Mazda Protege Basic Maintenance Questions
                    How do you baby your Protege?  Please share your care and maintenance regimen here.
KarenS
Owner's Club
KarenS
Owner's Club
There's a local shop here that has tons of car care products and I might go and get some in about 2-3 months to redo the entire wax and stuff.
H
lot of good things about it.
What's everyone's favorite wax? I've used Turtle Wax Finish 2001 (not very good) and Meguiar's Gold Class. It has a good shine, but doesn't last long at all! Once I run out I will buy some NuFinish, we'll see how it works!
as for the waxes.. Zymol is good.
So...how does it look and work? Any model info will work.
Thanx
Which means: Lots of elbow grease &
Damage to your surrounding clear coat (even if it says clear coat safe) If it's abrasive enought to take out a blob of paint, it's also wearing down your clear coat.
Is this a common problem of Pro?
Any suggestions except AC on?
I don't think turn on AC while outside temp. is 25 is a solution.
Besides, it didn't help much at all.
Thanks in advance!
Sean
REgards,
Pete
Then when the windows fog up in only a few small places, you'll see all the spots you missed.
Don't get any of that stuff on plastics, because it may change the color. Also use in a well ventelated area.
Matt, is the RainX anti-fog applied to the inside of the windshield? Also, have you or any other Mazda Protege owners tried the original RainX?
Respectfully;
Larry
all i can say is the repelling one is excellent, i don't really need to use my winshield wipers.
as for the anti-fog, i didn't really help much, i guess i didn't wipe all the excess off...
jeff
I have used the Pink fluid. It works great for easily coating your windsheild with Rain-X, but it's a poor window cleaner. Try getting the additive and put that in a high quality window fluid.
I bought regular RainX, additive and antifog in a 3 pack for $8 at SAM's Club - great deal for three big bottles.
hope this little tip helps.
H
my 22 dollars worth of advice.
-Larry
Larry
then I started having chattering problems - when the glass is cleaned squeaky clean by my wipers..not when the glass is wet.
brought a new pair of wipers...same problem.
Then some mechanic on the net advised me to clean my windsheild with windex..take out all the Rain-x from the container and replace the fluid with standard prestone, etc.
Works great now...even with my old pair of wipers.
not a chatter since last six months.
(that is why I said 22 dollars worth of advice..cost of new wipers:) )
-Larry
1) is this the right time for an oil change ?
2) what is the minimum/maximum tyre pressure allowed for safety & stability ?
thanks for the info.
-hari
-Larry
-Larry
the folks over in Synthetic Motor oil room say they've gone 12K on Mobil 1 and up to 25K on Amsoil, but I wouldn't go that far. they do change the filter more frequently though. since I live in Florida, i like the idea of Mobil withstanding the hot temperatures. That and i could go to a 5K interval (maybe 7500K if the car runs fine after several 5K changes). saves hassle of changing the oil.. but get a better filter though.. The PureOne or Mobil1 Filter..
And for switching back and force, I wouldn't recommend it anyways unless you aren't impressed with synth, but don't go every other change switching back and force. But again, that idea of not switching was due to previous formulations that cause the leaks... shouldn't be a problem now.. my Altima has 29K and at 30K I'm switching to M1 (been saying that since 21K though!!!) and the Protege WILL switch at 5K.
Dino oil: 18,000 miles divided by 3,000 mile change intervals, equals 6 oil changes a year.
Syn oil: 18,000 miles divided by 5,000 mile change intervals equals about 3.5 oil changes a year.
So, even if the cost is double, I still almost break even at my self-imposed change intervals. Not to mention the, time and effort to do the change out? Victor, what is the difference in price between a good quart of dino oil and a quart Mobil 1?
Thanks in advance;
Larry
I don't know if you might notice a difference straight away, but the most important thing, is change the oil regularly.. you also might want to look at taking samples of oil from both cars before the switch and after for each change to see since you both have the same car. Go to the Synth room as ask what are the sites for sending sample.. i have no clue.. i think that will also be wise.. seeing what the levels of contaminants are before and after..
Respectfully,
Larry
-Larry
thus cost of oil change is
oil filter + labor = 12$
oil 5 quart@4.25 = 21.25
total = 33.25 / oil change.
( i don't even remember what dino oil change would cost!! )
as Chikoo said, its rare i see M1 under $4. But i did see Target I think once at 3.50, some folks have said they've seen it on sale either there or Walmart for cheaper (ocassionally).. Everytime I go in those stores I check to see.. but I've yet seen a store carry the filters..
here's a site that has a study on the different filters..
http://members.nbci.com/minimopar/oilfilterstudy.html
-Larry
anybody have some valuable tips for the 30,000 mile maintenance?
