'95 Nissan Altima Check Engine Light
Will be on if there is something wrong with your engine...
What is this topic for anyway?
When a trouble code is retrieved, for example on the 94 Nissan, the code 33 - Oxygen sensor, Does NOT mean the sensor has to be replaced. It means there is a problem with the the Oxygen sensor circuit. Which could be a plug in,broken wire, or a bunch of other causes.
There are flow tests to determine the cause and problem.
ANY mechanic who says to replace the sensor of the code that comes up,is guessing.
Nissan dealership told me to shut off the engine while filling the gas tank. He said oxygen gets in the tank and the 02 sensor goes off. Also said the light will stay on for about 30 turns of the ignition. Problem has gone away on both vehicles.
Don't let them scam you with expensive bull#%@!
repairs. Try what I said.
Great web site!
Just my uneducated opinion.
As far as the light going off after a certain number of starts, my Accord owners' manual addresses this and says if the light comes on as a result of gas cap related problem and the problem is corrected, the light will go off after a certain number of starts.
The light will stay on as long as there is a problem, if the problem self corrects, the light will go out with in 10 restarts. As fritx said though, the reason the light comes on with the engine running while fueling is because the sensor for the fuel tank. Actually it will say something like this - EVAP Emission System -Small Leak
fritz1224,
I agree with the fuel tank deal. You are right on the money.
tims63,
Although I have never seen that new a vehicle have a problem with a distributer, there could be a module problem. Find out how they determined that the distributor was the problem and let us know. Can you see what trouble codes they came up with?
Also,check this page and it should enable you to retrieve the trouble codes yourself and gives you definitions of the codes. I realize that the system is OBD2, but some Nissans have the capability of giving you the basic trouble codes. But come back and let us know what the trouble codes were.
