Without the rack they look very van like.
Since the rack is very small & short I
doubt if they really are very useful.
1matrix
If you are the type to top it up and top it up until it flows down the side of the car, then you probably have an extra quarter of a gallon in the filler neck...
I have 7,250 miles on the car. I bought it new on July 1 '02.
I always fill up my fuel tank whenever the emply warning light come on.
The TRD supercharger is fully warranted by Toyota if it is installed by them, so I am sure it would be the easiest thing in the world to find out if its application to the 180 hp engine voids the powertrain warranty.
I haven't tried letting the tank go to empty, because I read that that can damage the catalytic converter. I'm pretty confident that my warning light is working properly, so for peace of mind, I'm going to assume that I do have some reserve left, even if it's not the usual 2 gallons.
Maybe an inquiry with Toyota is in order.
1matrix
They will have given you a separate booklet specifically for the Toyota alarm system if that is what you have. Other alarms work through the keyless entry, so just because your key fob says "Toyota" does not mean the alarm is factory.
If it is in fact the VIP3200 factory system, it can be set to be mute, or to make soft beeps when it is engaged/disengaged. it is easy to set - read the little booklet.
Revka
Hatchbacks & Wagons Host
Sounds like this "Extra Mile Package" is a collection of dealer installed accessories. Do you still have the Maroney sticker? The factory MSRP-manufacturer's suggested retail price--is listed on THAT and only THAT sticker. It includes all the FACTORY installed accessories.
Look to see if the "Extra Mile Package" is on that sticker. If it isn't (and I doubt that it is), the dealer may or may not have installed a factory alarm. It may be an after-market alarm. Then again, most after-market alarms do provide audible feedback, seemingly, the less expensive they are, the more intricate and loud the feedback!
How much was this "Extra Mile Package?" Does it appear in the car's brochure?
When you go to the Toyota web site and put in your zip code it takes you to different 'Build your own' web site and pages depending on where in the country you are. Here in New England you get the generic Toyota package of options since there's no single distributor for Toyota for this area.
But if you try 75001 ( in Addison, Texas ), you go to the Build-Your-Own Toyota site run by Gulf States Toyota for the Gulf States Distributorships which I think include Texas, OK and LA.
These folks put lots of stuff on Toyota's in 'port', i.e. a central location where they add options to the car after they get it from the factory.
Some of these options are good deals, like your leather seats. Others may be. Some are very questionable, like the VIN etching, fabric protectors, etc.
When you go to the Gulf State Build Your Own, the Extra Mile Package is right at the top of the list.
This is where the Extra Mile package was put on your car and why it's likely you don't have the factory installed Security option, though it could be the same thing put on by the folks at port.
I hope this helps.
I bet you are exactly right, footie!
It is almost certain that they did not install the Toyota factory alarm at the port. Those are usually aftermarket systems.
Why does Gulf States Toyota love pinstripes so much? Every Toyota south of the Mason-Dixon line must have a cheesy stripe on it!
The real issue is that the dealerships in these zones are really front's for the distributors. It would be instructive to learn whether Toyota USA gave these distributors a permanent franchise in those parts of the country or not.
If you live in Texas or OK you should go buy your Toyota in St. Louis and drive it home.
Even if you have problems (not very likely), you can always go to a local Toyota dealership and say you just got transferred. They'll never know...
If you live in the SET zone, well, try Virginia or Kentucky.
It's cheaper in many cases to go to a far away dealer, order a car just like you want at a few hundred $ over invoice and drive it home instead of buying one locally that's been stuffed and striped and pampered with useless options like VIN etching, upholstery protectors and special waxing. What year do these people think this is? 1975 or something.
Good luck to all in those parts of the country!
...imacmil: rattles and buzzes are everywhere in this car. They come and go, some are more consistent than others. After three tries I have given up trying to have the dealer fix them. There is just far too much plastic (hard plastic at that) in the interior of this car - it is bound to vibrate.
Is there a reason for this ? Normal?
Also I now notice a wind noise at 50mph+...
I can not tell if it is from the bottom or top of the windshield, maybe wipers at rest ????
I did notice the top of windshield sealer strip has an empty notch... could this be source of noise ? I do not think it is the moonroof.
At first I thought it was being 'transmitted' by the mesh sun screen at top of windshield.
I have already put carpet in the 'wayback'.
Think I will put the felt under the lift up door.
Probably should cover back of rear seats as well.
Thanks, you guys are my online manual !
If you are used to letting the twilight sensor turn the lights on for you, then you should be aware that it takes 15-30 seconds after the car has been running for this to be triggered.
You can also turn on the headlights in the normal way when it is dark - by using the switch on the turn signal stalk. This will trigger the interior lights I mentioned.
Is that what you meant?
I have 4WD Matrix XR with 8K miles. No problem yet. I tested my 4wd and abs. They seem to work just fine.
How do I turn off my headlights at night while the engine is still running??? There has to be a way that I can override the light sensor at night!
DVD9
Gotta hate twilight sensors...
If you haven't started the engine yet:
1. Pull the parking brake.
2. Start the engine.
3. Lights and DRL won't go on until you release the parking brake.
4. Don't forget to release the parking brake when you're getting ready to move again.
If you're already running the engine and the lights are already on:
1. Turn the car off.
2. Follow the steps above.
AND if you're just looking to drive at night with the headlights off, you're dumb and don't deserve an answer.
There are many reasons to want the lights off at night; I had the system on a '98 Prizm, and while I recognize that it has some value, and I never had to worry about accidentally leaving my lights on, I hated not being able to turn them off... Say you're turning into your driveway at 03:00 adn don't want to wake your family or the neighbors off. Say you're pulling into a campground at night. Say you're approaching a military base and you're required to dim your lights.
I do not like them, Sam I am...
Peace.
-Mathias
East Lansing, MI
At a drive-in movie theatre, I want to be able to turn off my headlights at night with engine running. It really sucks if I do not have this ability to override the light sensor.
dvd9
I so wish there were a fuse you could pull to just kill the twilight sensor altogether, while leaving the operability of the headlights intact.
I followed your procedures and it really works.
yes, there are still drive-in theaters in the good old usa. Now I dont have to use a blanket to cover my headlights in drive-in theaters.
Glad I was able to help.
Not telling the insurance company that you have added a supercharger may be construed by them as fraud, and reason to deny claims. If you don't wanna pay the freight, don't install it.
three honks of the horn. This let met know that it had been set off.
As I walked to my door I noticed a 2 inch high door ding about 1/4
inch from the lead edge on the passenger door. After arguing with
the drunk lady in the GMC Envoy next to me (ends up she was too
drunk to go inside with her brother, got mad and tried to get out,
slamming her door into my car) I called the police. Yadda yadda
yadda, they cited her for reckless damage. The driver (a very nice
old gentleman) and I exchanged information and went our own ways.
The body shop said there was $380 of damage! Due to the location of
the ding (1/4 inch from the edge of the door) Paintless Dent Repair
couldn't be used. Worst of all I have a Saturn SL2 as a loaner. This
car is horrible. I have owned 3 Saturns and don't remember any of
them being this horrible. I only had 680 miles on my Matrix. The car
still has the temporary tags on! This is one thing I worried about
with this car, since it has no "rub strips" on the sides. This could
be the begining of a long relationship with the body shop for door
dings.
