Sunroof leaks
I swore I'd never own a vehicle with a sunroof, but a few years ago I was won over by a beaut - a '90 Volvo 740 Turbo. About a year and a half ago, the sunroof started leaking (the exact reason I didn't like sunroofs). Now I drive a '97 Pontiac Bonnie and it, too, has a sunroof. The car is shacked up in the garage when not in use and any accumulated snow gets wiped off. I am curious if there is any prevention methods to keep the sunroof in a non-compromised condition?
Not the type of water that quenches my thirst. . .hs
Knowledge is power (destructive in my case). . .hs
"A drain trough encircles the sliding panel. The trough leads to drain hoses located at each corner. The two front drain hoses are routed down the windshield pillars. The two rear drain hoses are routed down the rear sail and quarter panels. If water leak compaints are encountered (wet headliner, etc), first check the windshield or rear window for the source. Prior to performing any adjustments, verify that the drainage system is not plugged or restricted. Using a 1 pint container, pour water into the drain trough with the sunroof open. Check for drainage from all 4 hoses. If water flow is restricted, use compressed air to clear the drain. Be careful not to blow the drain hose away from the housing drain spout. If water drips from the headliner above the doors, lower the headliner as required to check for proper drain tube connection. If necessary, reclamp tube(s) to housing drain spout."
Be careful with the compressed air. Suggest you find a shop with a pressure regulator (use 30 psi max.) and a blow gun with a long extension.
hs
