified top speed of 155. I have added another 200 to that (over a weekend) and will own the Maxton land-speed record for my class in less than a month. Then I'll get serious and expect a regularly street-drivable 750 HP later this fall. You should go buy a Malibu. KS
hi i have a 2003 ls and was wondering how you modified your ls or if maybe you could point me towards some web sites that offer ls performance parts and stuff. thanks for your time.
'00-'02 V8 version (details)
'00-'02 V6 version (details)
Filter (details)
With the McLaren-style grills, custom emblems, and '03 fogs
I owm a 02 LS and would like to know of other people's experience with them.
The one's that I am considering are aftermarket and the self sticking kind...no clips needed.
Looking forward to reading your feedbacks, thanks.
i am not looking to spend an arm and a leg. can ayone help me?
Air intake
Eng. Dress-up kit.
Underbody light kit
I think that about covers it.
Give me any input or thoughts?
Thanks, Ghost
I got the following error code from a Checker Auto Parts diagnostic tool:
P0795 Pressure Control Solenoid "C"
This error code is related to the "Check Transmission" error displayed on the dash.
I have a 2001 Lincoln LS V8, I am wondering if anyone knows how to program the Keyless entry pad.
Does anyone know if someone makes a supercharger and/or turbochrager for these cars, and where can you find various upgrades for the LS V8 too.
mongoose
BL
It sucks!
Thank you in advance for your time. :sick:
KS
