Toyota Celica GT-S
I am 16 and I am just test drove the celica GT-S and I liked it. I want to know hats a good price. its a CelicaGT-S , alloy wheels, as, sports roof, -shift , leather seats. what is a good price for this? the dealer wants $26,500.
Toyota Index. I am directing you to the index page because I don't know if you want to purchase a Automatic or manual transmission. Drill down to the vehicle you are interested in and then visit our pricing section. Hope this helps!
Owner can compare notes..., and non-owners can see what it's like to live with this 2000 Toyota Celica GT-S with Edmunds.com's Long Term Road Test.
Happy Motoring. ;-)
Pocahontas
Hatchbacks Message Board
and... can you explain a little bit..if you realy know it..
Sorry for the spelling error
Yesterday I noticed that the lower RH strut bracket was installed backwards, placing the pivot point forward several inches! I took out the two bolts and swaped it end for end--problem solved! The liftback raises with a lot more zest, and stays up easily.
So if your Celica has a sagging liftback check the lower strut brackets. Each one should be stamped either RH or LH, and these letters should be right-side up. There is also a slight depression in the narrow channel where the pivot point sits when installed correctly. I let the dealer know and they figred since the new struts didn't help then the factory installed the bracket incorrectly and the dealer's tech didn't catch it when he swaped out the struts. Good luck.
about 1995-1999 Mits. Eclipse's part website
like change the parts...???
thank you....
I've driven both for weeks at a time, and I prefer the e-shift for everyday driving. You just have to use it awhile to discover how sweet it really is. In my opinion, the gear spacing on the 6-speed is atrocious. I've heard they're taking a close look at it for the next model year.
I would say a normal (gas-conservative) shift for the 6-speed would be a little over 3000 RPMS. This would put you in 6th around 60mph.
There is a decent tourque point around 3800 RPMS and yes, the big one around 6500-6800 RPMS. I don't know if the sport shift will allow you to reach that or hold it though???
The second cam kicks in around 6000 rpm, which is why you get a big boot in the back at that point. The only time you use it is when you're merging into traffic or racing, and it's good to have it when you need it. The rest of the time, it's nice not to have to change gears when the 6-speed tells you to. The e-shift is much more flexible and real-world friendly, in my opinion. And I wouldn't have thought I would be saying that, except that it's true. I learned to drive with a 4-speed, owned four Alfas, a Lotus and two Road Runners, and I love manual shifting. But the transmission and shifter in the GT-S is just not engineered well, in my opinion.
XS Engineering did a turbo for the GT-S, but I hear they've had problems with it. It really isn't as good an application because of the higher compression and wilder cams. I think the simplest and most effective thing they could do in the short run would be to change the gear ratios and the VVTi programming.
Yeah, I would imagine that both the high 11.5:1 compression and the valve overlap would present some problems. If they could re-map the VVTi programming so the high lift cam kicks in around 5200-5500 rather than 6000, I think the various gear ratios could be left alone. The biggest complaint I've got right now is the apparent gulf between 1st and 2nd.
Maybe just a shorter final drive ratio would do the trick...8^)
So any suggestions? Comfort and luxury is not a big issue...I am more concerned with fun and performance.
I've got 6700 miles on the turbo now, and it still runs smooth and strong. I love it.
What is the difference between the new T and the GTS????
I don't know where you think you're going to find a WRX at invoice. Let everyone know, because it's nearly impossible. Don't know why you'd want one - it's stupid looking IMO, but it's not my choice.
You could get a GS-R now for $21k since it's the last model year. But, it's been the same since like '93 or whatever...
The 2002 Acura RSX is due out is July. This is Acura's version of the GTS. Seriously, check out the inside, it's a rip off the Celica. Also, the styling is a bit plain.
I think Im either going to get a Celica GT manual or an Integra GSR...hoping i can get a good deal (sub invoice???) for a GSR since the new integras are arriving. anybody know if it's possible? Im thinkig if the price difference between a fairly nice equipped GT (alloy wheels, weather package, power windows, alarm system) and a GSR is around 1000-2000 bux, I might go for the GSR...
anyway, didnt mean to raise any hopes on the invoice priced WRX
Sometime within the next three weeks the car will go to TRD for evaluation. Hopefully they'll get behind the program and produce it as a factory certified kit. If they do, that means emissions certification and a factory warranty. If they don't have the budget to adopt the program, it will still be available through Toysport. I wouldn't worry though -- this is a low boost kit and it hasn't shown any bad habits for over 9 months and 6700 miles.
Oh -- difference between it and the GT-S? Roughly the same price ($18k for the GT plus about $3k for the turbo), but WAAAYYYY more horsepower and especially torque. Way easier to drive, too.
A factory certified kit means the factory warranty stays intact. Without it (as with any aftermarket part), the factory can dissallow warranty repairs for engine damage that can be traced to the turbo. Emissions certification means you don't have to worry about having it smogged in states like California, where the emissions testing is super strict.
The turbo kit will be available for any car using the 1ZZ engine (meaning the Corolla, soon-to-be-introduced Matrix, Celica GT and MR2 Spyder).
Pocahontas
Hatchbacks / Station Wagons Message Boards
Does anyone know when they are coming out?
What changes will be made on the cars?
There is no turbo offered for the Solara. TRD offers a supercharger for the V6, but nothing for the 4. If you really want a turbo, have one custom made -- it'll run you about $4500 installed.
Toysport is a west coast tuner that specializes in Toyotas. However, the kit will be able to be installed by anyone with normal mechanical ability -- or the speed shop of your choice.
Do you know when it is going to be available?
Is there any word on some sort of recall?? I know there are not many of these, so the numbers don't add up to make an official recall probably.
