Aftermarket Heated Seats
I've seen one or two places advertising aftermarket heated seat kits that you can install, either yourself or have done at an authorized dealer. It looks like you peel back the cloth or leather and stick the heating elements on, reattach the upholstery and connect the wiring. Has anyone had this done or know of any links? TIA.
Steve
Steve
http://calgary.shaw.wave.ca/~csobchuk/Comfort_Seat/index.html
Drew
Vans, SUVs, and Aftermarket and Accessories message boards
http://www.rostra.com
Steve
MODERATOR /ADMINISTRATOR
Review your vehicle
Just an FYI.
Ken
http://www.comforthouse.com/winelseatcus.html
Just plug it into the cigarette lighter, and stay warm during cold winter months. Built-in climate control maintains a comfortable temperature. Only $39.99 ($34.99 web price) + shipping.
Cyn
Check the archives:
Recaro seats
Aftermarket seats besides recaro?
I mounted the switches on the center console so there can be no interference with the power seat,
Looks factory installed.
Price was reasonable - $154.00 per seat - and the warranty is one year.
In the winter, you feel heat in about 2 blocks (this through your heavy pants!).
Seriously considering putting them on the front and middle seats of my wife's Dodge Caravan even though they are cloth. Just gets a little pricey if you get 4 of them.
Web address is www.Sportsimportsltd.com.
Took the seat inside and took the molded back off, then opened the hog rings at the back of the seat and the bottom of the back so I could slide the heating pads in between the leather and the padding. The pads have a covering on one side that peels off to reveal a sticky side so you have to do this carefully. Peel down an inch or two and carefully work the pad into the proper position without any wrinkles and slowly peel the paper down as you stick the pads. The enclosed instructions cover this very well.
Then put the hogrings back in.
Drivers seat is the same except you have to disconnect the power seat wiring under the seat.
While the seats are out, fish the wiring harness for each seat under the carpet from the console to the midpoint under the seat (cut an X in the carpet under the seat where you want the wiring to come out). On my car, I removed the storage bin from the console to get to the interior to finish running the wiring and CAREFULLY measured and cut the holes for the switches just in front of the shift lever. Then finish running the wiring harnesses through the front of the console up to the lower backside of the dash and over to the fuse block at the left end of the dash and plug the harnesses in. On my car there were 2 unused fuseholders that I used, however, the harness can be piggybacked into a holder that is already used.
Then put the seats back in, bolt them down, plug in the wiring, and test them out.
As I said, not difficult but somewhat time consuming to do properly and neatly.
Other cars may require going under the floor pan to remove nuts or bolts to remove the seats and other consoles may not be as easy to work on (or may be easier!).
Strongly suggest the shop manual for all this.
Mounting the switches in the seat trim appears to be even easier if the trim will support this.
Mounting the switches in the door panels as on some GM vehicles would be much more difficult plus would require getting wiring harness extensions from Sports Import which would also up the price a bit.
By the way, these pads can only be installed on seats that have separate padding and upholstery. They cannot be installed on seats that are molded in one piece.
I was quoted a price of $635 to have heated seats (driver and passenger) installed in my Infiniti I30. Is this too high? What price range should I be looking for?
Hot options for cold cars (CNN Money)
http://www.ewylie.com/jeep/seatheat.htm
-twylie
I have been satisfied with the product, and it really has exceeded my expectations. They're obviously made with high quality components, and the installer had nothing but great things to say about them. I orignally went to another installer who seemd to only care about doing it quickly, and seemed to only want me in and out as quickly as possible. Be just as careful finding an installer, becuase some obviously care a great deal, and others only care about how much they can charge you. If that's all they care about, they're certainly not going to be using anything other than something cheap! I understand that a good majority of the sat heaters are mass produced in China, but I do believe that the Check Corp seat heater is made in USA. I can't remember for sure, so make sure you confirm this.
I hope this helps!
Tabo
-mike
-mike
Motorsports and Modifications Host
New Hampshire
I am currently looking for an aftermarket heated seat kit that offers both heat and massage. The only 2 companies that I found which offer this is CheckCorp and heatedseats.com. Has anyone had any experiences with either of the 2? I've not heard good things about heatedseatkits.com, but I just want more feedback.
Check it out....and thank god for consumer reviews...
http://www.resellerratings.com/store/Sports_Imports_LLC
Feel free to post your comment there as well.
These seats and all components are made in the U.S.A. 3yr/36,000 mile warranty. Whe I phoned their number I got an answering machine....they got back to me within 30 min. Very impressed with the speedy response and the very helpful and courteous customer assistance.
This is where I have chosen to buy a seat heater for my sweetie's buns. (Did I type that out loud?)
http://www.heatyourseat.com/
I will keep you posted on how they turn out.
:shades:
Interesting to see that people are using zip ties instead of hog rings to put the seats back together.
My friend will be putting them in. He is a top notch auto re-upholsterer.
He assured me that he could put the seat-heater in cheaply, with no trouble, as long as the seat fabric isn't glued to the foam. To check this you just pinch the fabric to see if it is loose or glued. Very important to check this out first, to see if your seat is compatible. The cost would go up if not
I will keep you posted for sure on how it works out.
Take care Steve.
Willi
Bet your friend has a real hog ring tool and everything.
I am curious to see if he declines jobs that involve seat air bags or if he can work around them.
