Hyundai Santa Fe Maintenance and Repair (2006 and earlier)
13233343537
    edited May 2010
    Cars don't have tune-ups any more and if you go in and ask for one, the service writer will pull out a long menu of stuff that's recommended by the dealer (most of them work on commission).
    The better bet is to look up what Hyundai recommends be done at 60k using the Edmunds Maintenance Guide and avoid the extra stuff that's not related to your misfire problem.
    Another thing you could do before going to the shop is get the codes read at an auto parts store. Most do that for free. You don't need to try to tell the service writers at the dealer their job, but if they tell you something that doesn't jibe with what the codes said at the parts store, you can make further inquiry. Since you know it's a misfire, maybe you already did this?
    Confessions From the Dealership Service Department
    bow45bow45 Member Posts: 21
    Hi everybody!
    I own a 03 Santa Fe LX V6 3.5 AWD that has 134,000 miles on it. I recently went to a dealership for the front subframe service campaign and the mechanic told me that the right front CV (tripod) joint (axle) boot is leaking grease :sick: and estimated it at $792.82 plus tax. :surprise:
    Does anyone know alternative or cheaper way to replace or fix it? I would appreciate any info. :)
    aquavishalaquavishal Member Posts: 2
    Hii
    I too went today for service campaign # 924 (subframe corrosion) and dealer suggest me to replace both front (inner) axle boots as they are leaking grease.
    I also have 2003 LX AWD V6 3.5 Santa Fe but I have 94000 miles on it. and my dealer estimated 445$ +tax !!!!
    he also said that if i ignore this issue , this might cause axle to break and then it would cost me 1000+!!!
    I would also like to know the alternative or cheaper way (looks like mine estimates are cheaper anyways)
    I live in Cleveland, OH, does anyone know good mechanic out here.
    VG
    tinkerbell07tinkerbell07 Member Posts: 28
    I had until recently, a 2001 GLS v6, automatic, bought new. Along with a multitude of other repairs and "issues" I was told by dealership service dept to replace the 2 boots, one being cracked and the other also damaged. I think these guys have a prewritten script of phony repairs they scare people into making - always out of warranty and always expensive. BTW, replacing the boots cost me a little over $300 each. I grew tired of the constant drain from vehicle repairs (you name it, the car needed it, and sometimes the repairs came in multiples of 2 or 3, such as 2 new alternators, 2 replaced oxygen sensors, etc.). Loved the car; hated the constant repairs.
    liviu49liviu49 Member Posts: 1
    my car cut off ,no overheating,no oil in to coolant.i open the head and the gasket looks ok.the top of pistons are a bit damage and their are on the same line????/
    v11lestatv11lestat Member Posts: 4
    If I understand what you wrote correctly, to me it sounds as though you have a broken timing belt.
    jim01128jim01128 Member Posts: 1
    Hi all, I am trying to reattach the windshield mirror and need some help. It looks I would attach the base and then screw the mirror into it? Also there are some wires that attach to the mirror, what do they do and how so I take the mirror apart? The old adhesive seems like a flexible putty, not a glue, what is that stuff? thanks for any help jpb
    r20d12r20d12 Member Posts: 1
    Mine has the same problem. I have found that if I put the shifter in manual and down shift to 3rd it goes away. I think this car has a clutch that disengauges when your foot is off the throttle. I think that the transmission is either rapidly disengauging and engauging the clutch or, it is rapidly shifting between 3rd and 4th. Also, when it first started, the service engine light came on and stayed on for a few weeks then, went of and has stayed off. Try the down shift thing and let me know.
