1995 VW Passat GLX Problems
I brought a used 95 Passat GLX two days ago. This car is nice except the vibration. I did not know the reason. Does any one have the same problem?
Dan
Dan
Do you mean the engine vibrates at idle, or that the steering wheel vibrates at highway speed, or that you feel a vibration under your seat but not in the steering wheel, or an overall buzz in the entire car under certain conditions?
We can't tell you anything with such a sparse description....details, please!
It smooths out when revved though. Is that the vibration you are concerned about? At cold start?
I had a 1995 Passat GLX up until about two years ago. I bought it new and drove it almost 90k miles in the time I had it.
I experienced two different types of non-engine vibration during my four years.
1) The Passat has marginal rear wheel bearings which WILL gradually become rough, if ignored long enough they can cause more of a vibration sound than the actual feeling of vibration. Said sound is more than just a little annoying, and fairly inexpensive to fix.
2) Virtually all of my driving was in and around NYC, during the winter of 1996 we had lots of snow, mud and pot holes. After one sustained melt, a fair amount of mud built up inside of the wheels causing LOTS of vibration. A quick trip to one of those do it yourself 50 cent car washes fixed most of the problem. The remaining fix required a new BBS wheel, apparently I had hit a pot hole hard enough to bend it!
Hope this helps.
Best Regards,
Shipo
P.S.
If your vibration is experienced only during braking, you probably have a "Hot Spot" on one or more of your disk brake rotors. In which case, the best fix is to replace the rotors.
Also, at what RPM should the Tip automatically shift up? I can get it to shift down on its own but not up.
I'd appreciate any insights.
