Difference F250 and F350
                    How much difference is there between and F250 and a F350.  It looks like heavier coils springs in the front and an additional leaf in the back.  It doesn't appear axles, transmissions, engines are any different.  So why the big price difference?
Can anyone set me on the correct path. If so is the GMC and Chevrolet's the same.
Both trucks share the same GVW on the front end so I don't believe there is any spring diff there.
The price diff is only like $400 for 2WD and under $700 for a 4WD CC.
There is a big difference in the front ends of the 4x4 trucks in that the f-250 is an independant front end (unless it is the heavy 3/4 ton package) and the F-350 is a solid front end.
The rear ends are different.The F-350 has a floater axle,which does have a higher load rating.
ALL the 250's and 350's are now Super Duties from Ford. The 4WD 250 and 350 both use the Dana 50 front end rated at 5200lbs. and both use a full floater rear with different spring rates depending on rear GVW. As discussed in a past topic, all current Ford 250's and 350 have the same GCVWR.
And yes, Chevy and GMC are the same... for now. Unless youre talking about the C3
