Subaru Impreza WRX Wagon
There's a dealer called Barber in Orem, closer to you, but I don't know anything about them. Good luck!
Oh, also - Nate Wade's doesn't tack on any phony "paperwork fees" or paint treatments, etc. that are nothing but pure profit for the dealer. I was surprised on one trip to a Honda dealer to find them still trying that. I thought all that baloney was a thing of the past.
Here's my question:
Why does the UK WRX recommend a cool down? Anything to do with the TGV's?
Dennis
-juice
-Jason
Can anyone confirm this and if so why?
thanks- sm
In the WRX turbo, Subaru designed the turbo in such a way that, it does not require a cool-down cycle. Due to its design, it does not affect its bearings and with minimal care, should last till the life of the engine (250,000 miles ??). As for myself, I do keep the engine running for a minute after driving around, just to be on the safe side.
Later...AH
-juice
Cliff
Apparantly, coolant continues to circulate through the turbo even after the engine is shut off, so no damage will occur and you can treat it just like a regular engine.
IMHO, excessive idling the engine probably does more harm than turning the engine right off after some spirited driving--but this only applies to the WRX. But then, OK, if its 100 degrees outside and the engine has been really running hard, then I would let it idle for a couple minutes or so.
The single best thing to make this engine and the turbo last a long time is change over to Mobil 1 after the 1000 mi. break-in. It is actually cheaper than using conventional oil in the long run, because you can go twice as long between re-builds when you conscientiously use a synthetic. You will also get a slight 3-4 boost in hp.
--RA
A good resource for this is:
http://www.seansa4page.com/resource/breakin.html
Later...AH
Anyone know where I can get a nice wooden gear shift knob? I don't like the weird looking carbon-fiber or plastic knobs designed for Subaru's. And how do you get the shift knob off? It doesn't pull straight off and it doesn't unscrew. Thanks!
Cliff
I don't yet own a WRX, but am close to purchasing one (5 spd wagon). Once I get it, I'm leaning very strongly to outfitting it with Nokian Hakkapelliita snow tires in winter only, and sticking with the OEM Bridgestones for summer driving. I live in the Salt Lake City area, and I drive daily between the Salt Lake valley (~4500 feet) and Summit County (~7500 feet).
I've heard aweseome comments about these tires for winter performance. Some reviews reprinted in Nokian's website (obviously biased) claim they out-perform any other winter tire. I believe they're widely used in winter rallies.
I wouldn't run them in summer, since they would wear very fast at temperature.
Anyone out there familiar with this brand? Think this would be a lean, mean, traction machine when combined with the AWD of the WRX?
Would it even be necessary... it seems like lots of owners are very pleased with the grip of the standard tires. I'm going for max traction and security in some occasionally harsh conditions.
Thanks for the comments.
Stephen
Have a good one!
Patti
Patti
-mike
If not, go for the Michelin Arctic Alpins. Also an excellent tire. I do not recommend the Pilot Alpins though. Snow grip is pretty mediocre.
Heated mirrors are nice up here, that's for sure.
xcskier: I'm in Salt Lake too, have had my WRX wagon 5spd for 2 weeks now. I've been getting around fine in the valley since the snow came with the OE tires, but if you're up in Summit Co. a lot I'll bet you'd find winter tires worth it. I know any edge I could get I'd take with all those big rigs up Parley's. I have no experience with Nokians but I know the Blizzaks are great, and my wife has the Michelin Arctic Alpins on her Prelude and they are also fantastic. The Arctic Alpins are rated especially good on ice and so may be the best bet, as with AWD snow traction is pretty easy to come by. I believe ice/hard-pack are the main concern, and these tires have a unique (as far as I know) design with about a million tiny little grooves (siping) that are particularly effective in those conditions.
I wouldn't run them in summer either - and you may want to consider a set of steel rims (blasphemy!) for the winters as mounting/dismounting tires twice a year is hard on them. IMHO the performance downgrade with the steel rims is pretty irrelevant in the winter, and they're a lot cheaper than alloys, of course.
re Shift knobs: my car came with the titanium knob, which I hated (uncomfortable shape and COLD in the morning) and also the carbon-fiber trim, which I wouldn't have ordered, but like now that I have it - so I just put a Momo carbon-fiber/black leather knob in my car. Looks cool, doesn't match the interior trim perfectly but its close enough, and its comfortable. I believe the model is "Shadow". And the titanium knob, anyway, does unscrew - just give it a real serious twist.
If you call Mobil at their 800 number, they will tell you straight out that you can change over to Mobil 1 as soon as you drive the car home from the lot. They would not make that claim if they didn't have some pretty hard evidence that the stuff is entirely safe for your car to use--i.e. lawsuit-proof evidence that would stand up in a court of law. Otherwise, they would have been litigated out of business by now. Almost all manufacturers today, including Subaru, make their engines to very close tolerances, far more so than in the past, so there is really no need for a 10,000 mile break-in.