    What did the other dealers say when you talked to them?
    hannahavahannahava Member Posts: 1
    Parts of my dash light are out the speedometer and the tack also one of my tail lights is out brake lights are ok
    kschnickkschnick Member Posts: 1
    We just bought a 02 santa fe with 65000 miles on it and the mechanic checked it out and said it was fine, about halfway home (50 or so miles from our starting point) the engine would over rev and not go over 65, it just stuck at 65 but was in what we believe 4th gear and never shifted over then all the sudden the the car started shaking and the check engine light briefly lit up, then it was fine for another 20 miles then did the same thing, this time the oil light lit up and then went away. Also throughout this 100 mile journey from hell, the radio would change to cd1 then back to am/fm then off (i do not know if this has anything to do with the engine issue)
    What could be the problem?
    somedai1somedai1 Member Posts: 416
    check fluid conditions and levels - worst cases? bad transmission - electrical shorts - computer problem - check to see what those svc eng light coming on was for - that might tell a story - 2002 with 65k miles? not only because it was nicely driven - could be that it had problems an couldn't be driven - hence the low mkileage...
    erguy85erguy85 Member Posts: 1
    While driving awhile back, the manual transmission would not switch out of 2. In an attempt to correct the problem, I disconnected the battery then reconnected the battery. The transmission problem seemed to be solved, but it will barely idle now, and for sure wont drive. It is as if it is missing or out of time. Any thoughts? :confuse:
    followme21followme21 Member Posts: 11
    I am in the process of rebuilding an engine for a 2004 Santa Fe (4-cyl) I am ready to seperated the engine and transmission (5 Speed) from each other. It is acting like something on inside the bell housing where the clutch is is holding them together. I have seperated many manual transmissions but this one has be stuck. Is there something in there thats need disconnected?
    I have disassembled a 2004 hyundai santa fee engine(4cyl, 2.4L) The spark plugs were getting the gap closed on them. When I removed the head every one of the pistons had material missing from them on the right hand side nearly 1/4 of the way around the piston. Looks like the material had just eroded away as there were no big chuncks in there and no other damage. The area was the top land all the way down to the piston ring. Still had good compression. Is this a common problem with these motors or what?
    randys42randys42 Member Posts: 5
    edited April 2011
    I have a 2004 Santa Fe. Some time after 50K miles, the clock display began to shut off. It would stay on when the car was cold...like standing overnight, but would shut down after a minute or two of driving. Then the check engine light would come on and stay on for a couple of days and then shut off. When summer came and it was hot the display wouldn't come on even when the car was sitting idle for a long time.
    As time went on, that same problem hit the radio display although the radio and CD player still worked fine. A few months ago, the cruise control stopped working. Recently on the first really warm day this year, a new problem cropped up. An odd one: I'd have a radio station on and then hit a preset button to change the station. Instead of the station changing, the CD player came on and played the corresponding CD. Hitting the Radio button to switch it back didn't always work. Sometimes I have to turn it off and trhen turn it on again to be able to switch back to rasdio. Even after i switch it back it may without me doing anything, go back to the CD.
    Now the AC doesn't pump cold air. Maybe it just needs Freon or maybe the compressor isn't working.
    It seems like some components are going bad, causing others to go bad. I wonder when it will cause the fuel pump or other systems to go crazy.
    Has anyone run into something like what I described?
    joblackjoblack Member Posts: 11
    I have been having numerous electrical problems with my 2003 Santa Fe GLS for a while now. My clock does not work, nor does my power sunroof or the thing that shows the date. I have also had numerous problems with the engine, but now it seems to be ok and YES, I always kept up w/my oil changes and used Hyundai filters!
    So far my sunroof and the calendar are still working. Did you find out what is causing your electrical problems? I'd like to have an idea of what the problem may be and what it would cost before I take it to the dealer.
    biged99biged99 Member Posts: 1
    edited May 2011
    After having the car at the dealer for a thorough routine service+ for travel from FL to CT, the engine light went on and stayed on. I brought it back and they did their magic and it went off. Then it re-lit and stayed on which I brought it back. They want to replace the purge valve ($250). Messages on this issue relate to engine stalling after filling with gas. I didn't have that problem. Why are they suggesting this repair? Also, recommending brake fluid flush ($110), power steering fluid flush ($110) and coolant fluid flush ($120). Is this necessary given yr./mileage? They also want to replace the original battery for $150, which batteries need to be replaced after this length of time. Does all this sound OK? It has been a great car for me with little repairs so far but am I being taken for a "ride"?
