The better bet is to look up what Hyundai recommends be done at 60k using the Edmunds Maintenance Guide and avoid the extra stuff that's not related to your misfire problem.
Another thing you could do before going to the shop is get the codes read at an auto parts store. Most do that for free. You don't need to try to tell the service writers at the dealer their job, but if they tell you something that doesn't jibe with what the codes said at the parts store, you can make further inquiry. Since you know it's a misfire, maybe you already did this?
Confessions From the Dealership Service Department
I own a 03 Santa Fe LX V6 3.5 AWD that has 134,000 miles on it. I recently went to a dealership for the front subframe service campaign and the mechanic told me that the right front CV (tripod) joint (axle) boot is leaking grease :sick: and estimated it at $792.82 plus tax. :surprise:
Does anyone know alternative or cheaper way to replace or fix it? I would appreciate any info.
I too went today for service campaign # 924 (subframe corrosion) and dealer suggest me to replace both front (inner) axle boots as they are leaking grease.
I also have 2003 LX AWD V6 3.5 Santa Fe but I have 94000 miles on it. and my dealer estimated 445$ +tax !!!!
he also said that if i ignore this issue , this might cause axle to break and then it would cost me 1000+!!!
I would also like to know the alternative or cheaper way (looks like mine estimates are cheaper anyways)
I live in Cleveland, OH, does anyone know good mechanic out here.
VG
What did the other dealers say when you talked to them?
What could be the problem?
As time went on, that same problem hit the radio display although the radio and CD player still worked fine. A few months ago, the cruise control stopped working. Recently on the first really warm day this year, a new problem cropped up. An odd one: I'd have a radio station on and then hit a preset button to change the station. Instead of the station changing, the CD player came on and played the corresponding CD. Hitting the Radio button to switch it back didn't always work. Sometimes I have to turn it off and trhen turn it on again to be able to switch back to rasdio. Even after i switch it back it may without me doing anything, go back to the CD.
Now the AC doesn't pump cold air. Maybe it just needs Freon or maybe the compressor isn't working.
It seems like some components are going bad, causing others to go bad. I wonder when it will cause the fuel pump or other systems to go crazy.
Has anyone run into something like what I described?
I should also mention this past spring I took it in for revving issues and they 'took' care it by replacing the spark plugs and something else. n
I know I should take it somewhere else but I worry about driving it - Think it will be ok to drive slowly somewhere else?
I'm new to this website and forum, but I've got nowhere else to turn with this creepy problem. I have a 2001 (or) 2002 Hyundai Santa Fe... can't remember at this time. I bought it used at a not-so-professional "dealership" close to a year ago. Until now there have been zero problems with my vehicle and its functions.
About a week or so ago, I unlocked my car with my key fob (as usual) to retrieve something from my passenger side. Almost a split second later, my car locked itself back up. I had successfully unlocked all four doors and the hatchback before this had happened. At first I thought it was my imagination and let it go. Then a few days later I went to unlock my car to get in and the doors locked a few seconds later; it turns out it wasn't a one-time thing. I had told my Dad about this issue and he seemed stunned, to my suprise. He doesn't really have a clue about what this could be, or what the cause is. And I must say, he knows a lot about cars.
Soooo, I thought the problem was just a willy-nilly thing that happened on occassion, until it happened again today but this time while I was DRIVING! My vehicle is not programmed to lock when it reaches a certain speed. It only is supposed to automatically lock after the twenty seconds or so that I unlock it and don't open any doors, for safety. Today I had been driving for about three minutes and was at a steady speed of 55. All of a sudden my doors lock and it scared me half to death. It frightens me to think that my vehicle could lock itself at any moment, including while I am in it. Not a very good safety habit it has learned I must say.
Could this be a problem with my key fob or my electrical/mechanical system in my vehicle? I'd love to know so I can hopefully have this problem adressed and solved. Thank you for reading!
-Cassie
Are you sure you aren't covered by your power train warranty?
GET another diagnostics from a different unaffiliated source.
Remove the small circuit board from the rubber gasket/button piece. Clean the rubber piece thoroughly. Make sure there is no water or noticeable debri/dammage on the backside of the circuit board. There are two tiny contact switch buttons. Gently press them with your finger nail. They should make a soft click, if not, replace the Fob. Reassemble, and test.
But my question to all Santa Fe owners is this; How much meintenance do you give your cars?
Today I went for the 45000 meintenance service that cost me $435.00, I also got a list of recomendations from the mechanic that involves another $ 500.00. Services such as flushing the oil in the stearing wheel, cleaning fuel injectors, drive line fluid service and ihrutte service. Now, in this economy I can't afford all that work, I would like to know if anyone out there has done all of this work to there cars, the car is in good condition and hasn't have any problems. I think that the dealer is taking me for an expensive ride. If there are any mechanical sabbys out there please help me.
Sincerely
Angela\
NJ
The service department typically works on commission and will try to upsell you stuff you may or may not need.
http://www.hyundaiusa.com/maintenance-schedule/
I wouldn't bother doing anything other than what is on the list for your car's year and mileage since this is what is recommended by the manufacturer unless you are having a specific problem. I hope this can save you some time and money.
This is my first post here on the boards, so thanks in advance for taking the time to help me out! My car is an '04 Santa Fe with a little over 109K miles on it. Just a few days ago I was on the highway when suddenly the engine just seemed to freeze up. I couldn't accelerate no matter how hard i hit the gas, and the car slowly dropped speed the whole time. All of the dashboard lights came on, and the steering wheel felt like it locked up too. I was able to still keep the car running long enough to get to the side of the road, and then I just shut the engine off. I waited about a minute, started the car back up, and I was able to drive off without any other issues.
I'm dropping my car off on Monday for a regularly scheduled oil change, so I mentioned to my mechanic what happened and they're going to take a look at it. In the meantime, I just wanted to get some opinions of what could have caused my car to stall/lose acceleration like that. I've been noticing a general sluggishness in acceleration for a little while now, but this is the first time something like this happened when the car just stopped running while I was driving. Any advice or suggestions would be greatly appreciated!
I will say this, I will never buy another SF or Hyundai again due to all the problems we have had with this vehicle and we are the only owners aside from the dealership that we got it from.
Santa Fe CM
Santa Fe SM
There are three levels of trim on a Santa Fe so that can't be it. Maybe it is 4 cylinder or 6 cylinder?
Anyone know which i should choose for my 4 cylinder GLS?
I own a 2003 Santa Fe LX V6 3.5 AWD which has a leaky automatic transmission cooler in front of the radiator. Does anyone know how much it would cost to replace it?
Thanks in advance.
