Visitor Agreement.
If I do anything, it'll probably be the "drop and drain". I knew I heard of problems after some people got the power flush.
Deke
I tested my blikers today on the ride home form work and they were blinking fast with no light showing but the DRL is still lit. Also the light does not work when you hit the hazard button. I won't get a chance until Friday to check out the connections.
The 500 had the CT and did I hate that tranny! For the car itself, it lacks any refinement in materials, but the chassis seemed good and the handling was all familiar to Intrigue owners, but smoother. It deserves a decent engine, which it hasn't. It was quite roomy and really quiet.
The La Crosse was very refined, not your average Buick. The chassis was excellent and the new 3.6 V6 is the fusion of the qualities found in the 3.8 OHV and in the 3.5 DOHC, a home run. The handling and ride were excellent, very quiet, but the rear seat was cramped. Fit, finish and material quality were below only Cadillac in GM's line up.
I went down to AutoZone and got a replacement bulb, this time they had the 4157. I put that in the socket and i could see the connectors are different even though they both fit in the socket. The bulb which i replaced ssaid 3157NAK. So far it is working properly.
Just a word of caution, do not use anything other than 4157NAK for your turn signals bulbs. The 3157 will work temporarily but eventually it will cause problems.
I bought a new set at http://gmpartsdirect.com for about $100, but the replacement procedure looked daunting to me, so I'll probably ask the dealer to do it.
Awhile back I posted re this bulb# issue. See link below hope it works, took a bit to find it. You can scroll back and forward from that post9796 in the other intrigue forum, to get the gist of the banter that was going on.
moonshadow, "Oldsmobile Intrigue" #9796, 26 Jul 2003 4:02 pm
The Sylvania link doesn't link anymore, they giggled there site around. I did some looking there and found something similar here. http://www.sylvaniaautocatalog.com/new_sylvania/ProductBrowse.asp- - - ?Batchid=9&FigNumber=27
I also found that sylvania pdf file on my drive. The stuff one keeps. It is a little clearer as it shows actual colour bulb photos as well as colour indicators in the layout that makes it more user friendly to get the big picture.
cheers
Or perhaps the molding that acts as a squeegee at the base of the movable window
cheers
HTH
My.02 worth.
10446537 Molding, Belt L
Those outer moldings are very easy to replace, but you need to be careful not to damage your finish. Once you did one side , the other could be in and out in 10-15 minutes. The inner belt seal needs to have at least the top part of the door panel pulled back from the door. The inners just push down on a strip of metal and held there by the upper curve of the door panel .
The outers are held in place by a friction fit(rubber wedges in the molding to the metal edge of the door) and one screw. When you get the new ones you will be able to see the setup.
The screw for the rear is located just inside the door where it meets the front door at the pillar. The front is also near the same pillar. A black screw with a phillips head (or a plus screwdriver when I'm helped by da wife lol).
The other end is interlocked with the molded curved bit and the back of the door.
Once the screw is out, it is a matter of working it loose. It is easier to get a grip if the window is down.
You need to lift up at the pillar end and while tilting it away from the window by say 20 degrees. A small flat tool may be needed to get it started, depending on how stiff, cold, stuck it is. Be sure to support the tool with a cloth or thin piece of rubber.
Then after you have it up an inch or so, work your way down to the back by lifting up and away from the glass . Then pull it out under the fixed window seal and out of the interlock from the curved piece. It is in there about 1 1/2 inch.
Replacement has to be slid under the fixed window bottom rubber seal and then pushed down and replace the screw. If you are having a tough time sliding it in under the small glass, try a smear of vaseline etc. on the metal edge of the door, but not along the whole door as the friction fit will be diminished . After you think it is down, try giving it another push while rocking and it will probably seat in a bit more.
The front is similiar but sneeks under the mirror for about six inches. A little more fiddling/ trickier, but patience wins the day.
cheers
1999 Oldsmobile Intrigue
Sealing Strip Replacement - Rear Door Window Belt Outer
Removal Procedure
Lower the rear door window.
Remove the outer belt sealing strip screw.
Remove outer belt sealing strip from the rear door pinchweld flange, by pulling the sealing strip upward.
Installation Procedure
Install the outer belt sealing strip to the rear door pinchweld flange align the sealing strip with the screw hole. Press the strip into place until fully seated.
