diesel vs. gas
Which engine is more trouble free, gas or diesel? Many people have told me that gasoline engines are more trouble free but I'm not so sure. What do you readers think?
This doesn't mean one can ignore a diesel, either. Lack of routine maintenance will destroy any engine.
I just dig driving diesel so much I git carried away. I had to buy a new truck with a gas engine because diesel isn't an option in a Dakota, and I didn't want a huge, $38,000 truck. The 4.7 V8 is nice, but I really really miss the diesel...
1. Maintenance is not cheap! More oil to change. Parts are more expensive. I spent $625 for a new starter. You have two batteries to replace. Fuel injectors can run into the $100s+ EASY, especially for the newer trucks (i.e. the Power Stroke injectors are over $600 EACH and there are eight of them!) You can go longer between rebuilds than gas but rebuilds can run $2000-3000 for a GOOD one. On the positive side, I got 135,000 miles out of the original glow plugs. That is not necessarily the norm, and they run about $8-12 each.
2. Finding qualified diesel mechanics can be tough, especially in smaller towns. I have had some of the worst diesel mechanics right at the dealership (very little experience). I've had better luck with diesel mechanics that work on big rigs.
3. Fuel is getting to be the price of mid- to premium-grade unleaded. Depending on where you are, diesel can be tough to find, especially in small towns. You have to plan your routes accordingly.
4. Check out TheDieselPage.com. Great site if you own a GM diesel!
As mentioned, if you want torque for towing, diesels are the way to go! If it's just to have a Turbo Diesel, plan on higher maintenance costs! Good luck!
Dave
My first GM Goodwrench oil and filter change was only $68, included 12 qts Titan oil, and with discount coupon, was only $48.
If all goes as planned I will be pulling my 5th wheel rig next weekend. A 14k load. It should be fun to see how this truck handles a big job.
14K 5th wheel? That's the REAL deal. Good luck, and let us know how it does!
BTW, you need a BIG drain pan!
As for the oil, there's a good chance they put 12 in and that that's the correct amount. My owner's manual is off, too, though only by 1/2 quart.
Hunter
Best of Luck
Hunter