    falmar1falmar1 Member Posts: 12
    Not sure if this helps, but I had, I think, the same problem with the purge valve a few years back. What caused the problem was that when I filled the car up at the gas station I kept topping off the gas to make I sure I got a full tank. It effected the purge valve. I can look at at my repair record to be sure.
    hmarksterhmarkster Member Posts: 4
    For the past 6 months or so, my MIL light has come on every time I fill up my car with gas. I loosen the gas cap and put it back on and that seems to correct the problem, temporarily, until I need to fill my tank again. I have a 2004 Santa Fe 6 cyl. 3.5L engine. I have had my mechanic pull the code for this and it comes up as an evap leak. I have replaced my gas cap with a new one but the problem still exists. I have had the gas cap checked and it is OK (spent the extra money to buy it from the dealership to make sure that it is the correct part for my car.) I stop filling when the gas pump shuts off (I originally thought the problem was caused by topping off the tank so I make sure I don't do this, and I always make sure I put the cap on tightly as I know this could also cause the problem.) I was told by my mechanic that there is really nothing they can do except replace the gas tank nozzle and that may not even correct the problem so I should just deal with it until the light doesn't go off after replacing the gas cap. It usually comes on the day after I fill up my car and after replacing the cap will take about a day to go out. This was a major concern when I needed to get my new tags as my car wouldn't pass emissions with the check engine light on. I had the mechanic reset the code and I didn't fill up the tank until after I had passed emissions, so that is no longer a concern. This is more an annoyance than anything else and I was wondering if anyone else had this problem and what they did to fix it or if there is even a fix for this.
    santos3santos3 Member Posts: 1
    I got a code on the OBD-2 pointing to the MAF as the problem on my wifes santa fe becuae it had been sputtering. So I took it off cleaned it put it back on and when I tried to turn the car on it wouldnt turn over all that would happen was the lights would go dim and flash. Has this ever happened to anybody because Im really at a lost. Could really use some help.
    are you sure you didn't drain down the battery? Make sure it's fully charged. And make sure the maf is dry before you try to start...
    otto595otto595 Member Posts: 4
    I have a 2004 Santa Fe that had the same problem. My mechanic said that this is a common problem due to the poor design of the evap system. The problem occurs when your fuel tank is overfilled. The gas is too high in the filler neck thereby causing fuel to flow into the charcoal (EVAP) canister. A defective refuel and/or fuel cutoff valve would could cause this problem. It's possible that your charcoal canister was saturated with gasoline too so that may need replaced.
    ahmal1ahmal1 Member Posts: 1
    I have a 2004 Santa Fe with 97000 miles on it. My check engine light went on last week and I took it to the dealer. They told me I had a cracked manifold and needed a new O2 sensor. I had to pre-order the O2 sensor $150. I went on vacation and took the car in today. It had not been driven the past week - and was acting weird as I drove to the dealer. It was revving at 5000 rpms before it would sift around 20 - 25 miles (it is an automatic). I mentioned this to the dealer, they hooked it up and found out I needed a new catalytic converter. They quoted me at 2400 for parts and 3100 with labor for the catalytic converter - and I still 'need' the manifold and O2 sensor. This sees outragous to me- any ideas? Does this seem like a lot?
    I should also mention this past spring I took it in for revving issues and they 'took' care it by replacing the spark plugs and something else. n
    I know I should take it somewhere else but I worry about driving it - Think it will be ok to drive slowly somewhere else?
    cassierosebcassieroseb Member Posts: 1
    Hi there,
    I'm new to this website and forum, but I've got nowhere else to turn with this creepy problem. I have a 2001 (or) 2002 Hyundai Santa Fe... can't remember at this time. I bought it used at a not-so-professional "dealership" close to a year ago. Until now there have been zero problems with my vehicle and its functions.
    About a week or so ago, I unlocked my car with my key fob (as usual) to retrieve something from my passenger side. Almost a split second later, my car locked itself back up. I had successfully unlocked all four doors and the hatchback before this had happened. At first I thought it was my imagination and let it go. Then a few days later I went to unlock my car to get in and the doors locked a few seconds later; it turns out it wasn't a one-time thing. I had told my Dad about this issue and he seemed stunned, to my suprise. He doesn't really have a clue about what this could be, or what the cause is. And I must say, he knows a lot about cars.