Install the outer belt sealing strip screw.
Tighten the outer belt sealing strip screw to 1.5 N·m (13 lb in).
Raise the rear door window.
Document ID# 537671
Sealing Strip Replacement - Rear Door Window Belt Inner
Removal Procedure
Remove the door trim panel. Refer to Trim Panel Replacement - Side Rear Door.
Remove the inner belt sealing strip, by lifting the sealing strip off the pinchweld flange.
Important
Ensure the front end of the inner belt sealing strip is inserted into the gap formed by the weatherstrip and the door inner panel.
Ensure the rear end of the inner belt sealing strip is flush to the rear leg of the weatherstrip but not interfering with the path of the window.
Install the inner belt sealing strip to the pinchweld flange. Press the sealing strip into place until fully seated.
Install the door trim panel. Refer to Trim Panel Replacement - Side Rear Door .
Raise the window.
I post rarely, but read posts often.
This morning on the way to work, it started snowing. As I took off from a red light, my wheels (99 GL) began to slip in the snow and the "Low Trac" light came on, as it should. But not only did the power to the front wheels cut off, the engine cut off all together! Has anyone else experienced this?
This was a potentially dangerous situation as I was on a high traffic route. Luckily, the person behind me understood and did not honk the horn.
BTW, I have the 3.5 with just over 86K on it.
A new problem on the horizon, I find that my transmission decides to shift hard from time to time. I feel a real clunk when upshifting. Downshifting remains smooth. This happens only occasionally and only after driving a while. Could I need a tranny fluid change? I had one around 50K, could I need another one already? I'm at 86K.
Thanks all, and glad to see the Intrigue board still alive almost three years after the end of production of a not very well known car model.
Frustrating because I have not had any problems with my GLS ('99, 3.5, 110,000 mi) until I hit 100,000 miles. Then all of a sudden the shifting problem starts and then it stalls two or three times while slowing into a turn. Also had to replace a couple fuel injectors. I've starting looking for a new vehicle which is too bad because the car is in great shape.
Bad gas? I don't think I would go back to that dealer. If you do research you will find GM bulletins on this subject (no $$$ help).
On the positive side, the new injector seems to have cure the rough cold starts.
Two small problems I've had since new that I haven't seen on this board:
1. Cruise control holds speed steady but not the throttle, which constantly changes a little bit--just irritating enough that I can't stand to use it. Am I too sensitive? I didn't want the dealer to mess with it when it was new--in my experience, after the dealer plays with the engine, something else breaks right afterward.
2. The rear suspension(?) makes a soft honking sound at takeoff and very low speed bumps, louder in warm weather (I don't think it's the trunk hinge problem). Just makes the normal shock hiss when I jump on the bumper. The dealer replaced something that squeaked loudly back there when it was new, I forget what.
After reading this board and some of the main one, I guess I've been luckier than some, but I've never liked the car as much as my old Bonneville SE, although it's better in all respects except ride comfort. For a few years I really hated it, but couldn't find anything much better. Now I might as well drive it into the ground. Does anyone know if GM is likely to extend the 12/05 expiration on the $1000 "Death of Olds" credit?
Bottom line: it's a design characteristic or fault, depending on one's point of view.
I remember years ago driving my Cherokee through the mountains on a gravel road with the window open. Heard this loud rattle from the front brakes and was very worried. Turned out to be nothing, the combination of the road and having the window open made it seem much worse than usual. I wouldn't worry too much about it.
Then again, I need to clean the TB on mine...
It's especially odd that this would fail since we almost NEVER roll down the rear windows. For all I know, it might have been inoperative for a year or more :-). Is there any history of power window problems on this model?
A former co-worker had an early prouction 98 GLS and had the same problem - turned out to be a crimped wire that shorted out on sheet metal from time to time.
Deke
Well. not quite. gordon. the switches are in series basically and if the door switch at the rear is flaky or a bad plug connection then the master will have no affect as well.
Each up/down window switch is actually two separate contacts controlled by a single lever.
Before you tear the regulator/motor out :
The switch in the rear is removed by lifting up, with a slight jerk, from the rear or the switch plate. The forward part of the switch plate is hooked under the panel. If you like, you can swap it for the other side, quick elimination of the rear switch.
