car can't pass smog
i have a 88 honda accord. it is all stock.
i failed the smog check recently. the problem was excessive tailpipe gas what is the problem? could it be because i haven't changed my oil for over a year?
With that in mind, it's no surprise that it flunked the smog test.
GUARANTEE TO PASS - 19.95 OR LESS !!!!
Or something similar. Now, I'm sure some if not most of these shops were pretty fly by night. They would do the bare minimum required to make the car pass but you WOULD pass.
Throwing a bunch of tune up parts at a car that may or not be needed would be another approach. Even then, the actual problem could well be missed.
The Dyno test (Every three years for cars registered in more populated counties) is much harder to trick and more difficult to perform. Still, a moderately well maintained car of late vintage will almost always pass. When I last had it done the tech said that he had yet to see a single post 1990 Honda or Toyota fail that had not been modified or completely trashed by its owner.
HiC
The above will take you to a quick overview of what is required. The first bi-annual test on new cars is waived, so the first test is when it's four years old. Funny though, check your registration renewal-you still get charged a "smog abatement fee" even if the test is waived! That's California, folks!
Dag gum if it didn't work and I passed the test!! Almost any person with even the smallest bit of Shadetree mechanic in him/her could do it.
Send $19.95 to ls1v8 at.......:)
Still, those quick fix guys didn't necessarilly pull any "tricks" in order to get the cars to pass. These guys were pretty adapt at putting their finger on the actual problem that was causing the cars to flunk. If the car had a couple of bad plug wires that were misfiring and causing the car to fail, those wires (and ONLY those wires) would be replaced.
Just a down and dirty, ie, cheap way to pass the smog test that worked.
On the other end of that spectrum, other shops would throw a lot of expensive and somtimes unnecessary tune up parts at the car to solve the problem.
Still have that last print-out. PPMs for CO and NO2 are over 150 times that of my V8 Landcruiser! And that was a pass!
Anyone want a 67 Cougar? Its exempt now (due to age). I feel too guilty to drive it anymore.
HiC
The shop I managed installed the version that went into the upper radiator hose. I remember they cut off the vacuum advance unless the car was ready to overheat.
These were a micky mouse "solution" that made the cars run like crap.
I'm sure the majority of people unhooked these miserable things as soon as they got home.
Don't feel guilty about driving your Cougar! There are so few polluters like that left on the road that it wouldn't amount to a hill of beans.