    Soooo, I thought the problem was just a willy-nilly thing that happened on occassion, until it happened again today but this time while I was DRIVING! My vehicle is not programmed to lock when it reaches a certain speed. It only is supposed to automatically lock after the twenty seconds or so that I unlock it and don't open any doors, for safety. Today I had been driving for about three minutes and was at a steady speed of 55. All of a sudden my doors lock and it scared me half to death. It frightens me to think that my vehicle could lock itself at any moment, including while I am in it. Not a very good safety habit it has learned I must say.
    Could this be a problem with my key fob or my electrical/mechanical system in my vehicle? I'd love to know so I can hopefully have this problem adressed and solved. Thank you for reading!
    -Cassie
    ella1128ella1128 Member Posts: 1
    I have a 2002 Sante Fe and recently it has started making this loud ridiculous sound like as if the engine is about the explode, it wont accelerate when its making this sound and after a few miles of driving through the sound it just stops. Im also having a problem getting up to speed, if I come to a stop or try to accelerate quickly it really lags and takes about a mile or two to really get up to speed. It also makes this LOUD ticking sound when I first start my car and after its been driven a few miles that sound goes away. My Dad replaced the power steering pump thinking that was the problem but its just seems to get worse and worse every day! It has 145,000 miles on it, I bought it used 2 years ago with 100,000 and drive a long haul to work. Has anyone else had this problem or even heard of anything close to what I am explaining???
    The 2004 Santa Fe has a 100K warranty on it if you kept up up scheduled maintenance. Mine acted similar to yours although it was running at almost no power. The shifting problem was transmission related and covered and it needed two manifolds. One was also part of the power train coverage but the more expensive manifold was about $1600. I also had a bad O2 sensor. The sensor and manifold cost about $2500 total. The manifold part was about $1100. I'd call other Hyundai service centers and see their prices. The catalytic convertor shouldn't affect the transmission not shifting.
    Are you sure you aren't covered by your power train warranty?
    I never had any responses or clues as to what may be causing my electrical troubles. They get worse as the weather gets hotter.
    mas15mas15 Member Posts: 2
    Ask them to show you the crack in the manifold. When they messed with the cables/linkage that traverses over the manifold, It is likely they did not reconnect them properly. This would cause your your vehicle to run at high rpms. Based on your reported issues and description of what the dealer said...I would be highly suspicious of their ethics and competence or both.
    GET another diagnostics from a different unaffiliated source.
    Check the FOB first. Use a small coin or flat-tip screw driver and gently pry open the Key Fob. There are two indentions along the side seam for this purpose. Once open, inspect the battery and button contact points for corrosion, dirt etc. Clean off any rust or debri. Slightly bend up the three battery contact prongs.
    Remove the small circuit board from the rubber gasket/button piece. Clean the rubber piece thoroughly. Make sure there is no water or noticeable debri/dammage on the backside of the circuit board. There are two tiny contact switch buttons. Gently press them with your finger nail. They should make a soft click, if not, replace the Fob. Reassemble, and test.
    angiemaritzaangiemaritza Member Posts: 1
    Hello everyone today is my first time in this forum. I have a Santa Fe 2006 it has 48600 miles in it and I have to say that up until today the car has been great. It survived a head on collision 6 months ago and I think the car's structure helped out a lot in me not getting severly hurt.
    But my question to all Santa Fe owners is this; How much meintenance do you give your cars?
    Today I went for the 45000 meintenance service that cost me $435.00, I also got a list of recomendations from the mechanic that involves another $ 500.00. Services such as flushing the oil in the stearing wheel, cleaning fuel injectors, drive line fluid service and ihrutte service. Now, in this economy I can't afford all that work, I would like to know if anyone out there has done all of this work to there cars, the car is in good condition and hasn't have any problems. I think that the dealer is taking me for an expensive ride. If there are any mechanical sabbys out there please help me.
    Sincerely
    Angela\
    NJ
    The Edmunds Maintenance Guide will tell you what Hyundai recommends be done on your Santa Fe and how much it should cost.