UNPLUG the switch. Get yourself a meter or someone who has one, check for DC volts at the purple and dark green wires at the plug coming out of the door panel, ignition Key to Acc.
When the master switch for that window is activated up/down, you should get +12volts in one direction and -12volts in the other.
***If you don't, then you have a bad/dirty master switch or a broken wire somewhere along the line to the rear.
Next measure from chassis ground to the blue wire in the middle of one row. (There are two blue wires, go figure). You should have 12 volts when the lock out at the master is not engaged , 0 volts when it is.
***If not, then the master lock switch is defective or a broken wire/corroded plug from the switch to the rear switch. This will cause the master to work but not the actual door switch.
Next, remove key, and measure for resistance between the brown and other blue wire(they are direct from the motor). They are in opposite corners of each other in the plug. You should get around 1 to 2 ohms.
***If you don't then the motor brushes may be sticking/corroded from lack of use. Sometimes a rap on the motor case will get it going, but the door panel needs to go to get to it.
That will eliminate the electrical portion of your problem. If the cable regulator is seized or jammed, then you are down to a mechanical replacement. I have, on occasion, repaired some with lubrication and or dissembling the motor to repair stuck brushes. However, not on a never Gm lately.
Remember that anything on a car that does not get used, ... gets stuck.
cheers gordon, hope you get something out of this .
Hey there,
i have a 2000 GLS and put the car in the trans shop back in october due to hard shifts up and hard shifts back down once i took my foot off of the gas pedal. Well it has been in the shop every week for 2 months now. At first, check engine lights were coming on because torque convertor was bad and now i am back to the beginning with the hard shifting issues again. it almost feels like someone is rear ending me when it happens. they have rebuilt the transmission now twice and replaced the valve body.
Also when accelerating once the car first starts for the first 10 minutes or so, when i push the gas pedal the engine revs and the rpms go up, but i don't move any faster. It's like i get stuck at the same speed no matter what. The shop replaced the throttle positioning sensor and it hasn't helped.
i really like my intrigue and it's a great car (other than the turn signal lights not working half the time) When the car is working properly, it is such a great, smooth ride. If anyone has any advise or knows what else may be wrong, i would greatly appreciate the info. ( i still like my car better than any of the sedans out there today!)
Now, about the front moldings, the mirrors press over them and although it looked like removing the moldings without removing the mirrors could be possible, sliding them back in didn't look possible without damaging the moldings.
In order to remove the mirrors, it's necessary to remove the door trim panels, which requires new fasteners when reattaching them.
In face of this, I'll gladly pay an hour's worth to a dealer to replace the front moldings.
;-)Yes the fronts do look like they may be more difficult to slide back in. However, If I remember correctly(can't be sure) they will slide/rock in under the mirror. I believe the first 4 inches of the inside of the molding is cut away on one side for this purpose.
Either way, if you have finesse, you can remove the mirrors partially on a trig without removing the panel. You have to pull the triangular tweeter cover away. It is connected to the door panel at the bottom and it is snapped in with a metal spring clip near the top.
Once the little cover is angled back from the top, you can use a 10 mm (i think) box wrench to lossen the 3 nuts off to rock/wiggle the mirror out of the way.
Do not over tighten the nuts. Do not let the nuts fall into the panel. Also I believe the mirror electrical plug is behind the panel down several inches.
Either way the panel can be removed rather easily if you have a forked door panel clip remover or a resonable makeshift. The trick is to pry up on both sides at the same time. I've found them to be reuseable if they come straight out from their holes. Also those barbed pins/clips are more breakable if they are cold. The window switch plate snaps up by lifting at the back of it. There is a torx bit behind it and one on the door pull. Plus a srew behind the snapped in plate on the unlock handle.
Not sure how much info you need, so i tried to list all i could remember..
cheers.
:-)I still think it's possible without removing the panel. Of coarse, everything is easy if you've already done it before.
Although, a cheapy forked door panel tool can be picked up for a few bucks at some discount auto stores and will surely come in handy someday.
It does make it much easier. :-)
Cheers
I suggest trying www.gmpartsdirect.com or just calling a local GM dealer's parts dept. Let us know how much you end up getting the part for.
Thanks....bill