If you call Subaru of America, they say it's perfectly fine to use, just wait 1000 miles for the rings to get a proper seal. I changed over to Mobil 1 at 640 miles on our WRX wagon, and have no problems whatsoever. The engine uses very little oil (1/4 qt.) between changes, so the rings have sealed properly, it idles smoothly, and runs like a top.
My personal feeling is Mobil 1 is sooo much better than conventional oils, the carmakers are a little afraid if everyone uses it, cars will stay on the road a lot longer and sales will suffer. Hence, all the false rumors about the supposed bad effects about what it does to your engine.
If you look on the Mobil web site, www.mobil.com, you can read about how they ran a BMW for over a million miles and when they broke the engine down, it passed new car specs! I can't vouch for every synthetic out there, but if Mobil 1 does that for a BMW, it will certainly help a WRX make it to the 250,000 mile mark, IMHO, (even with the way I drive ;-).
I've seen other opinions that say you can go 5K or even 10K with synthetics, and that these longer inervals offset the higher cost.
SKIREX from Discount Tires where my Nokian
NRW tires were just installed. You might want
to research this model for your situation. I was advised this was a better choice for someone
highway driving in snow and slush. I plan on using their capabilities driving Albuquerque to Taos a couple of times per week and to Colorado
once a month. I haven't driven them yet but they
do look cool.
Good luck,
Taos
Looking just now, it seems they revamped their website and didn't see the original article on this test, but they will send you info if you ask them. The number is 1-800-ASK-MOBIL.
Just wondering if I should just order my wagon already with the stiff suspension factory kit installed
Stephen
you are right: buy it - drive it - change it - decide
Stephen
Still trying to break it in (not break it!!!) and one of my first impressions is the shifter stinks!! Compared to my Miata, stirring the gears is like poking a stick in a mud pool and trying to stir it. I guess I am spoiled by my Miata.
Now, if I can control myself and not go crazy on the gas pedal.... I am still catching myself giggling while I am driving it, just like the first day I picked up my Miata!!!!
I may be mistaken, but I think the Turbo Foresters come without the hill-holder clutch in Euroland, I'd guess it to be the same when they're launched over here .
TWRX
IMO the stock shifter is a little balky but not vague or imprecise. Quite honestly it doesn't measure up to my old Integra's, but its not bad either.
TWRX
I did the same with my 2000 Acura 3.2TL, which has been absolutely perfect till date, and is an amazingly smooth operative !
Later...AH
-mike
Most race car teams use it-- if anyone has an interest in having the best motor oil, it's those guys.
Regarding the break-in issues, there is a re-print from Motor Magazine on the www.Mobil1.com website. Look under "What Auto Experts Say" then under "Mobil 1 In The News". Apparently, there is a special ester added to the synthetic to help the rings seal, so that's why they say you can use it from day one.
It's easy to understand people wanting to be cautious putting it in, especially with a brand-new car. But I think the more you use it, the more you begin to trust that it really is great stuff, especially if you have a car that you plan to keep a long time.
On a different trip, I drove at a steady 70mph during the entire trip and the mileage was at 36.5mpg. Of course it was a strain on me to resist the urge to step on the gas, since I wanted to see how much mileage it would fetch. With a mix of 40%city/60% highway mix, the car generally returns about 22-24mpg.
The EPA figures are at 19/29 for the TL/TL-s.
I believe the owner's manual recommends 5w20 or so for the TL-s. You may need to check it out.
Later...AH
-mike
Later...AH
Also, CR did the test like a strict laboratory experiment, changing religiously at the specified intervals. You and I both know that's not the way the real world works. I once new a lady who hadn't changed her oil for 28,000 mi.! And a lot of people out there don't get around to changing it until months after they're supposed to. By then, the wax and other natural contaminants found in dino are really starting to sludge up the engine and create performance-robbing depostits. If they are using a synthetic, that wouldn't be nearly as much a problem, because it doesn't have any wax or other contaminants.
If you're leasing your car and plan to turn it in after 2-3 years or if you are driving an old car that leaks oil, then OK, don't bother with a synthetic. But if you plan to own your car and especially if you have a high-performance car like the turbo-WRX, you are crazy not to put it in! Just MHO. Sorry, but it's simply the finest protection you can buy, bar-none. And you'll get the extra cost back in the long haul, because your engine will go a lot further between overhauls.
I'd be happy to report back just how long my WRX engine lasts with the Mobil 1--if you guys are willing to hang around for 15-20 years
Dealer says it's a bad gasket, but I didn't get to talk to the mechanic to find out more about which gasket it was. Likely story? Anything I should check when it comes back?
Total mileage at pickup 79
Total mileage at return to dealer 201
Disappointed in Delaware -
-Eric
To me, that's not much to have the best engine protection for a $25-grand WRX investment.
OK, that's my last comment, I'm going to stop beating the horse on this topic.
To get a new thread going, does anyone know how many extra horsepower you can get by installing the Prodrive muffler on the WRX? Do you get any better gas mileage, and are there any drawbacks to doing this--passing emissions, etc.?