    The service department typically works on commission and will try to upsell you stuff you may or may not need.
    You can also check the Hyundai website for maintenance schedules. You can find that here:
    http://www.hyundaiusa.com/maintenance-schedule/
    I wouldn't bother doing anything other than what is on the list for your car's year and mileage since this is what is recommended by the manufacturer unless you are having a specific problem. I hope this can save you some time and money.
    randy102randy102 Member Posts: 1
    My wifes car did the same. I went to the HMA website and they stated that the most common problem is the fuel pressure regulator. Sometimes it would smell like gas also. The instructions were, take off the hose that runs from the fuel pressure regulator to the manifold. Check the end of the hose to see if gas is leaking through, if it is, it is the fuel pressure regulator going bad. I checked this on my wifes vehicle and it was as described with fuel leaking out the end that attaches to the manifold. I bought the part at the dealer for 79.00 and replaced the old one in about 5 minutes. The car starts right up on the first turn and no more gas smell. This is a common problem with 2001-2003 Santa Fe's
    eterrieneterrien Member Posts: 2
    Thanks! Finally someone who offers something informative.
    rosebermroseberm Member Posts: 1
    02 santa fe-108K mi. In the past year I am getting a whining noise is the steering and when in park/neutral turning the wheel produces a lower pitched whining. Does not happen on start-up. Dealer could not reproduce noise. Transmission/power steering unit ruled out as causes. Hyundia tech thinks it may be the steering pump. Anyone ever have this problem? thanks
    radde4radde4 Member Posts: 1
    I just took my 2004 Santa Fe in for this very same problem, waiting for the bad news, because I'm not the original owner. I bought it off my parents last year. Hyundai said that makes the warranty null and void. Ugh!
    psujohnnypsujohnny Member Posts: 1
    The problem with mine was the Vehicle Speed Sensor. It is located under the battery box on top of the transmission. Once I figured out where it was it was an easy fix and a lot cheaper than taking it to the dealer. My Santa Fe would shift very hard (almost a loud clunk sound) and then would not change gears. If I turned off the engine and start it again the check engine light would be on, but the transmission shifted normal... until the next clunk. Relaced that part and it has been fine since.
    bhancock47bhancock47 Member Posts: 1
    my 02 hyundai santa fe (140k miles) runs beautifully until it gets to about 50 mph, then chugs out, deaccelerates, and settles back to about 40. any suggestions?
    hn78hn78 Member Posts: 1
    Hi all,
    This is my first post here on the boards, so thanks in advance for taking the time to help me out! My car is an '04 Santa Fe with a little over 109K miles on it. Just a few days ago I was on the highway when suddenly the engine just seemed to freeze up. I couldn't accelerate no matter how hard i hit the gas, and the car slowly dropped speed the whole time. All of the dashboard lights came on, and the steering wheel felt like it locked up too. I was able to still keep the car running long enough to get to the side of the road, and then I just shut the engine off. I waited about a minute, started the car back up, and I was able to drive off without any other issues.
    I'm dropping my car off on Monday for a regularly scheduled oil change, so I mentioned to my mechanic what happened and they're going to take a look at it. In the meantime, I just wanted to get some opinions of what could have caused my car to stall/lose acceleration like that. I've been noticing a general sluggishness in acceleration for a little while now, but this is the first time something like this happened when the car just stopped running while I was driving. Any advice or suggestions would be greatly appreciated!
    skgharstskgharst Member Posts: 1
    I have a '01 Santa fe, w/ 17620 miles, 2 weeks ago I had the alternator & battery replaced.Today while I was out I noticed that rear light were on & the switch was off.When I got home, I checked I have blinkers, tail lights, backup lights, but no brake lights when the pedal is depressed.If I pull the fuse the lights go off, but I still have no brake lights.Checked all the appropriate fuses and none are blown.Husband is checking light bulbs but any other suggestions.
    tsfe4tsfe4 Member Posts: 1
    i have a 2003 sante fe v6 with 108000 mi. it ran fine this morning but will not start this afternoon. turns over but that is it
    doderdoder Member Posts: 1
    My 04 SF 3.5 has been battling this for over 2 years. At first we thought it was tire balancing, old tires, etc. Nope. I took it in yesterday to dealership and was told it is a problem with the "transfer case" that it is failing. Not good news obviously as that can kill the whole tranny at total failure.
