Common General Motor's 2.8, 3.1, 3.4 V6's engine problems
Hi I am have a 96' Oldsmobile Ciera series II 4door with 79K. With 3.1 series 3100 V6. I just found out why car was using coolant for the last six month's. It appear's that one gaskets is letting coolant out the top of the engine. The mechinic said in could be the Intake mainfold upper and lower, head gaskets or the throttle body gasket's. I am wondering which gasket it is? I am wondering how common this problem is? I also like to know how time (aka work is involved to fix). And Lastly how other engine damage I might have. By the way I had checked my oil and it does not show any signs of contaimintation (the oil looking cholatety, or thick and murky).
See Also
The Lost Art of Diagnosing Engine Problems
See Also
Mitchell Mechanical Labor Estimating Guide times:
1984-96 Ciera
Manifold gaskets................ 5.4
Head gaskets.................... 9.8
Add:
where A.C. interferes........... .3
where Air Pump interferes....... .5
where Cruise Control interferes .. .2
By the way, Dex-Cool is available at K-Mart and similar outlets at very reasonable prices. Don't buy it from the dealers.
I'm not suggesting that's what Grand Prix's fault was but, while we were on the subject of valves....
Thanks in advance for your insight,
rwinger
The coolant looked like it was a mix of dexcool and regular AF. I say that because it had a green shade to it (it was still basically that fluorescent orange/pink, but it sure didn't look like fresh stuff) Would the intake manifold gasket deteriorate as a result of mixing the two?
rwinger
Its going to another mechanic tonight to take care of something that was supposed to be done when I picked the car up, so I can get a second opinion from him before I go spending a ton of money.
How common are intake manifold gasket failures in these engines anyway?
Any help is appreciated, Thanks
rwinger
On the dipstick, I would look for an increase in the level or if there is a kind of goop like what is on the oil cap. If you trust the mechanic, I would also talk to him about it.
Something bugs me about this failure - I'm still puzzling over the reason that (at least for this vehicle - 97 venture) they sell it with dexcool, which is good for 5 years, and then can blame lack of maintenance in the cooling system for the gasket failure. The service advisor at the dealer was quite sure it was the intake manifold gasket leaking, so I assume he's seen this a few times. I've only had it 1 1/2 weeks so I can't comment on what the previous owner did or didn't do but given the van's age, the coolant shouldn't have been in bad shape for too long if its designed to last this long.
I guess I'm wondering why this failure is common, and usually blamed on the coolant maintenance which only needs attention every 5 years. Should I be changing out the dexcool every two years like the regular stuff?
A little miffed, Not enjoying spending $$
rwinger
I'll talk to the mechanic and see what he says. I just would like to know that first, it needs doing, and second that it should be OK after as long as I maintain it properly. I like to have my cars in the shop when its convenient for me.
Am I bitter? A bit.
Mastercard likes me though.
rwinger.
NOTICE:
When adding coolant it is important that you use DEX-COOL (orange colored, silicate-free) coolant meeting GM Specification 6277M.
If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will have to be changed sooner -- at 30,000 miles or 24 months, whichever occurs first.
The problem is that silicated (conventional) coolant can damage aluminum parts such as the intake manifold and cylinder heads on 2.8's, 3.1's, etc. Re your question as to whether this is common on these GM engines: yes, very. That's why they had to develop the silicate free coolant.
I was quoted by a dealership that it would cost upwards of $700 to have this problem fixed. I think I'll get a quote from another mechanic before I do anything.
The part that really upsets me is that the entire coolant system is advertised as "no coolant change" for 100,000 miles. What could have caused the gasket to go bad? I never added dexcool coolant to the system until I noticed it was leaking. I have never considered buying a foreign car, but it's expensive repairs like this that make me wonder if its worth sticking with GM cars.
I now know I'm not the only one out there with this problem. Thanks for the insight.
One more thing... has there likely been damage to the engine as a result of this leak? Am I going to be plagued by recurring problems because of this?
Again Thanks,
rwinger
Anyway, my father put a fan in the engine so I could turn off AC and still have a fan on to cool off the engine in stop and go traffic, red lights, etc. He put a switch inside the car so I can turn the fan on and off as needed. I don't know how much that would cost if you took it to a mechanic. It does help though.
I'm buying a new car soon and have been considering the Impala and Taurus. After reading car reviews on Taurus's as well, I may just flip a coin on which one to buy! The Impala owners seem to be satisfied customers anyway.
I hope you get your overheating problems worked out. I've been dealing with it for 10 years with this Grand Am!
http://www.imcool.com/articles/anitfreeze-coolant/dexcool-macs2001.htm
This link found at:
http://www.s-series.org
Al
I think it loosens up after a while. (116,000 and still uses no oil)
My advise is to torque it down, so far it has worked for me. It uses a 10mm socket and/or wrench.
Also in the owners manual it said when you change coolant to put a stop leak additive, I. E. Bar's Leak Stop.
Has the problem been fixed in later model versions of the engine?
Thank you for the link!
I had the same contamination in coolant tank of my 98 Chevrolet Malibu with 3.1l V-6 engine. I would say even much more pronounced.
Recently asked for coolant system service at my local Firestone, because of the sediment and because I had to add a quart of 50/50 DexCool solution every tree months. Was not sure if this is an evaporation or small leak, even more that the Malibu manual states it is normal to add coolant up to four times a year.
The mechanic told me DexCool does not need be replaced before 100-150,000 miles. I told them about the need to add coolant. They started from pressure test and found a leak on the top surface of the intake manifold gasket. Now the car is in shop, undergoing the gasket replacement.
Had the the reddish sediment in the coolant tank from the very beginning, when I bought the car used with 15k miles. Serviced it first at dealer, than at a very good local Firestone shop after the original warranty expired. They added coolant every 3 months. But nobody told me before this sediment is not normal.
The contamination looks natural with the orange DexCool coolant: the iron oxide, i.e. common rust, have practically the same color, only more dark Most probably, even certified mechanics may not know this is tell-tale sign of rust.
When cruising at aproximatly 55 MPH ( aprox 1,800 RPM) if I try to encreasy the speed the engine start missing, it feels like one cylinder is missing).
Where can I find information to troubleshoot the ignition and fuel injection systems in my car.
I need the wiring diagrams of the ignition and fuel injection systems and the physical location of the sensors associated with the systems.
Several years ago a had a similar problem with an Oldsmobile 6 cylinders and found the problem to be a spark plug wire, the wires in the Buick check ok as far as continuity is concern.
Any sugestions will be apreciated.
Abel
Does the problem go away if you shift out of overdrive at the same speed?
As the car heats up the wires break down and start arcing.
Try that and that alone may fix your problem.
GM ignitions are of such high voltage that they tend to be hard on plug wires. If you have ever noticed that the plug gap is something like .60 which takes big volts to jump such a large gap.
But that is one reason GM motors have decent HP and torque and yet get decent mileage.
I have a 2000 Impala with a 3.4 and I got 33 mpg on a highway trip.
Alan
I will also try the overdrive sugestion and let you know.
Thans. Abel
