Mazda Protege Basic Maintenance Questions
"Chikoo, I checked for the jolt yesterday and never got much of a bump. I noticed that there is more of a jolt when the radiator fan is already running and then the compressor and A/C fan kick in."
This is the exact situation that I explained to Mazda dealer last year - the first time when I took it for the jolt problem. sure we think alike -huh
Malt, I am sorry if I am troubling you but you are one of those few on this board who has been able to talk with some engg. data with him...not speculations.
thanks for your input....
BTW, what is the idle RPM of the DX/LX?
(just a thought)..
Here are the idle-up specs:
Load condition...........Idle-up speed (rpm)*1
E/L ON*2...................650--750
P/S operating*3............700--800
A/C ON*4...................700--800
*1 : Excludes temporary idle speed drop just after the electrical loads (E/L) are turned on.
*2 : Headlight is on, Fan switch is above 1st, Cooling fan is operating, Rear window defroster is on.
*3 : Steering wheel is fully turned.
*4 : A/C switch and fan switch are on.
I checked out the 2001 ES. It has the same A/C and the same Idle speed setting too!
check out the jolt for us Vocus...so we know what is going on.
BTW, remind you that the jolt is felt only when the radiator fan is also working...means after the car has reached normal working temp+ some more driving.
Linda
However, I did use it on the rear and side glass and headlights. It worked well keeping those surfaces free of water, but the front glass always seemed to bother me with Rain-X on it. It seemed almost like it was waxed.
Also where is the best place to get them?
And complementary wires... I've heard it's best to match plugs with wires.
While you can't buy the true OEM plug in the states, you can get NGK plugs from most auto parts stores along with NGK wires(good quality). The factory plugs are NGK but they are made in Japan vs. 95% of the NGK plugs(including the dealer replacement part) sold in the US are made in the US.
99/00/01 dx : 700 rpm 1.6L
99/00/01 lx : 700 rpm 1.6L
99/00/01 es : 700 rpm 1.8L / 2.0L
do the mazda engineers think all the 3 engines produce the same power output at 700 rpm?
why this standardization of idle speeds?
or somebody never proof reads the service manual?
at idle speeds the engine should generate enough power to support all the loads such as A/C, headlights, foglights, heater, defroster, brake lights, radiator fan, etc.
how can 3 different engines, producing different HP/torque at different RPMs, support all these at the same RPM?
the PCM changes the idle speed based upon the load on the engine...it does not foresee a load like the A/C coming on. Thus it jerks when a/c is turned on and also the radiator is running. The engine does not stall because the rpm have been increased - but just a wee bit late - late enough to stall the engine momentarily.
The idle-up is a feedback system, alteast on the 99 ES.
The way it should work is this:
1 second before the a/c compressor engagement signal is sent out, the idle-up signal has to be sent out.
I am sure the 99 ES is not doing this - courtesy of flawed programming in the intel chip of the PCM.
Mazda says "700 RPM" when gear is in P position.
and that is what my car idles at - 700 RPM
On another subject, I found on the internet that the dealership where I got my 2001 ES is selling my 1999 DX. For $3500 MORE than they gsve me for it!
http://www.sandsauto.com/cgi-bin/ss/prshowca.cfm?CARID=14184
With this nice weather here in MD, finally getting a chance to enjoy the sunroof. My audi had it as well, and it was a must have on my new car. I especially like the glass, (old one was solid, fiberglass) because it really lets the light in and brightens things up.
I have been using my sunroof from the day I got the car. I use it in the vent position all the time though, because I drive 32 miles a day commuting for work. Yesterday, it was like 65 degrees here so I had the sunroof all the way open and the windows down with the CD player going. What a nice feeling!
I am going to get my windows tinted now that it's stating to get warm outside. It gets downright hot in the car even at these outside temps. Cannot imagine what it's gonna be like in the dead of summer at 100 degrees. I want the sunroof panel tinted too, because I don't like the amount of sunlight it lets in during the day. My last Protege had an aftermarket sunroof, and the glass was tinted. I kinda liked it that way. Only thing I miss about that car was the automatic closing sunroof when I turned the ignition off. Oh well, there a LOT more to like about my 2001 ES than that!
Steve, we still are gonna have to get together one weekend and hang out and compare ESs.
If you see a 2000 mica black Protégé LX
with Ohio plates that say Y2K PRO, that's me.
At least it will be so in about two weeks.
I also took some dental floss and removed
the dealer placard. It came right off. I
still have to get the remaining tape off
later this PM. J&J waxed cinnamon floss
works real well.
I bought some black plate covers and
removed the dealer covers as well.
'Gonna be looking good.
When I removed the dealer placard I
also noticed the MAZDA name badge was
looser than I'd expect. I'd guess I
could pull it off with my fingers,
I'll have to look into that...
I saw my second 2001 Protege.. a silver LX.. kinda dirty.. shame..
And washed little zoom zoom yesterday.. actually got another compliment on how good it looks...
it's there since last 2 months and I did not want to go to the dealer without any specifics.
when I am going around 35 mph - usual speed around town and then coast to a stop, there is a slight whirr(sound of spinning) and a thunk from the underneath left footrest.
I have not heard it if I brake hard...but everytime when I semi-coast(lightly braking) to a stop..usually at the traffic lights and stop signs and there is a slight tug forward associated with the thunk.
so what I deciphered was that the tranny is shifting into first gear when I am coming to a stop. but why this whirr-thunk to get into the first gear?
looks like the tranny is shifting into the first gear with some "torque".
need your views before going to the dealer.
Meadeball
Meade
In my old fogie voice..
What's that verna?? You know I can't zoom anymore since I threw out my hip!
any suggestions?
Today I was standing in the cafeteria at work, looking out the window admiring my PRO' from the vantage point of two stories up about 100 yards away. Some lady got into the car next to mine. When she opened her door I imagined I heard a "thunk." There was NO WAY I could possibly have heard anything. It was "just my imagination, running away with me..."
Anyway, when I left for the day I did look...
must be bad karma, keep having problems with my Pro this past few weeks...
specifications say: 700+/- 50 rpm in P.
I did 750 rpm in 'D'.
(in P mode, it goes to 800 rpm).
No more BIG JOLTS from the A/C. I can only hear it engage with a big "clack".
Thanks Maltb for the document.
and thanks to you too Vocus ... for giving me the new Idle settings for the ES.
Used Zymol to wax an McGuires protectant on the inside. I threw the LeBra on and tinted the tires green. It looks awesome!