    I will say this, I will never buy another SF or Hyundai again due to all the problems we have had with this vehicle and we are the only owners aside from the dealership that we got it from.
    jaaaaajaaaaa Member Posts: 1
    If you have a 2.7 engine, I'd check the CPS(crankcase position sensor). This sensor is located just above the starter. It is a common problem with the santa fe and will cause the car to jerk/stutter/completely shut off/ and stall at stop lights. What happens is that over time the rubber cable that holds three wires coming out of the sensor, breaks down-falls apart- and the insulation also cracks and breaks down leaving three bare wires dangling as you drive along. At some point(totally random) some bump in the road will short out two of the wires and your car will stop working(sometimes just for a short period). Most of the time you can restart your car and then drive off. If it becomes bad enough, the shorting wires will totally kill your car. To replace the CPS($75) from the dealership- take off skid plate, Take off shield cover of starter(by taking off two bolts and a nut, rotate 90 degrees and remove towards driver side). Sight from around the oil filter back towards and above the starter. That is where the CPS is located. It can be removed by using a 10mm 1/4 inch drive socket with small extension. You can't use a 3/8 inch drive because the clearance is too tight. Only one bolt holds it in. Will take a couple hours to replace because it is very awkward to get to on your back in a driveway. Fixed my 03 santa fe that had this problem for over five years last month. Couldn't believe how badly the cable and wiring had deteriorated just past the sensor(maybe an inch and a half of bare wires). Looks to me like it was badly designed as far as the materials used to make the sensor. Anyone that hasn't changed out this sensor after 75k miles should do it asap. Could save you a tow and a ton of money.
    edited December 2011
    This is also a problem with a faulty EGR valve (Exhaust Gas Recirculation valve). I'm having to replace mine now. Although I don't have the problems you are having, my research on the EGR valve has shown that your symptoms can be caused by this valve. Check with your dealership as there is a Technical Service Bulletin (10020878 / 0636006) for this part issued in December of 2006. My problem is that it is leaking and causing the Check Engine light to come on. Over time, if not repaired, it will cause stalling when you stop the car and poor acceleration.
    barmaid1barmaid1 Member Posts: 1
    I have had a 2002 and now have a 2004 Santa Fe..in regards to your back seat, make sure your gray straps are always visible..pull them forward so your seats can be pulled flat down on both sides..next take off the head rests which has a small slide that you push and at the same time slide the head rests up..on the sides of the back rest is a lever that you push or slide at the same time to push the seats down..they will be somewhat flat, just make sure there is nothing in the seats or the floor to harbor your quest...also I have noticed on my 2004, radio it will play the radio but not show..just gently tap the screen and it will pop up..do not now why it is doing it but having it checked with dealer soon..hope this helps..have my own questions on edmonds regarding my gas tank...seems to be leaking..any one else with problems please post...any help would be greatly apprciated!
    kdconodkdconod Member Posts: 53
    When one tries to register for Hyundai's service site (www.hmaservice.com), they ask you to state what vehicle you have. For the Santa Fe there are only two choices:
    Santa Fe CM
    Santa Fe SM
    There are three levels of trim on a Santa Fe so that can't be it. Maybe it is 4 cylinder or 6 cylinder?
    Anyone know which i should choose for my 4 cylinder GLS?
    tucsonnativetucsonnative Member Posts: 1
    I just noticed that the left side of my 2004 Santa Fe GLS 3.5 has gone dark. The parking, tail and both side marker lights went out. The turn signals and flashers still work. Has anyone else experienced this.
    Hi all,
    I own a 2003 Santa Fe LX V6 3.5 AWD which has a leaky automatic transmission cooler in front of the radiator. Does anyone know how much it would cost to replace it?
    Thanks in advance.
    kkbuehrer79kkbuehrer79 Member Posts: 1
    Did you ever find the problem, mine is having the same problem with the 2.7L 4WD Auto.
