Volvo 240 Wagons
I own a 1990 240DL with 175,000 miles on it. It needs no rotors and pads and maybe a new front hub bearing. Other than that it runs fine. My question is I also have a 1992 Saturn with 104,000 miles on it (just replace alternator, however, other than an engine mount and an oil seal that is the only things I have ever had to replace), and I need to sell one. Which one? Any suggestions? Anyone else out their with a 240 who has alot of miles on it? How many more is reasonable? Thoughts . . . rants. . .
Thanks in advance for any posts,
me.
me.
If you've had no other problems with your 240 other than those you describe, and there is no rust problem, I'd say you have considerable driving ahead of you. If the a/c fails, however, a new one (if it can be found) is priced out of sight.
Check message boards, car ads, etc. You will probably get more money for the Saturn.
Good luck - Elizabeth
Still, I love the old tank. I've put a bunch of money into it (rear-main seal, front brakes, tranny seals, etc, etc.) but it always get's me where I'm going.
Keep the brick, sell the Saturn is my opinion.
I'm considering purchasing the car for use as a daily driver. Since I've never owned a Volvo I am curious to see if this vehicle looks like as good of a deal as I think it is. I understand that the 240-series cars will routinely deliver 250,000 miles if properly maintained.
CJA
Still, the price is a touch high. KBB's prices seem to be a bit above realistic in my opinion.
Have a GOOD Volvo mechanic give it a thorough look-see and go from there. You are at just about the mileage where a few expensive things "may" need to be done. A good mechanic can give you that info and you can adjust the price from there.
I believe you can find a [i]"what to look for"[/i] list at www.brickboard.com or www.swedishbricks.com
I became very interested in the Volvos because of their safety reputation. I would like any follow-ups or suggestions on this and which model you would suggest I am more interested in the wagons. Thank-you.
I always install a vacuum gauge on my vehicles. It fit nicely into the instrument blank just to the right of the gas gauge, and left of and on the same plane as the radio.
A vacuum gauge measures 15 separate running engine functions. The B230F 4 cylinder 2.3 L. engine is solid. The gauge indicates that, and it sounds and runs that way. It uses 1/2 quart of oil within my 3 to 4,000 mile oil change cycle. It doesn't leak a drop of any fluid.
I use the vacuum gauge to show me when it's time to shift down with the 4 speed manual trans. After awhile of mountain road driving, I'm not sure if I'm going up or down. With the gauge, there is no doubt about what gear the engine will do best with.
I had the timing belt replaced and valves adjusted at 124,000. 60,000 is recommended, but since it is a noninterference engine - nothing damaging will happen if the belt brakes, I stretched that. It's due for another belt replacement at 212,000 - actually long overdue.
Another repair I've done is replace the water pump at 100,000. I forgot how often I've replaced the brake pads - mountain driving uses brakes, but since I bought free replacement pads, I just take in the worn ones with my receipt and come home with new ones.
4 wheel disk brakes makes brake work easy. Once the wheel is off, I can put in new pads in 5 minutes/wheel.
Consumer Reports top rated the '86 240 in driver and passenger safety, as well as structural integrity. Only 3 other cars for that year were rated as high.
I had two unbelievable handling experiences. While driving at night, about 60 mph, all of a sudden, a guy was standing right in the middle of our road way. Not in the middle of the road, but right in the middle of the car. Dark clothed, and appearing out of nowhere, all I had time to do was snap the wheel to the left, and back to the right. Fortunately, there was no oncoming traffic, and I didn't hit gravel on the road edge. I shook more than the car.
The other, I drove nonstop for 2 nights and a day going East on I-80 from Salt Lake City during a continuous blizzard. At times, the Volvo was the only car on the road - all the others were in the ditch.
Dunlop SP 40 A/S 195 70 R 14 has been my favorite tire.
After all this bragging, I end by saying we are selling it. We need more seats for our Grandchildren and have chosen a mini-van. I wish for the same kind of luck and longevity with it.
