Volkswagen Golf Accessories & Modifications
Karen_S
                    Member Posts: 5,092
                    Share your Jetta accessories and/or modifications stories here!
KarenS
Owner's Clubs
                        KarenS
Owner's Clubs
Gary
i have used both venders for many years on my previously owned 87 gti weekend racer.
Thanks, Doug
Karl Flaig
www.blue-guy.com, Driven By a Different Point of View
I seem to be getting a ton of windnoise from my brand new 2001 Jetta VR6. Is this just my car? I would be grateful for any suggestions. Thanks.
Yes the increase in power is quite evident. In the forums at vwVortex.com someone recently posted that a GIAC chip drops the 0-60 times to the mid-6's. More than the horsepower increase, the chips raise the torque to insane levels (about 240). It's the 1.8T's torque that makes the car feel so strong, not the peak HP, which doesn't even come on until late in the RPM range. Almost full torque on the 1.8T kicks in around 2200 rpms.
Check out vwvortex for more info. Do a search in the forums on chipping. Gobs of info.
i have a neuspeed chip in my 2k vr6 jetta
i do low six's now as the result it rox!
i was gonna get the neuspeed p-flo but someone told me that its not good n e suggestions on that?
what bout a cat-back exhuast? what kind and where?
and i want to get FOG LIGHTS ON MY CAR...ANY SUGGESTIONS ON THAT???
i got a EXHAUST TIP from VWAFTERMARKET.COM
it rox and makes my car look good
look into
thats all i ahve to say about this....thanx
A week later I installed a 2.5" techtonics stainless cat-back system (Borla muffler) with NOTICABLE results. The chip will have to wait until my 60K platinum warranty expires. I also had a set of Eibach Pro-line springs installed. The improvement in handling was significant, since the CG was lowered 1.5". Oh yeah, the springs were VW installed, purchased out of their catalog--not the best price, but covered by the vehicle's warranty.
- How do suppliers vary winter #1 vs summer #2 mixes?
- Any anti gelling additives recommended - if drives up north to below 0 temps?
- Do various brand Diesel fuels vary with sulfur? or additives (injector cleaners)?
- Are any specific Synthetics oils recommended?
- Any special Oil filters availale besides VW parts?
- How is Dieselfuel in Europe different than US?
- Why isn't everyone demanding more Diesel engines (like in europe where it's ~ 50% of car market now) ? What's the catch?
Thanks for the info
But most people seem to recommend the panasonic 8 disc or the alpine changer. You will need an adapter tho. (they recommend the blitzsafe, which has a lifetime warranty and will work with both changers - but some people have had to tweak their setup)
Mine is a 2001 Jetta/non-monsoon. I bought the crutchfield cable w/mix function for my panasonic 8disc. (yes, you CAN access disc 7,8 directly. just 'double-click' button 5 or 6) and it can mix all tracks on all 8 discs.
D.
I did notice something else though. You can only hit the actual "power" button to turn the radio on. In the Protege I used to have, you could hit the CD button, the AM/FM button, or the power button.
Hella Micro DE kit for the Jetta (includes grille)
[b]dieselcar[/b]
1. Stanadyne has a VW approved additive for gelling prevention. It is listed under a VW TSB, so it should be available at the dealership.
2. Many over at www.tdiclub.com will recommend Mobil Delvac1 5w40
3. Europe has low-sulfur diesel fuel
4. What people remember diesels as....stinky and loud, which is a different story now and is actually pretty quiet now.
Now I gotta save money for the Landspeed Mikro-Audio system for non-monsoon stereos.
What route do I use to increase the quality? New speakers? Completely new radio?
I don't care about having a heavy bass, nor do I want a radio that can be heard three blocks away - just want some basic quality sound.
www.landspeedusa.com
Some online dealerships sells them also.
Short shifters, of course there's Neuspeed, and there's also Diesel Geek http://www.dieselgeek.com, which also reduces side throws by 30%.
check out www.pgperformance.com they sell them. Every now and then the someone from the vortex is selling them also. And there's Ebay.
First off the front seats have the side impact airbags mounted in them on the outboard sides. How would you know if the airbags are compatible between a Jetta 4door vs. a Golf with 2 or 4 doors.
In addition, the leather seats come standard with heating elements in them and the appropriate wiring connections to boot. Does your 02 Golf have heated seats now?
Finally, will the car's computer accept the different seats as the cars computer checks the airbag system when you turn on the ignition. It could possibly log a fault and cause the airbag malfunction light to go on.
You possibly would have to have the computer cleared by the dealer.
You do not want any chance of the side impact airbags to be deactivated at all.
Last but not least you will compromise your warranty regarding the seats and side impact airbags.
Talk to your dealer for a way to make you happy.
You might be able to buy the leather components and have them replace the velour/cloth covers.
So if you have a putrid smell in your car make sure the dealer checks with VW.
http://www.tuninglinx.com/html/afilter.html
sorry, but it's from a board
I don't think that's a issue for the A4 Golf/Jetta though.
If you got them after, any trouble getting the colors to match?
I don't think these are available aftermarket, but there are some places that have kits. Check out:
http://www.performance-cafe.com
http://www.pgperformance.com
http://www.oettinger.com
Good luck!
