Chevrolet Impala Accessories & Modifications
How do I know this? A friend's car failed inspection because of this mod.
Anyone know where there is a kit that fits or knows the sizes?
They have the end links but I need the bushings too.
The bar hugs the car bumper, and it mounts firmly to the car with NO HOLES! Two brackets thru the grill, two in the lower airdam. Does not affect anything on the car. It looks sweet....will try to get pics up ASAP. It can be purchased thru Galls for about $180.
NOTE....this item is for use by law enforcement and it does makes the car look like a squad from the front. Exercise some judgement in regard to your driving habits to prevent a trip to the clink in the backseat of a real 9C1!
The fast way is to take a 1" - 1.5" hole saw and put a hole in the upper floorpan next to the rubber plug. Drill the hole (watching for obstructions), place a rubber grommet in the hole, then run the wires. That's how our unmarked impala's (and mine, now) got the wires in from the engine compartment. Once you have the stuff in, seal the hole with silicon to keep the water out.
It's easy, and still is hidden by the carpet...
I have to wonder why you have a push bar though...
Got any pics? I'll be tossing some more of my car up tomarrow.
No pic's yet, will get to that asap. I like your front LED bar next to your rearview mirror. Is that an original 911 bar, or newer? All blue- that must have hurt the wallet!
It's the newer version, the LS-15. The old LS-15 wasn't worth squat, but this new one is very sweet. Cost me just under 300.00 US and is very nice and useful. People yield quite well to it 'round these parts. Got any pics of yer car?
Yeah, I got the pic's taken, just not on the computer yet...will get to that the next 2 days while I'm off. I'll let you know when/where they are up.
A couple of the guys have those in their cars, and most of 'em have additional lights since the installed lighting is horrible.
mke9c5@wi.rr.com
Price for parts: $25.00
Warm car seat in December: Priceless
http://www.lynoise.com/images/borla/driveHanger.jpg
Also does anyone know the GM Part Number for it?
gw
I checked with my local dealers about a month ago when I saw an LS Sport, and they all said the same:
The PCM's have different programming, the harnesses are different and the (additional) hardware is/would be different to support the cluster. If someone could get around that, I'd be in line behind you to get the cluster. I don't know why they couldn't have done that the first time.
Unknown part number...I didn't bother to ask.
I was hoping that I could just swap it myself and it would work, thinking that it was still sending oil pressure and battery information to the cluster (to the idiot lights) and that maybe the gauges just read that info. Of course nothing works out that simple does it?
If I do find out anything I will post it here.
gw
I think the cluster swap could be done, if the additional hardware was there. From the limited research I have done thus far, it looks to be possible at some point. Get the helm book for the LS Sport when it comes out, get the Sport PCM and a few custom harnesses and make the cluster work. I hope. Don't quote me
When my '02 LS is out of warranty, I may try it.
First, I'm going to do what dg13 did and get a 140 mph Certified speedo for mine. Chevy says you can leave the tach cluster in and swap out the speedo head. We did a certification run on my stock 120 mph speedo, and it was just over 1 mph off of actual speed. Not bad, but I still want the certified one.
dgonzalez13- let us know how the swap goes. It is the spring project for mine.
I posted a warning about this on my site, but I just got another report about it. No word on if the company will correct the problem.
Rather than spend big dollars on a cat-back system it might be a cheap alternative to achieve the look.
Thanx...
This one can be clamped or welded on: http://www.holley.com/HiOctn/ProdLine/Products/ES/ESFT/f59905FLT.html
Here are some others: http://www.hedman.com/pages/hot-tips.html
The one's Nathan posted are just tips..
Did you get the 140 mph speedo in yet?
Also, regarding the steel wheels/caps...chevy will sell you the set of 4 center caps for about $200, and each heavy-duty steel wheel is around $130. I've got a set of wheels coming, along with goodyear UltraGrip mud/snow tires for my winter/hunting adventures. I was just doing backwoods driving with it this weekend, and it is well mannered in the mud without the tires.
It worked great for the most part. The potential problems for me were:
1. Your mileage needs to be synced from the cars computer to the cluster. The cluster will carry over it's original host vehicles mileage on it's display. My 60K mile impala now reads 9970 miles, which is annoying, so i will trry to get it synced this weekend.
2. The Temperastue, turn signals and message center work fine. The Gas needle needs to be reset. I had to fill the tank and drive till almost empty twice before it gave me an accurate reading again. I drive 82 miles a day minumum, so it only took a week and a day to reset.
3. Speedometer now has a top speed of 140, which i would never hit even if i could. I still dont know if it is accurate though. I have to drive by a police sponsored highway radar "Your speed is:" sign to check. Will let you know. All in all, it's a small detail to add, and pretty cheap. I got mine on ebay for $68, so i was pleased. I also gained a little confidence in pulling things apart on the car which i was always scared to do. It was worth it.
Sorry...couldn't resist ;-)
I just returned a set of the caps and the bolts needed to put them on after realizing my black steel wheels didn't have the bolt holes
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1867556686
Maybe you can contact this guy and get more info about how these attach.
bh0001, thanks for the catch on no tires from my previous post. I was typing too fast! No baja with the Impala, but some unimproved National Forest roads in northern Wisconsin. I agree with the ground clearance, but it never bottomed out on anything but grass. I just have to pick and choose a little better then the 4x4's. I may have to look into the full-cradle skid plate for it...