I am really puzzled though, by this little button on the drivers side of the automatic shifter--what does it do, and why won't it turn off? I'd really appreciate any advice here! :sick: :confuse:
I just got an '84 240DL wagon. The external release for the rear gate immediately broke. The inside still works. Peering in, it appears that there was some kind of linkage that connected the interior and exterior latch releases and this is now gone. Has anyone had this happen and does anyone have any suggestions?
-cliff
I have a 93 240 wagon , bought it with 43,000 miles, have 260,000ish now. The odometer and tripometer quit working at 255,000. Bought a used one off of ebay worked for 142 miles and now also has quit, Can anybody help me?
I need this to keep track of gas. Runs out of gas at 11 gal. gas gage does not work, neither does instrument cluster main lights or radio lights. I think this year is isn't as good as the others. :confuse:
license plate light
rear wiper motor
center brake light(bottom center of window)
your can get a replacement hinges at www.ipdusa.com.
when you replace hinge remove tailend of headliner and replace section of wire. when replacing use extra shielding to contain wires.
">ac compressor bypass kit http://www.ipdusa.com/ProductsCat.aspx?CategoryID=516&NodeID=567&RootID=629
this pulley replaces the one on your power steering. It puts the drive line directly inline with main shaft pulley that used to drive the compressor. the belt provided in the kit is the size you need.
you may also want to put new bushings in your power steering mount. This is a good opportunity to do this.
I have owned 240's my whole life, and I miss them all. I am willing to offer my perfect condition 740 wagon to trade for a 240 wagon that has some or all of the following
gl, gle, or a 240 dl with electric windows
cruise control
no rust body
volvo tow hitch a plus
m46 tranny (4spd stick with push button overdrive)
resistive coil springs in rear (heavy duty)
late 70's ealry eighties a plus
thank you,
Carlo
My boys trashed my beloved 240 DL and now I am trying to restore it to its better days. I need help finding parts because I don't know the exact names etc. I'll list the problems.
- missing front grille
- very loose driver door handle (works though)
- driver and pax seat warmers wires are all messed up thanks to backseat pax sticking feet up under seats...
- missing big flat piece that attaches under the engine (to keep it clean from splashes?)
- missing driver door 3-4" trim
- missing entire bottom 4-5" trim type part that goes all along the side bottom of the pax side.
- missing small trim (~1" with part chrome) on pax door
- cruise control no longer works
- odometer and trip-ometer no longer work
- both rear light fixtures are broken and need to be replaced ($150 each from Volvo!!!)
- the little ball thing that you hold on to on the shifter is gone - needs to be replaced (bought 3 from auto type stores, none fit)
I love my Volvo and feel very safe in it. I'm sure it has at least 240,000 miles on it and now that I've had the clutch replaced, it runs great again (but it's loud - needs new exhaust system too).
Thank you all for your help and forgive my automotive parts ignorance.
Lynn
ckinglk@cox.net
Here is the problem. Once after my car has been driven on the highway at high speed or for more than 10 min. around the city, it gets very hard to shift in to first and second gears. I have to press on the stick shift really hard and I feels that if I press any harder I might snap the cable or do some other damage. Also the clutch pedal is really stiff. So basically when I start my car in the morning it shifts OK, although not perfectly fine but after about 15 min. drive, it gets progressively harder and grater to shift.
I'll appreciate any suggestions what might be the cause for that.
i own an 87 volvo 240 dl, i just replaced the alternator, and i drove it around for a couple of hours, then i put some injector cleaner into the gas tank, it started up fine, but when i went to drive it a couple hours later it wont start, the engin is sparking, but it seems like its not getting any gas, i replaced the fuel pump relay, but that didnt help, any one had this problem, if its not the fuel pump that would be awsome
js
Good luck-
It works great for the most part but once a week or so
after driving with no problems it wont start.I open the
hood and look see nothing and in a few tries it will start.
I decided to plug and unplug the ECU and heard a rattle.
I opened it up and a resistor R315 was laying on the bottom
and the place it was supposed to be was a little charred.
Anyone know the value of said resistor or it's use. waserd
My mechanic put in three different OD switches - that helped for a few weeks, than they each broke. So he put in a new OD unit for a few hundred bucks. That worked for 6 months, then died. He replaced it for free, as I had bought a factory reconditioned one that had a warrantee. The replacement lasted another six months, then died. We were both very frustrated.
About this time, my left hip got so arthritic that every time I pushed in the clutch it hurt a LOT. I began making driving decisions based on whether or not I had to use the clutch. This wasn't safe, so I thought I had to sell he car and buy an automatic. But otherwise it ran like a top, and I knew that I wouldn't get much for it.
My mechanic suggested he put in a used tranny. For about $1000 (parts and labor and tax), he replaced the 5 speed manual with a 4 speed w/OD. The mechanic was very happy that he had managed to locate a tranny from a turbo, which he said was more heavy duty. It also had "only" 90K miles on it. (Gotta love Volvos.)
That was 100,000 miles ago. So for $1000 I got to keep my car and solved the annoying OD failure problem. The OD in the replacement automatic tranny has been fine.
Got the hip fixed too - total replcement. Good as new!
Slipjig
my 1984 240 DL is 22 years old and has 304,000 miles. I am the original owner. I have done oil changes every 3K miles, and kept up on all the safety and mechanical necesseties.
I love this car, and wanted to drive it till it died - but it just won't die! 304 K miles and she still starts on a dime and purrs right along. She shows no signs of giving up the ghost anytime soon. Burns no oil, never overheats (has an extra large radiator).
The inside is, well, thrashed. Several generations of dogs have chewed various internal parts. (The flat folding bed in the back is FABLOUS for dogs and cargo). Loads of lumber have torn some of the upholstry. The seals on the AC cracked years ago and the cost of repair greatly exceeds the value of the car, so I have to drive around with the windows open. This is a pain with hand crank windows!
The wiring harness to the back hatch has broken - a common thing with 240's. My mechanic says he could fix it for about $150, but it's not worth it to me - I spent $500 for new rotors instead. (They couldn't be turned any more.) I have gotten along for years without that little back wiper.
The exterior shows some battle scars from rocks and from the huge tree that blew down right next to it. The car next to mine was totalled, but my lucky little Volvo just got grazed by a limb or two. A little bodywork on the roof and it looked fine. But that was 11 years ago, and now the touch up paint has faded. I call it character.
But EVERYTHING else works just fine. These are simply amazing vehicles.
Alas, I have to sell it, as I finally bought a new car. (Subaru Forester - I need to get back into the mountains, and my old 240 just can't take me there. At least the Subaru is boxy, too.) I think I need a grief/loss support group.
Slipjig
Message:
While cruising, at either high or low speed, DL 240 loses power and I coast to shoulder of road. Turn off ignition. Start. Has started and has not started. Has been towed. Cannot identify causative driver behaviour or physical problems of the vehicle. Has anyone had similar experience? Do you have a clue as to cause? If so, were you able to solve the problem. How, please? Tjhank you. While cruising, at either high or low speed, DL 240 loses power and I coast to shoulder of road. Turn off ignition. Start. Has started and has not started. Has been towed. Cannot identify causative driver behaviour or physical problems of the vehicle. Has anyone had similar experience? Do you have a clue as to cause? If so, were you able to solve the problem. How, please? Tjhank you.
Message:
Can you tell me where the ECU is so I can check it out and also if you got it fixed?
Desssa
Manual said to check the fuse on the left wheel housing by the coil. Can't find the fuse. Anybody know where it is?
Please help.
Desssa
working OK. Both Units are under the glove box and next
to the fender, behind a cardboard type panel.
Good Luck Ed
